first oil change.....what is recommended? - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > 2nd Gen. SRT-Specific General Discussion
2nd Gen. SRT-Specific General Discussion This area is for the 2012+ general discussion of the new 2nd generation 300 SRT8
Old 11-12-2012, 09:40 AM   #1 (permalink)
PGT
Points: 2,432, Level: 1 Points: 2,432, Level: 1 Points: 2,432, Level: 1
Car: '12 Rubicon MW3 w/ AEV stuff '13 BMW 328i M-Sport '12 300C SRT8
Member Number: 39125
I normally run Motul as that's what my local independent has. I'm not near my car at the moment so I can't RTFM....what is recommended for the SRT8? 5W30? 0W30?
thanks
PGT is offline
Old 11-12-2012, 09:47 AM   #2 (permalink)
Points: 29,667, Level: 1 Points: 29,667, Level: 1 Points: 29,667, Level: 1
Car: 2012 Dodge in my garage Challenger SRT8
Member Number: 6420
0W-40 or 5W-40, I would go 0W-40 being the cold season is upon us.
'12 Challenger SRT8 Pitch Black 6-speed, stripe delete, all options
-BT catch can, skip shift eliminator, AFE intake, BB's resonater delete, Jet 180 t-stat, ceramic tint/clear bra
13.56@104.38 DA 7170 - that's 12.33@114.45 corrected!!!
EricG is offline
Old 11-12-2012, 10:20 AM   #3 (permalink)
Points: 10,557, Level: 1 Points: 10,557, Level: 1 Points: 10,557, Level: 1
blk300limited's Avatar
Member Number: 33977
There was a TSB that came out from Chrysler that says to use 0W40.
blk300limited is offline
Old 11-12-2012, 03:59 PM   #4 (permalink)
PGT
any issues with Mobil 1 in 0W40? The Pennzoil Ultra looks to be OEM for Chrysler so nobody else sells it. Might as well take the car to the dealer if I have to go there anyway to buy the oil/filter.
PGT is offline
Old 11-12-2012, 08:22 PM   #5 (permalink)
Points: 1,758, Level: 1 Points: 1,758, Level: 1 Points: 1,758, Level: 1
MIASRT8's Avatar
Car: 2012 Chrysler 300 SRT8
Member Number: 36120
I use Mobil-1 0W-40 along with the Mobil-1 filter.
The Penzoil is the factory oil and the one installed at the dealerships, you can buy it online also (it has the SRT logo on the bottle) they used to use Mobil-1 but after Fiat bought Chrysler they switched to Penzoil I guess Fiat has a contact with them.
Both are good but I have been using Mobil-1 for a long time and decided to stick with it.
Sent from my iPhone using Autoguide.com App
MIASRT8 is offline
Old 11-13-2012, 08:11 AM   #6 (permalink)
Points: 2,613, Level: 1 Points: 2,613, Level: 1 Points: 2,613, Level: 1
Torian's Avatar
Car: 2012 Chrysler 300S V6 8 SPD
Member Number: 36311
Correct me if I'm wrong, but I believe Penzoil Ultra is a slightly higher grade of synthetic. This could prove problematic down the road with an ******* dealer that gives you flak for using Mobil-1 one instead of the recommended grade.
Torian is offline
Old 11-13-2012, 08:17 AM   #7 (permalink)
Member Number: 6420
You are wrong. Not necessairly about the oil grade comment - who knows - but a dealer will not give you flak for using Mobil 1.
EricG is offline
Old 11-13-2012, 08:17 AM   #8 (permalink)
Member Number: 6420
What Mobil 1 filter number are you using for the 6.4?
EricG is offline
Old 11-13-2012, 09:54 AM   #9 (permalink)
PGT
from MobilOil.com:
M1-210
Amazon has them for $13/ea or a two-pack for $25. There's a seller doing them at $8/ea on Amazon too (FilterDump) but that makes me nervous as I've gotten counterfeit product on Amazon earlier this year. Since they sell for $13.99 or $14.99 at AutoZone or Advance, the $13 seems legit.
PGT is offline
Old 11-13-2012, 10:02 AM   #10 (permalink)
PGT
If I have a choice between 5W-40 Pennzoil Ultra or 0W-40 Mobil 1, what's the better choice? Can't find 0W-40 for the Pennzoil except at the dealer and they charge $13x7 for it. I can get either of the others for $50 for 7 quarts from Amazon (almost half).
PGT is offline
Recommended Motor Oil wilkenms SRT8-Specific General Discussion 6 11-16-2010 10:38 PM
recommended service? albacore General Discussion 8 03-28-2010 07:54 PM
Max PSI and Recommended PSI? jallen18 Custom Wheels & Tires 16 10-15-2009 05:49 AM
CR says - Dodge Charger - recommended. Camry V6 - NOT recommended CanadaCraig General Discussion 2 10-17-2007 02:59 PM
Recommended Mod list? JBSRT8 SRT8-Specific Performance & Engine/Intake/Exhaust Mods 8 06-30-2007 03:10 AM
