Engine bay grinding noise + vibration - Chrysler 300C Forum: 300C & SRT8 Forums
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > SRT8 Forums > 2nd Gen SRT8- Mechanical
Register Home Forum Active Topics (T) Gallery Garage Search Today's Posts Mark Forums Read
Like Tree2Likes
LinkBack Thread Tools
Old 12-12-2014, 09:32 AM   #1 (permalink)
Points: 654, Level: 1 Points: 654, Level: 1 Points: 654, Level: 1
Activity: 23% Activity: 23% Activity: 23%
Car: 2012 Chrysler 300 SRT8
Member Number: 90650
Hello everyone, I've been dealing with this annoying vibration/grinding noise that comes from my engine bay since I've purchased my 2012 SRT back in September. It only seems to happen when the engine is idling, both cold and hot. Raise the RPMs a little and the NVH goes away. The sound can be heard from inside the car, as well as felt throughout the entire car. It's not very consistent either. Has anyone else experianced this?
On a side note, does anyone's car make a sloshing sound on startup or when you rev it? Sounds like it's coming from behind the dashboard. Thanks!
SRT8_ANDREW is offline   Reply With Quote Quick reply to this message
Old 12-20-2014, 08:50 PM   #2 (permalink)
Points: 1,561, Level: 1 Points: 1,561, Level: 1 Points: 1,561, Level: 1
Member Number: 50713
My 2012 makes that sloshing noise sometimes, but I have no idea what is causing that noise.
SRTOcho is offline   Reply With Quote Quick reply to this message
Old 12-20-2014, 11:16 PM   #3 (permalink)
The sloshing noise is weird. I'm not as concerned about it as I am the engine vibration/grinding noise. The car's been doing it since new, and it has almost 12k miles on it now, so I know it's not a serious issue, but still would like to get it resolved as it is pretty annoying.
Old 03-01-2015, 09:09 AM   #4 (permalink)
Points: 5,490, Level: 1 Points: 5,490, Level: 1 Points: 5,490, Level: 1
Member Number: 40506
My 2012 has the exact same issue as you describe it. I'll also add the its somewhat inconsistent in its severity. Sometimes it is mild little hiccups other times it shakes the brake pedal and steering wheel. Of course the dealer says nothing is wrong. I have not agreed with them but to be fair ever time I've complained about it, its been on the mild side. My personal opinion is that its a marginal(hasn't failed but not completely right) fuel injector that is having difficulty metering fuel at the low duty cycles needed at idle, but once you raise the RPM enough it doesn't have an issue any more. The problem with diagnosing this is there is no way to isolate which injector(s) would be at fault. I suppose it could be a number of other things but I'd put money on it being a faulty injector. It's my biggest complaint about the car.
One other thing I notice is that the issue tends to be much worse after a car wash, when it rains, or is just damp/muggy out. After a prolonged dry spell its not as pronounced, although its still there. I might change my plugs this summer and cross my fingers that maybe its a bad plug. It's a lot more expensive swapping out all your injectors
R.
2012 300 SRT8, Ivory Tri-Coat,Black Chrome,H/K,SafetyTec,Leather Inter. Group
rocko107 is offline   Reply With Quote Quick reply to this message
Old 03-01-2015, 12:35 PM   #5 (permalink)
R.
I brought this issue to my dealer's attention once. Of course it was one of the days that the car decided to act normal. Annoying. I've learned to just live with the problem. If something goes bad, such as an injector, I'll replace it. If not, then whatever...
Old 05-17-2015, 05:17 AM   #6 (permalink)
Users Awaiting Email Confirmation
Points: 31,135, Level: 1 Points: 31,135, Level: 1 Points: 31,135, Level: 1
Member Number: 26764
are you sure it is not the exhaust butter fly rattle ??
Cheers
Geoff
geoff c is offline   Reply With Quote Quick reply to this message
Old 05-17-2015, 09:32 AM   #7 (permalink)
It is definitely not the exhaust butterfly flaps. This noise is definitely coming from the engine bay. I have my exhaust flaps spring loaded open anyway. Sounds great with the resonator delete!
Old 09-06-2015, 11:31 PM   #8 (permalink)
Points: 227, Level: 1 Points: 227, Level: 1 Points: 227, Level: 1
Activity: 34% Activity: 34% Activity: 34%
Car: 2012 Chrysler 300 SRT-8
Member Number: 107738
I believe it's the alternator. I was researching a noise from the engine bay on a Town and Country and ran across a video of an alternator on the old 3.8 ltr doing exactly what your symptom is (mine does it as well). Maybe try hooking it up to a battery tender over night, start it in the morning and once it's on normal idle see if it still does it. With no load on the electrical system if it goes away that should confirm it.
Paul S. Safford is offline   Reply With Quote Quick reply to this message
Old 09-10-2015, 12:00 PM   #9 (permalink)
Points: 1, Level: 1 Points: 1, Level: 1 Points: 1, Level: 1
Level up: 0% Level up: 0% Level up: 0%
Member Number: 114682
Hi guys
I have exactly the same problem on my 2011 Challenger SRT8 The grinding starts when I am down to about 600 rpm and can be felt throughout the car. I took it to the dealer, they checked on it on and off over 3 days w/o finding anything. Has anyone got any update regarding this?
I really love my new car (just traded in my Mustang GT for it) and still have a couple month's worth of warranty on it.
I would really appreciate a reply since I live in Switzerland and my car is a very rare beast over here.
Thanks, Philip (2011 green with envy)
philausb is offline   Reply With Quote Quick reply to this message
Old 09-22-2015, 11:07 AM   #10 (permalink)
Member Number: 115273
My 2013 had some odd faint grinding sounds at idle and low RPMs. Turned out to be the water pump going at only 11k miles. Easy to tell if you have a mechanics stethloscope. You can get one at harbor fright for rather cheap.
Paul S. Safford likes this.
Rmehuron is offline   Reply With Quote Quick reply to this message
Insurance
Please select your insurance company (Optional)
Grinding noise after a rev!! HELP! pedrosarraga General Discussion on Issues / Trouble Shooting 3 12-04-2011 02:44 AM
Hissing noise in engine bay gotkarp Problems / Dealer Service 3 07-20-2011 11:54 AM
Grinding Noise on Startup wilkenms General Discussion on Issues / Trouble Shooting 3 06-05-2011 01:46 PM
Grinding Noise in Brakes vcval Australia / NZ Forum General Discussion 9 07-21-2008 06:55 AM
weird noise from engine bay when using A/C Casey General Discussion 2 05-13-2007 09:09 PM
» Premium Vendor Showcase
» Buyers Guide
Auto Loans Get Approved Today
Warranty Extended warranty packages
Vehicle History Get a vehicle history report in seconds!
Tires Find the right tires for your car
Insurance Get a free insurance quote
» Latest Chrysler News
» Recent Discussions
Tid-Bits - Unrestricted
07-11-2014 03:28 AM
Last post by Piggy.
Today 01:56 PM
1 Replies, 105,696 Views
ESP/BAS will not go away
Today 01:49 PM
by bama1
Last post by bama1
Today 01:49 PM
0 Replies, 3 Views
99 psi oil pressure????
02-14-2017 11:53 AM
by bama1
Last post by bama1
Today 01:48 PM
4 Replies, 103 Views
DRL connections
Today 12:54 PM
by EeWee
Last post by EeWee
Today 12:54 PM
0 Replies, 13 Views
The Dreaded P0700 Error...
02-25-2017 03:04 PM
by razor
Last post by razor
Today 12:45 PM
7 Replies, 149 Views
Problem seeing threads...
Yesterday 09:12 AM
by OostinD
Last post by OostinD
Today 11:38 AM
6 Replies, 75 Views
Minimize Your Shipping...
Today 09:49 AM
Last post by RockAuto
Today 09:49 AM
0 Replies, 19 Views
Chrysler 300C...
12-19-2014 11:14 AM
Last post by Diode Dynamics
Today 09:10 AM
48 Replies, 5,879 Views
Front suspension part...
02-27-2017 11:24 AM
Last post by UK CHRYSLER 300C
Today 08:21 AM
9 Replies, 152 Views
chrysler 300 2.7 engine...
Today 08:06 AM
Last post by Class-Newbie
Today 08:06 AM
0 Replies, 19 Views
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
