Getting BOOSTED what's needed - Page 6 - Chrysler 300C Forum: 300C & SRT8 Forums
1st Gen SRT8-Specific Performance & Engine/Intake/Exhaust Mods This section is for topics related to SRT8 performance & performance mods. For non SRT8-specific topics, please post in the All Models Forums.
 4Likes
post #51 of 78 (permalink) Old 11-30-2016, 04:28 PM Thread Starter
Points: 118, Level: 1 Points: 118, Level: 1 Points: 118, Level: 1
Activity: 53% Activity: 53% Activity: 53%
So the brake boost is recommended for T-Ing in the vacuum system. As far as the spark plugs what should the gap look like? I just put in stage colder plugs and gapped to 33-34 and was running good with nitrous and when I took the nitrous off. My tuner stated that gap is still ok, but wanted opinions
SRT8-GHOST is offline
post #52 of 78 (permalink) Old 12-01-2016, 02:37 AM
Administrator
Points: 101,395, Level: 1 Points: 101,395, Level: 1 Points: 101,395, Level: 1
Activity: 86% Activity: 86% Activity: 86%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Originally Posted by Kaiser Bill View Post
....Also reduced my plug gaps....misfire at 5000rpm WOT now cured! (from .052" to .032"). It wasnt a slipping belt as I'd thought (kudos Johan Mangs, "Diablotoona", everyone's favourite CMR tuner for the diagnosis)
Watching You Avoiding Me!
Kaiser Bill is offline
post #53 of 78 (permalink) Old 12-01-2016, 06:06 AM
Points: 85,678, Level: 1 Points: 85,678, Level: 1 Points: 85,678, Level: 1
Activity: 29% Activity: 29% Activity: 29%
silver06hemic's Avatar
Car: 2006 Chrysler 300c
Sorry pal I just saw this... Yes it's the line you pointed to, the booster line.
For lighting I'd read this pal... Great info and it saves me typing it all! Lol. Its where I learned from years ago and I kept it as a reference just in case.
http://www.lxforums.com/board/showth...e-illumination
Plugs you should absolutely gap to 035... They all should be consistent as even a slight variation (or less than 035) can make a difference to the burn and make it a bear to tune.
Sent from my VS986 using Tapatalk
FRI'd Sidewinder, Novi 1200 S/C @ 7.5psi, Custom TR1235 A2A Intercooler, Tial BOV, Ported SRT Headers & Gutted Mid's, EGR, MDS & 02 Delete, Custom Catback w/Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Big Bully Catchcan, 3.06 diff, 2800 stall, MTCM, Tranzformer, SRT Rad, SRT P/S Cooler, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, SE Coilovers.
AMP'd, FRI'd and Blown... 476rwhp/507rwtq @ 7.5psi
11.51@117.02mph 7.5psi/DR's
silver06hemic is offline
post #54 of 78 (permalink) Old 12-01-2016, 06:38 AM Thread Starter
Thanks will check it out today and reroute the vacuum system to the brake boost. Soooooo close to being kinda fast
post #55 of 78 (permalink) Old 12-01-2016, 06:41 PM Thread Starter
All vacuum lines are be rerouted to the brake boost. Now question, I have next to no room to put an air filter on the blower it literally sits right behind the drivers headlight. I have searched, searched.....& searched some more.... can you throw me some info on what I can use?? There literally might be 3 inches of width (being gernerius)
post #56 of 78 (permalink) Old 12-01-2016, 07:57 PM
If it's a reverse routed blower then you will need a pancake air filter... I use one from AutoZone... Crap brand but it's actually really stout and has good surface area...
post #57 of 78 (permalink) Old 12-01-2016, 08:01 PM
http://www.spectreperformance.com/mo...aspx?prod=8161
Take a look at this... Its like mine. As I said, not a great brand but I change them every other oil change anyway and I have had no collapses... I also know a guy running 16psi on it and it hasn't been sucked in yet so I feel safe at 7.5psi! Lol
post #58 of 78 (permalink) Old 12-02-2016, 05:50 AM
Administrator
Originally Posted by silver06hemic View Post
8161 - Spectre , Spectre Conical Filter
post up a photo of yours.....mine is a cone filter that crams under the strut brace & against the coil cover
post #59 of 78 (permalink) Old 12-02-2016, 03:48 PM Thread Starter
Spark plug gap.....??? I am running very rough at idle and getting up to cruising speed then it pans out decent. My tuner said my data log showed pas side bank 2 dumping much more fuel. He said look for vacuum & exhaust leaks or replace the o2 sensor. I replaced all the vacuum lines and sprayed TB cleaner on everything and never heard the engine idle higher. I don't see my o2 sensor randomly going bad and I would hear if I had an exhaust leak.... I believed I gapped my plugs around 35 and they are a stage colder but could I be experiencing "blow out" as the red flags for it appear to be what I am experiencing.
post #60 of 78 (permalink) Old 12-02-2016, 05:36 PM
Post #53 .... gap them at .035... looks like you have, but check them again and move on as that's where you will need to be. Make sure none are cracked while you are in there...
Everywhere you tapped a vacuum line you have checked right? Is it rough on acceleration out of boost?
Your support needed: Well, your input anyway Jim777 Intake & Exhaust 4 04-18-2016 09:36 PM
Interior stain or spot removal advice needed Jim777 Interior Appearance 11 02-22-2016 12:08 AM
2.7 to 300c conversion? Items needed MZP32398 Customize Your Ride 3 12-05-2015 11:08 PM
recommendations needed Todd Coppage Car Audio/Alarms/UConnect/Navigation 2 11-14-2015 02:41 PM
Edelbrock test vehicles needed. rjbeck Performance General Discussion 0 08-11-2015 01:38 AM
