Nice pics, badgx. Do you know if the swirl motor, alternator and oil filter are in similar positions to the OM642? I notice the oil filler cap has been relocated and I await with interest to see what problems the new engine might throw up. Hopefully, may have to wait some time for this to happen!
Interesting article. The alternator does appear to be similarly located to that in the Merc engine, although the oil filler cap is on the opposite side (good). However, the dipstick is in a similar position to the Merc and follows a tortuous route to the oil pan at the rear of the engine. The item that looks like an oil filter housing does appear to be accessible from above. Can't make out where the swirl motor might be, but hopefully in a more sensible location than the Merc's.
According to Wiki the A630 motor is generally reserved for Chrysler products with one exception -
"A 630 DOHC
A 3.0 L (2,987 cc or 182.3 cu in) double overhead camshaft V6, featuring four valves-per-cylinder and common-rail direct fuel injection. A variant complying with emission norms of North America market (NAFTA) is named L630 DOHC
A630 applications (EU):
2011 Jeep Grand Cherokee
power 241 PS (177 kW), torque 406 lb·ft (550 N m)
2012 Chrysler 300 /Lancia Thema (Europe)
power 190 PS (140 kW; 190 hp) @ 4000 rpm, torque 440 N·m (320 lb·ft) @ 1600-2800 rpm
power 239 PS (176 kW; 236 hp) @ 4000 rpm, torque 550 N·m (410 lb·ft) @ 1800-2800 rpm
2013 Maserati Ghibli III
power 275 PS (202 kW; 271 hp) @ 4000 rpm, torque 600 N·m (440 lb·ft) @ 2000 rpm
what i found more interesting is that on one of the 'posh' marques getting this motor (not the 300c!), theres a twin turbo version with greatly enhanced output
Exactly. I suspected someone would spot that. It would be interesting to know two things; what the mods are and, how reliable the engine is then? Mazas don't have a tremendous reputation over the past few years do they...
This new system sure does make you work hard though; previously I always had a tab with the European threads and could see at once what was happeneing. Now, with all this jiggery pokery, there are several places to look...
Hi From Texas!
I was wondering if someone with a 300c with the VM 3.0l diesel could share the required oil spec from the owner's manual. Does it list a Fiat spec?
I have a 2014 RAM 1500 pickup with the L630 VM engine and on the RAM1500diesel forum we have this ongoing debate about oil specs.
Hi my daughter has the 3.0 diesel, its got got 144k in a beautiful smooth powerful engine, quieter than my 3.0 Amarok and she has achieved approximately 8.0 liters per 100k,,,
Recent Alternator change$340.00 from Jeep Adelaide,,
Related Threads
Chrysler 300C & SRT8 Forums
1.4M posts
78.1K members
Since 2004
