2013 Srt 8 acceleration sag - Chrysler 300C Forum: 300C & SRT8 Forums
1st Gen SRT8-Specific Problems/Dealer Service Please post SRT8 related problems and dealer service topics here. For non SRT8-specific topics, please post in the All Models Forums.
post #1 of 35 (permalink) Old 08-30-2013, 12:17 AM Thread Starter
Points: 3,775, Level: 1 Points: 3,775, Level: 1 Points: 3,775, Level: 1
DjHEMI's Avatar
Car: 2009/2012/2013 Chrysler 300C Hemi/300 SRT-8
Anyone have any trouble with an acceleration sag/delay? I was attempting to pass a semi as we both left a stop sign at about 35 mph, I got in the left lane and hit the gas and it lost power until I let off and pumped the throttle slightly and hit it again and then it accelerated quickly like it should have the first time. I did only have about 1/8 tank of gas I took it into town filled the tank and again jammed the accelerator down and it seemed to have the lag and it was making a deep intake sound like the old 4bbl carbs did. I switched the setting to "track" and tried it again. If I was above 25 MPH it would lag if under 25 MPH it would burn rubber on the roll and get right with it. A very moody car sometimes. The temp was around 87 today with high humidity but the car had never done that before even in higher outside temperatures. Any thoughts?
DjHEMI is offline
post #2 of 35 (permalink) Old 08-30-2013, 08:45 AM
Points: 25,740, Level: 1 Points: 25,740, Level: 1 Points: 25,740, Level: 1
SPARTAA's Avatar
Car: '12 Chrysler 300 SRT8
It's an automatic, is my suggestion. I just purchased mine and when I press the gas pedal hard it delays about 1-2secs then takes off.
United States Marine Corps.
"I wanna be your drill instructor, I wanna wear that smokey bear..."
SPARTAA is offline
post #3 of 35 (permalink) Old 08-30-2013, 09:36 AM Thread Starter
DjHEMI's Avatar
Originally Posted by SPARTAA View Post
It's an automatic, is my suggestion. I just purchased mine and when I press the gas pedal hard it delays about 1-2 secs then takes off.
I would agree on that other than I had the G-force meter on and I noticed G force went to the front of the car when I started passing the semi truck during the lag period it was for about 4 seconds at a guess..more like it starved for fuel or backed timing way down
DjHEMI is offline
post #4 of 35 (permalink) Old 08-30-2013, 10:30 AM
Points: 81,342, Level: 1 Points: 81,342, Level: 1 Points: 81,342, Level: 1
MADDOG's Avatar
I'm surprised that so many of you are experiencing this problem. My only thought was some sort of excess air leakage (loose intake hose, loose vacuum hose, etc...) is happening but this sounds a bit more problematic.
Michael
MADDOG is offline
post #5 of 35 (permalink) Old 08-30-2013, 12:04 PM Thread Starter
DjHEMI's Avatar
I just did a visual inspection after you mentioned that and everything is tight I was wondering if being at 1/8th tank it may have temporarily sloshed to the back of the tank and lost fuel volume and pressure? I am going to take it out on a stroll later today and temps are right around 87F here again, I want to see if it is going to reoccur. I have also been mixing 89 with 93 octane as gas is over $4.00 again I had forgot I was doing that and maybe it retarded the timing way too much?
DjHEMI is offline
post #6 of 35 (permalink) Old 08-31-2013, 02:49 PM
SPARTAA's Avatar
The mix of gas could be the issue. That would explain why mine has done it, since I just bought it and it was still using the dealers gas which I'm sure was the cheapest. I'm sure there is a fuse pull of some sort to reset the timing since your car thinks to give less power because of the gas uve used. I'll have to research it to see.
SPARTAA is offline
post #7 of 35 (permalink) Old 08-31-2013, 04:47 PM Thread Starter
DjHEMI's Avatar
Well on that note: I put 93 Octane in it and took it out for a run today and it was a totally different story. The temperature was about the same and conditions about the same. No lag, good response in all modes. In fact I surprised a camaro owner and myself none the less he didnt want to play all. So I would say fuel was probably my issue at least not to sure about other people with a similar problem..I just hope it inst an intermittent issue that is gone today and here tomorrow.
DjHEMI is offline
post #8 of 35 (permalink) Old 09-04-2013, 03:53 AM
Points: 13,569, Level: 1 Points: 13,569, Level: 1 Points: 13,569, Level: 1
Cannon's Avatar
Car: 2012 Chrysler 300 SRT
I would NEVER run anything but 93 octane in my car. You just spent over 50k for a new car and worried about a couple bucks for fuel? Really?
Jim
2012 Black 300 SRT Sold. Just my Jeep now.
Cannon is offline
The Following User Says Thank You to Cannon For This Useful Post:
Northern Rider (09-04-2013)
post #9 of 35 (permalink) Old 09-04-2013, 07:44 AM
Points: 85,202, Level: 1 Points: 85,202, Level: 1 Points: 85,202, Level: 1
Activity: 76% Activity: 76% Activity: 76%
silver06hemic's Avatar
Car: 2006 Chrysler 300c
Absolutely!!!
Never fails to amaze me... $3.60 on an 18 gallon tank at .20c gallon difference... Ditch one Starbucks a week and save your knock sensors from working double time trying save your car from the massive amount of ST an LT knock your creating. Honestly $50k for a car and feeding it like an 89 Civic is bound to have repercussions inspire of what is 'possible'... Glad you got it all sorted out but people please feed your cars right people!
FRI'd Sidewinder, Novi 1200 S/C @ 7.5psi, Custom TR1235 A2A Intercooler, Tial BOV, Ported SRT Headers & Gutted Mid's, EGR, MDS & 02 Delete, Custom Catback w/Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Big Bully Catchcan, 3.06 diff, 2800 stall, MTCM, Tranzformer, SRT Rad, SRT P/S Cooler, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, SE Coilovers.
AMP'd, FRI'd and Blown... 476rwhp/507rwtq @ 7.5psi
11.51@117.02mph 7.5psi/DR's
silver06hemic is offline
post #10 of 35 (permalink) Old 09-04-2013, 03:36 PM Thread Starter
DjHEMI's Avatar
LOL probably why I have the money to pay it off by this time next year, I am cheap..but if it is going to cause this acceleration sag.. I ain't that cheap anymore
DjHEMI is offline
Rear Bumper sag fix vs. Manufacturing Date fm1 Appearance General Discussion 4 02-17-2009 01:10 PM
How do the SRT-8's wheels effect its acceleration? Normgarry Custom Wheels & Tires 9 05-05-2008 08:50 AM
Eibach Sag ? OC.FAB Suspension/Handling Modifications 5 08-11-2006 05:11 PM
Does your rear bumper sag? bigwise1 Problems / Dealer Service 12 11-19-2005 03:46 AM
22" 20k miles no lowering needed -spring sag BIGTUNA Chrysler 300 Picture/Media Post 4 04-16-2005 08:57 PM
