Engine bay grinding noise + vibration - Page 6 - Chrysler 300C Forum: 300C & SRT8 Forums
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > 2nd Gen SRT8- Mechanical
Register Home Forum Active Topics (T) Gallery Garage Search Today's Posts Mark Forums Read
Like Tree2Likes
LinkBack Thread Tools
Old 06-02-2016, 11:40 AM   #51 (permalink)
Points: 769, Level: 1 Points: 769, Level: 1 Points: 769, Level: 1
Activity: 40% Activity: 40% Activity: 40%
Member Number: 126194
Negative. They didn't do crap. They are terrible. Getting a field manager now and getting a different dealer to work on it eventually. I did change to royal purple 0w 40 and it seemed to help with lifter noise and after car is hot you barely hear the noise.
12srt8392 is offline   Reply With Quote Quick reply to this message
Old 06-02-2016, 01:16 PM   #52 (permalink)
Points: 187, Level: 1 Points: 187, Level: 1 Points: 187, Level: 1
John_xlc's Avatar
Car: 2012 Chrysler 300 SRT8
Member Number: 124554
I find Mobile, BP, Sunoco brand fuel and Pennzoil Ultra 0-40 helps as well. It really seems like a timing and or combustion issue. Dealership sucks and I'm searching for an independent MOPAR specialist in northern Virginia.
John_xlc
John_xlc is offline   Reply With Quote Quick reply to this message
Old 06-02-2016, 01:18 PM   #53 (permalink)
I hear ya. Try the royal purple. It makes it run smooth and better than Mobil or penzoil. I'm convinced. The noise won't get fixed by dealers ever I doubt. It might just be the MDS lifters and the bad design by chrysler
Old 06-04-2016, 07:40 PM   #54 (permalink)
Hello everyone , I found the reason behind this noise but still haven't fixed it. Oil PSI low causing this issue. Start up your car and watch the oil pressure gauge in the center Dash. You can get to it by checking engine gauges and find oils pressure exact psi. Once my engine goes down to 25 to 30 Psi the noise kicks right in. When cold and higher oil pressure. No noise. I'm trying to figure out if the normal pressure as most people say is 25 to 30 but let me tell you. If you give it to 700 rpms and oil pressure goes to 32. POOF. Noise gone. If it's "normal" 600 rpms and 25 to 30 rpms. Boom clunk clatter vibration noise. I'm going to my mechanic again. I found the culprit now to fix the issue. I need to keep oil pressure at 32 Psi minimum.
Old 07-01-2016, 08:14 PM   #55 (permalink)
Points: 9,023, Level: 1 Points: 9,023, Level: 1 Points: 9,023, Level: 1
Car: 2013 Chrysler 300c SRT
Member Number: 29598
New to the SRT's 2013 did have a 2006 but what do the exhaust butter flies do?
typan is offline   Reply With Quote Quick reply to this message
Old 07-01-2016, 08:25 PM   #56 (permalink)
12srt8392 if that's your problem then get yourself a system 1 oil filter been using them for years, very low oil pressure drop across the filter and a very high total area of filtering
Old 07-01-2016, 08:50 PM   #57 (permalink)
I'll try that filter bro. But I found that royal purple almost cured this issue. Thanks for the tip. You asking about exhaust mods? I left mine stock. MDS mode with aftermkt makes tons of droning. However I do extensive research and found that if I was to do it. I would go with corsa sport watch this video it's pretty good and will show you what is what
https://youtu.be/BcV5qmsdIxQ
Old 11-02-2016, 07:31 PM   #58 (permalink)
Points: 35, Level: 1 Points: 35, Level: 1 Points: 35, Level: 1
Activity: 23% Activity: 23% Activity: 23%
Car: 2013 Chrysler 300 SRT8
Member Number: 137145
Originally Posted by Rmehuron View Post
My 2013 had some odd faint grinding sounds at idle and low RPMs. Turned out to be the water pump going at only 11k miles. Easy to tell if you have a mechanics stethloscope. You can get one at harbor fright for rather cheap.
I've got what I believe is the the same thing going on my 2013 I just bought two months ago and unfortunately the warranty just expired. Did your's start leaking ever? Did you have it replaced under warranty? If not how much did they hit you to replace it?
dollarsignbill is offline   Reply With Quote Quick reply to this message
Old 11-02-2016, 07:32 PM   #59 (permalink)
Old 11-02-2016, 07:34 PM   #60 (permalink)
Water pump may be bad in mine as well. Sounds like a bearing noise
Insurance
Please select your insurance company (Optional)
Grinding noise after a rev!! HELP! pedrosarraga General Discussion on Issues / Trouble Shooting 3 12-04-2011 01:44 AM
Hissing noise in engine bay gotkarp Problems / Dealer Service 3 07-20-2011 10:54 AM
Grinding Noise on Startup wilkenms General Discussion on Issues / Trouble Shooting 3 06-05-2011 12:46 PM
Grinding Noise in Brakes vcval Australia / NZ Forum General Discussion 9 07-21-2008 05:55 AM
weird noise from engine bay when using A/C Casey General Discussion 2 05-13-2007 08:09 PM
» Premium Vendor Showcase
» Buyers Guide
Auto Loans Get Approved Today
Warranty Extended warranty packages
Vehicle History Get a vehicle history report in seconds!
Tires Find the right tires for your car
Insurance Get a free insurance quote
» Latest Chrysler News
» Recent Discussions
Chrysler 300C License...
09-01-2015 03:59 PM
Last post by Diode Dynamics
Today 12:20 PM
10 Replies, 5,260 Views
🇺🇸 Memorial Day Sale -...
Yesterday 12:38 PM
Last post by XenonDepot
Today 11:13 AM
1 Replies, 72 Views
Chrysler 300 HID...
01-27-2014 01:27 PM
Today 10:48 AM
17 Replies, 7,607 Views
Vendor Rules
Today 10:20 AM
Last post by Administrator
Today 10:20 AM
0 Replies, 22 Views
2017 Memorial Day Deals...
05-22-2017 09:15 AM
Last post by Discount Tire
Today 10:03 AM
2 Replies, 92 Views
300C Fog Light LED...
09-03-2014 09:09 AM
Today 09:14 AM
62 Replies, 10,689 Views
FS: Chrysler 300 "HALO"...
12-06-2013 02:48 PM
Today 09:11 AM
33 Replies, 13,220 Views
Chrysler 300C...
12-19-2014 10:14 AM
Today 08:58 AM
39 Replies, 6,554 Views
300c 3 litre diesel lack...
Today 12:39 AM
Last post by DGO
Today 07:59 AM
2 Replies, 41 Views
Uconnect Updates?
05-16-2017 07:48 PM
by BobF
Last post by ChryslerCares
Today 07:57 AM
21 Replies, 701 Views
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
