Remote Start Question... - Chrysler 300C Forum: 300C & SRT8 Forums
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > 2nd Gen SRT8- Mechanical
Register Home Forum Active Topics (T) Gallery Garage Search Today's Posts Mark Forums Read
LinkBack Thread Tools
Old 06-13-2013, 09:25 PM   #1 (permalink)
Major Contributing Member
Points: 23,315, Level: 1 Points: 23,315, Level: 1 Points: 23,315, Level: 1
hofb99's Avatar
Car: 2013 Chrysler 300 SRT8
Member Number: 52225
So, both Tahoes I previously owned (2007 and 2012) came w/ remote start w/ intelligent climate control (i.e., I can remote start the vehicle and in the winter, the heater would automatically warm up the inside and in summer, vice versa). I believe even the NBS Ford Explorer has this feature. So, I asked the salesman if the 300 SRT had this capability as well...he told me yes, it'll cool down in summer and heat in winter, etc...etc... WELL, I've since found that my 2013 only has the configurable option to turn on/off the heated/cooled seats on remote startup... So, been pretty warm here in MD area and the HVAC doesn't seem to be running when I get in the car after remote starting, but the cooled seating does come on, as advertised... Checked the owner's manual and all it says is, essentially, you can remote start and it'll run for 15 minutes, but it says nothing about heating or cooling the compartment... So what gives? Those of you who own the 2012 or 2013 SRT, does the intelligent HVAC work when you remote start it? Need to know if I'm doing something wrong or if something is broke or "works as designed". AND, if this is not a feature, then CJDR??? Probably the only feature I'll miss from my SUV...
2013 300 SRT8 : Gloss Black > Black Interior >
Vapor Chrome > Pano Roof > SafetyTec > H/K 900W Audio >
GY Supercar F1s > 35% Tint ... + GAS GUZZLER TAX!
{{{ my pony @ the waterhole rehydrating after rigorous workout! }}}
hofb99 is offline   Reply With Quote Quick reply to this message
Old 06-14-2013, 06:56 AM   #2 (permalink)
Points: 2,835, Level: 1 Points: 2,835, Level: 1 Points: 2,835, Level: 1
MIASRT8's Avatar
Car: 2012 Chrysler 300 SRT8
Member Number: 36120
The AC and heat do work with the remote start system. I always leave the AC on when I turn off the car so when I turn it back on the AC or heat turn on depending on the temperature.
I have had the remote start on GM cars and now on Chrysler and IMO I think it's easier to use on the Chrysler as all you have to do is press the remote button 2 times. On GM cars you have to push the lock button first then press the remote button and leave it pressed until it turns on, also on GM cars when you get in the car and turn the ignition on after remote start the AC and radio turns off then on again and on Chrysler everything just stays on.
Sent from AutoGuide.com App
MIASRT8 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to MIASRT8 For This Useful Post:
hofb99 (06-14-2013)
Old 06-14-2013, 10:58 AM   #3 (permalink)
Points: 14,061, Level: 1 Points: 14,061, Level: 1 Points: 14,061, Level: 1
toasteroven's Avatar
Member Number: 38072
Leave your climate control in Auto when you turn off the car. If it's off, it will not automatically turn on with remote start.
"This car is 100% sh*ts and giggles."
2012 Chrysler 300 SRT8 // 6.4L Hemi // AFE Stage II CAI // Flowmaster Force II Cat-back // Diablo Tuned
2004 Dodge SRT-4// 2.4L Turbo // Sunrooof+Vipers // Mopar BOV
2005 PT Cruiser GT Convertible // 2.4L Turbo // Muffler Delete // Pillar-mount SRT Boost Gauge // Mopar BOV // Diablo Tuned
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
toasteroven is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to toasteroven For This Useful Post:
hofb99 (06-14-2013)
Old 06-14-2013, 03:53 PM   #4 (permalink)
hofb99's Avatar
AHH SOOO... So the Chryslers don't come w/ the "intelligent" climate control, but leaving it in "Auto" pretty much does the same...pretty much. Thanks for that idea, toasteroven! Although, in the GMs, if it's say "mild" outside, ~ 55 - 65 degrees (F), nothing will turn on because the ambient temp in the cabin doesn't call for it. But leaving it in Auto sounds pretty slick! Think I'll give that a try...and if the blowers stay on even after depressing the ignition, like MIASRT8 informed us above, then that would be cool too! I didn't appreciate how you had to turn your HVAC back on after turning the key in the GMs... You know, I REALLY wish these salesmen would get better acquainted w/ their product...sucks when they can't answer your questions (let alone CORRECTLY) when you're about to make the next to the largest purchase in your life (second only to one's house, in most cases)...
Old 06-14-2013, 04:10 PM   #5 (permalink)
Points: 1,830, Level: 1 Points: 1,830, Level: 1 Points: 1,830, Level: 1
PirateClown's Avatar
Car: 2014 Chrysler 300S
Member Number: 54185
buy a heatshield from amazon their custom fit and heard they work great.
Btw does your Ram have Rambox(i think thats what its called)?
PirateClown is offline   Reply With Quote Quick reply to this message
Old 06-14-2013, 04:19 PM   #6 (permalink)
There is also an option for enabling or disabling the system (along with the heated wheel separately) in UConnect settings. It should come from the factory / dealership ON by default.
I leave the HVAC system on AUTO all the time, and the only time I turn it off is on mild days with the windows down. If I recall correctly, heated options turn on if the temperature is lower than 4C, and cooled options come on if it's hotter than 24C. I've also found that the temperature sensor itself takes a minute or two to "figure out" the correct temperature.
Old 06-18-2013, 03:48 PM   #7 (permalink)
hofb99's Avatar
I believe the enable/disable setting is only for heated/vented seats...not HVAC. I did ensure that was set to "on" in the Auto/Comfort settings... Haven't found the auto setting for the heated steering wheel as of yet...no need right now I guess as summer is right around the corner.
Yeah, we had a couple of days in the 90s already and one of those days my temp readout displayed 121 degrees when I first got in!
Old 06-18-2013, 09:52 PM   #8 (permalink)
Points: 5,290, Level: 1 Points: 5,290, Level: 1 Points: 5,290, Level: 1
Member Number: 38703
I'm quite sure the AC will return to the last setting. Above 80 degrees the ventilated seats will (should) turn on. I'm not sure what the low temperature is but the heated steering wheel will turn on when it's cold enough.
Catch can, 180 tstat, BT water neck, Drake pedal covers, EBC Red Stuff, 22" Niche Circuits, WeatherTech Ultra Liners, Killerglass, Volant CAI, Mopar '11 shifter
drksyd is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 05:40 AM   #9 (permalink)
Points: 180, Level: 1 Points: 180, Level: 1 Points: 180, Level: 1
Slandrew's Avatar
Car: 2013 Chrysler 300 AWD
Member Number: 120098
I have a 2013 300 Glacier Hemi AWD. I know old tread but my remote start works when it feels like it any help?BatterysBoth keys???The climate control does work hot or cold but remote start not working all the time
Slandrew is offline   Reply With Quote Quick reply to this message
Insurance
Please select your insurance company (Optional)
Remote start/ Diablo Predator question... FRYZSRT8 Car Audio/Alarms/UConnect/Navigation 4 08-21-2009 01:05 PM
Question about a Remote Start Clutter General Discussion 4 12-05-2008 07:15 PM
Remote Start Question tiny3876 Car Audio/Alarms/UConnect/Navigation 2 11-22-2007 06:27 AM
Remote Start Question Buz-CCC Car Audio/Alarms/UConnect/Navigation 8 04-08-2007 06:32 AM
Remote Start Question from a newbie KRO flyz Car Audio/Alarms/UConnect/Navigation 12 02-11-2007 07:55 PM
» Premium Vendor Showcase
» Buyers Guide
Auto Loans Get Approved Today
Warranty Extended warranty packages
Vehicle History Get a vehicle history report in seconds!
Tires Find the right tires for your car
Insurance Get a free insurance quote
» Latest Chrysler News
» Recent Discussions
P0730 in uk
05-13-2017 09:07 AM
Last post by Gazza487
Today 09:25 AM
2 Replies, 85 Views
2014 Chrysler 300c John...
Today 07:23 AM
Last post by Jae Cummings
Today 07:23 AM
0 Replies, 21 Views
NSW Police cars look...
02-08-2017 12:16 AM
Last post by Moparlife
Today 06:15 AM
11 Replies, 338 Views
HELP.....Can't open...
03-24-2017 11:44 PM
by dodge34
Last post by Piggy.
Today 06:14 AM
7 Replies, 191 Views
"Too little car for too...
Yesterday 09:50 AM
Last post by feichter
Today 01:03 AM
2 Replies, 89 Views
Radio/Navigation Dark &...
08-27-2013 07:39 AM
Last post by CarlosOfSanMarcos
Yesterday 09:19 PM
15 Replies, 2,265 Views
How to Update Your Maps...
04-09-2014 03:44 AM
Last post by Piggy.
Yesterday 04:46 PM
664 Replies, 189,270 Views
I want a better exhaust...
Yesterday 12:22 PM
Last post by jasonzane
Yesterday 12:22 PM
0 Replies, 51 Views
Houston, we have...
05-28-2007 05:51 PM
Last post by stealthsrt8
Yesterday 11:49 AM
42 Replies, 15,192 Views
SD Card Vs USB
07-14-2013 08:14 AM
by ron6468
Last post by Doubleg4lsu
Yesterday 07:49 AM
64 Replies, 21,580 Views
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
