Transmission Shutter After Fluid Change - Chrysler 300C Forum: 300C & SRT8 Forums
1st Gen SRT8-Specific Problems/Dealer Service Please post SRT8 related problems and dealer service topics here. For non SRT8-specific topics, please post in the All Models Forums.
post #1 of 8 (permalink) Old 08-28-2016, 11:04 PM Thread Starter
Points: 2,172, Level: 1 Points: 2,172, Level: 1 Points: 2,172, Level: 1
Car: 2006 Chrysler 300c Srt8
Hey Everyone i have the 06 300 SRT. It has 34,000 miles on it. I just had the dealer change the transmission fluid and filter for me because I felt like it was time. Now, when i start it up, if I dont let it sit and idle for more than about 2 minutes or so, if I drive off and come to a stop I get a bad vibration. If I drive off and dont come to a stop within a few minutes then I dont get a vibration but I do still notice that the transmission is shifting gears a little harder than before and not as smooth. Almost as if they replaced the factory fill with some garbage fluid.
So then I noticed that fluid was leaking out of the bottom so I took it back to the dealer and they found to have overfilled it. They just did the fluid and filter change not a flush and they added 6 quarts which ended up being over a quart and a half too much according to the chrysler tech. Now that the fluid level was said to be correct I thought the problem was gone but I hadnt shut the car off and then restarted it before leaving so I was wrong. The problem is still there and it even happens if say I stop to get gas somewhere and then when I restart the car the fluid is still hot but it does this vibration when coming to a stop for the first couple of minutes.
What can be the problem here? I was reluctant to even have them change the fluid but I figured the car is 10 years old and even with light mileage it was probably a good idea but now I feel like I made a mistake by having a routine maintenance done.
Also, what if some damage was done by the overfill? Would that allow me to be covered in case I need a new transmission? Especially that im long out of warranty.
Thanks
Mopar Cold Air Intake
Borla Stainless Catback
Magnaflow Gutted Mids
Jet 180 Thermostat
Catch Can
HHP Stage 2 Heads, Cam, Intake
Hemifever Tuned Diablo Intune
Wavetrac Differential
Ati 13% Underdrive Damper
Hotchkis Sway Bar
Koni Strt (orange) Front Shocks
SuperPro Poly suspension bushings
Eagle F1 Asymmetric 265/40/20 front
Eagle F1 G:2 305/35/20 rear
2006 Chrysler 300c Srt8 heads/cam & 2002 Dakota 5.9 R/T heads/cam/gears/stall
Siciliano15 is offline
post #2 of 8 (permalink) Old 08-29-2016, 02:00 PM
Administrator
Points: 101,445, Level: 1 Points: 101,445, Level: 1 Points: 101,445, Level: 1
Activity: 90% Activity: 90% Activity: 90%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
the fluid level has to be exact and it MUST be ATF4+.....NOT Dexron III.
The level has to be measured at a precise temperature. If its not the exact height on the dipstick they use compared to a given temperature graph you'll get real issues - shifting / change severity / gear slip it goes on and on. Just chucking in the amount stated will not do at all....this gearbox demands accuracy within 100CC or so at a precise temperature (the fluid expands enormously as it gets hot), so being a half a pint over or under can make a ton of difference. A quart over, as you suggest, is asking for bad damage to occur. Get the fluid level sorted out properly, hopefully you havent killed the trans, and never go to see those idiots again
Originally Posted by Kaiser Bill View Post
remind me not to have that video guy change my gearbox oil
this guy is annoying, but gets it pretty much right
Jeep Grand Cherokee W5A580 NAG1 722.6 Automatic Transmission Fluid Change Check Fill - YouTube
details of the dipstick and the temperature chart are here....Tranny Dipstick...hope this helps anyone with similar issues
Watching You Avoiding Me!
Kaiser Bill is offline
post #3 of 8 (permalink) Old 08-30-2016, 03:29 PM Thread Starter
they seem to have used the correct oil. mopar part # 68218057ab. they put 6 quarts in when they did the filter change but it was coming out the vent hole so they took over a quart out. not sure exactly how much.
had them check it a third time for the correct level and its still doing the same thing but its not leaking anymore. converter lock and unlock is a little harsher than before and the shutter after startup for the first 2 min or so is still there.
post #4 of 8 (permalink) Old 08-31-2016, 06:04 AM
Points: 85,725, Level: 1 Points: 85,725, Level: 1 Points: 85,725, Level: 1
Activity: 38% Activity: 38% Activity: 38%
silver06hemic's Avatar
Not every dealer is familiar with the correct fill procedure of the Nag1... Kaiser Bill is bang on, this sounds like an improperly filled unit to me.
There is a chart and special dipstick... It MUST be used to prevent issues and or damage. I'd go somewhere else and have them check it personally.
Sent from my VS986 using Tapatalk
FRI'd Sidewinder, Novi 1200 S/C @ 7.5psi, Custom TR1235 A2A Intercooler, Tial BOV, Ported SRT Headers & Gutted Mid's, EGR, MDS & 02 Delete, Custom Catback w/Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Big Bully Catchcan, 3.06 diff, 2800 stall, MTCM, Tranzformer, SRT Rad, SRT P/S Cooler, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, SE Coilovers.
AMP'd, FRI'd and Blown... 476rwhp/507rwtq @ 7.5psi
11.51@117.02mph 7.5psi/DR's
silver06hemic is online now
post #5 of 8 (permalink) Old 08-31-2016, 06:06 AM
I attached the chart for you just in case.
post #6 of 8 (permalink) Old 08-31-2016, 02:41 PM
Points: 24,440, Level: 1 Points: 24,440, Level: 1 Points: 24,440, Level: 1
dhoolwerf's Avatar
I drain and refill my trans fluid every 15K miles (swapped on a Mercedes trans pan with a drain plug), and drop the pan/change the filter every 30K miles. I only drain/fill, never flush. I'm at 120K miles now, so I've done this more than a few times. I bought a B&M dipstick that locks in place so I can check the fluid anytime. Haven't had any transmission problems at all.
I concur with the opinions above...the fluid level is still not right.
dhoolwerf is offline
post #7 of 8 (permalink) Old 09-01-2016, 09:08 PM Thread Starter
ill try this chart and see what happens. thank you
post #8 of 8 (permalink) Old 09-15-2016, 10:54 PM Thread Starter
So the problem ended up being my exhaust. I had it dropped and welded up a few days before the transmission fluid change and hadnt noticed anything but i looked under the whole car today and found that the muffler was touching the rubber coupler that connects the driveshaft to the rear diff. I guess when they dropped the catback the pipe must have shifted just enough. I ended up putting a small dent in the corner of the muffler and it fixed the problem. Soooo glad it was nothing serious. No more vibrations now. It did lightly wear on the rubber but only a small amount it will be ok.
Transmission fluid warmup times Torian General Discussion on Issues / Trouble Shooting 0 01-29-2016 09:08 AM
transmission Fluid turns milky/strawberry likemefranky General Discussion on Issues / Trouble Shooting 6 01-10-2016 08:56 PM
Transmission oil change Boro al Diesel Models OM642 (CRD) & VM (2nd Generation) (CRD) 1 10-10-2015 08:09 AM
NAG1 transmission fluid change info please Alan1 2nd Generation Chrysler 300 Discussion 1 09-29-2015 08:54 AM
