Can't get car out of park!!?? - Chrysler 300C Forum: 300C & SRT8 Forums
1st Gen SRT8-Specific General Discussion General Discussion specific to the SRT8 models. If your topic is not specific to the SRT8, please post it in the All Models Forums.
post #1 of 15 (permalink) Old 08-09-2011, 07:27 AM Thread Starter
Points: 15,665, Level: 1 Points: 15,665, Level: 1 Points: 15,665, Level: 1
Car: 2006 Chrysler 300C SRT-8
Car won't come out of park. Was fine yesterday and this morning I started it up and it won't even move from park. Things tried..rocking the car, emergency brake, seat belt, praying. Any suggestions?
Predator tune/AFE CAI/Blastin Bob's 11 db Pipes/Proxes 4 staggered 245-275
-2006 300C SRT8- is offline
post #2 of 15 (permalink) Old 08-09-2011, 08:21 AM
Points: 685, Level: 1 Points: 685, Level: 1 Points: 685, Level: 1
Car: 2006 Chrysler 300c SRT8
Look up (The Pink Thingy) on this site. There is a bypass for this on the right side of shifter, pull the plastic rectangle cup out and push the button in the square opening. (That might work)
Also their is a recall on this problem. Or you can get an alum. part from Bullit Tech. and get away from the plastic ones. There is a video on YouTube on how to replace this part (Park Interlock).
Good Luck!
Indy Ice Man is offline
post #3 of 15 (permalink) Old 08-09-2011, 08:41 AM
Points: 88,359, Level: 1 Points: 88,359, Level: 1 Points: 88,359, Level: 1
GoofyTimL's Avatar
Car: '15 300C Platinum Jazz Blue; '07 MSRT8 Bright Silver MSRT: Edelbrock SC w/ InTune, 402flaps, Stealth HIDs, misc BT stuff, dual pin stripes, 35% tint 300C Pt: 35% tint, SpLx Pedal Set so far
Yep... that's my best guess also. Here's the thread that can get you going... regarding replacement/installation of the "thingy" part.
Park Lock-Out Mechanism Installation
but now there's the 300C Platinum and an Edelbrock SC Magnum SRT8!
GoofyTimL is offline
post #4 of 15 (permalink) Old 08-09-2011, 08:56 AM
Points: 71,838, Level: 1 Points: 71,838, Level: 1 Points: 71,838, Level: 1
Good Luck!
Chances are pushing the button in the square hole will not release the shifter. This release method was not designed into the car for this type of park lockout mechanism failure.
The recall is known as "K-39". Call your stealership with your VIN inhand and have them check to see if you are in cluded in the recall.
There is an emergency release procedure detailed somewhere on this forum. It involves removing the bezel that surrounds the shifter to gain access to a cable below, then poking it with a screwdriver to activate the release. Do some fairly extensive searching to find it.
If you are not included in the recall there are several solutions to the problem, such as: get the car to a stealership for a shifter mechanism replacement, about $350; order the Billet Technology (BT) replacement part and replace the broken part yourself, $50 for the part plus any labor (about an hour-and-a-half) not provided by you, or have someone do it for you, (requires removing the center console and other components to gain access; remove the center console and disassemble the shifter to remove the broken part so as to drill a hole in it and insert a cotter pin to provide an attachment point for the return spring, about $0.02 for the cotter pin.
CAUTION: Problems with key removal can be created if care is not exercised in disassembly/reassembly of the shifter and associated control cables.
As previously mentioned "Good luck!"
DESIREE is offline
post #5 of 15 (permalink) Old 08-09-2011, 09:57 AM
Points: 37,948, Level: 1 Points: 37,948, Level: 1 Points: 37,948, Level: 1
Car: 06 Deluxe! CSRT8
May wish to note that Dorman has this part in aluminum for about 20 bucks
J. William Fulbright
Steve
06 300C SRT8 all stock
stevesrt8 is offline
post #6 of 15 (permalink) Old 08-09-2011, 10:39 AM
Points: 30,476, Level: 1 Points: 30,476, Level: 1 Points: 30,476, Level: 1
kevenj's Avatar
The dorman part is available thru Napa or any parts store pretty much; OR you can just remove the 'pink thingy' completely and be done with it for $ ZERO - - and a couple hours time invested. I've removed it on my car and my Dads with no ill effects. I can now turn my ignition off and remove the key without first putting the shifter in park, but why would anyone ever do that anyway? Other than that everything works as before.
kevenj is offline
post #7 of 15 (permalink) Old 08-09-2011, 12:48 PM
fm1
Points: 20,534, Level: 1 Points: 20,534, Level: 1 Points: 20,534, Level: 1
fm1's Avatar
Car: 2011 Sapphire Crystal Metallic Chrysler 300c
The screwdriver trick is explained in both of the links below.
Stuck in PARK - Dodge Charger Forums
Shift Mechanism Pink Thingy Explained - with links. - Lx Forums | Dodge Charger Challenger Magnum | SRT8 | Chrysler 300 Forum
Good luck.
<img src=http://www.300cforums.com/forums/images/smilies/new/fing02.gif border=0 alt= title=Fing02 class=inlineimg />
2011 Sapphire Crystal Metallic 300C
2006 Magnesium Pearlcoat 300C
fm1 is offline
post #8 of 15 (permalink) Old 08-09-2011, 01:30 PM
Points: 13,645, Level: 1 Points: 13,645, Level: 1 Points: 13,645, Level: 1
Car: 2006 Dodge Charger SRT8
Great advice there moderator.. Maybe you could get Dorman to come over here and pay a couple hundered bucks a month to help support this forum too..
That being said that part, last I heard was on national back order for whatever reason,
Billet tech "A long time supporting Vendor" has them in stock at all times,, We realize we are not as cheap as the over seas part but we do offer a life time warranty, And customer support which the other brand does not.
Our part ships within 24hrs "M-F the other part usually does not.
We also have over night options as well.
Any other questions feel free to shoot me a PM or email info@billettechnology.com
https://www.custombilletstore.com/Se...sp?Search=1028
1fst4dr is offline
post #9 of 15 (permalink) Old 08-09-2011, 05:59 PM Thread Starter
Dealership fixed it. Done. Now to put my tune back on.
post #10 of 15 (permalink) Old 08-09-2011, 08:21 PM
fm1
fm1's Avatar
So what was the story? How did you get it to the dealership ? Did you use the screwdriver trick ? Tow truck ? AAA driver who was knowledgeable and got you going ? Dealer house call ?
fm1 is offline
Car stuck in Park xiaolong 1st Gen SRT8-Specific General Discussion 28 11-10-2012 06:12 AM
HELP!!! My car doesn't want to come out of PARK HELP!!! 300ARUBA General Discussion 16 08-28-2010 10:35 AM
car will not move out of park onebadcbr929 1st Gen SRT8-Specific Problems/Dealer Service 21 05-22-2010 03:21 PM
Never park your car in the street!!! slabhurta02 General Discussion 23 12-19-2009 01:22 PM
Why do they have to park by our car?? Masochist General Discussion 36 04-09-2007 05:08 AM
