Just installed HID Headlights - Question about results - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-08-2012, 12:45 AM   #11 (permalink)
Points: 52,208, Level: 1 Points: 52,208, Level: 1 Points: 52,208, Level: 1
Activity: 82% Activity: 82% Activity: 82%
Fisch's Avatar
Member Number: 22401
Originally Posted by Sharp300c View Post
Ok, so I took out the right bulb and re-seated it while it was lit so I could see the light spread on the garage door. It looks way better now. I'll post more pics tomorrow. There are still some dark areas towards the center-left so I'm thinking I need to re-seat the left bulb now. I didn't feel like taking out the intake again so I'll do it tomorrow and see.
Good to hear. Hopefully that was the issue - cause that's an easy fix!
Fisch is offline
Old 12-08-2012, 07:15 PM   #12 (permalink)
Points: 5,325, Level: 1 Points: 5,325, Level: 1 Points: 5,325, Level: 1
Car: 2011 Chrysler 300C
Member Number: 3420
Ok, so like I said, I re-seated the right bulb and that took care of most of the problems but there is a dark vertical line not being hit by light from the left bulb.
I attached 3 pics
1st pic is both bulbs as of now.....you can see the dark vertical line I'm talking about running parallel just to the left of the center line in my driveway.
2nd pic I covered the right headlight with a thick black towel so I could see only the left beam and the dark line is more visible so I'm guessing I need to take out the air filter compartment again to re-seat the left bulb
3rd pic is the right bulb only after I re-seated it. It looks way better. You cant see the driveway in the pic b/c the towel is bunched up on my hood but the dark line I'm concerned about wasn't there.
Anyway, besides the dark line coming from the left bulb does it look the way its suppose to as far as brightness and coverage? Re-seating the left bulb will fix the line right?
Just installed HID Headlights - Question about results-hid-both.jpg   Just installed HID Headlights - Question about results-hid-left.jpg   Just installed HID Headlights - Question about results-hid-right.jpg
Sharp300c is offline
Old 12-08-2012, 07:44 PM   #13 (permalink)
Points: 4,601, Level: 1 Points: 4,601, Level: 1 Points: 4,601, Level: 1
Joe79692's Avatar
Car: 2005 Chrysler 300c
Member Number: 38241
Yea the right side looks a lot better I know it's a hassle but take off the air box and take the ballast and error cancellor out of the housing and that should fix the dark line problem and yea the brightness and coverage looks like its suppose to
Joe79692 is offline
Old 12-09-2012, 02:12 AM   #14 (permalink)
Fisch's Avatar
Yeah - you're looking good brother.
Re-seat that left bulb and you should be good to go.
Fisch is offline
Old 12-09-2012, 10:01 PM   #15 (permalink)
Member Number: 3420
Re-Seated the left bulb tonight and the dark line is gone! Take a look at the results and tell me what you think.
I think it looks good but I"m concerned the lights might be aimed too high now.....either that or I'm not use to my lights reaching as far as they do now. Can anyone tell by the pics if they are too high and if so, anyone know how to fix?
Last question.....I didn't use the wiring harness that I ordered with the kit b/c I couldn't figure out how to install it so the HID's are being powered by my stock headlight plugs. Is that a problem. I think I recall reading something about that could screw up the wiring? Anyone know if thats true?
PS....I still have the ballast & error code eliminators inside the headlight housing.
Just installed HID Headlights - Question about results-hid-fixed-both.jpg   Just installed HID Headlights - Question about results-hid-outside-both.jpg
Old 12-09-2012, 11:12 PM   #16 (permalink)
Points: 9,891, Level: 1 Points: 9,891, Level: 1 Points: 9,891, Level: 1
blk300limited's Avatar
Member Number: 33977
Stock wiring is perfectly fine. I actually wouldn't even bother installing the wiring harness. I've had the same kit installed in my 300 for a few months now with no issues.
Also, I think what was causing your issue before might have been one of the wires from the kit was sticking out over the projector enough to cause that dark spot.
One more thing, and I speak from experience here, if your shutter(s) ever get(s) stuck then its because all the wires and ballast you shoved in there is keeping it from actuating.
blk300limited is offline
The Following User Says Thank You to blk300limited For This Useful Post:
Sharp300c (12-09-2012)
Old 12-10-2012, 12:47 AM   #17 (permalink)
Joe79692's Avatar
Looks nice man they light up the way they're suppose to nice job and yea u might have fix the ballast and error cancellor in the headlight
Joe79692 is offline
Old 12-10-2012, 09:00 AM   #18 (permalink)
Member Number: 3420
Thanks for the help and the feedback guys. This was my first MOD and now I think I've been bit by the bug.....I want to "black chrome" everything but don't know where to start.
Old 12-17-2012, 06:25 PM   #19 (permalink)
Points: 755, Level: 1 Points: 755, Level: 1 Points: 755, Level: 1
Car: 2012 Chrysler 300 Limited
Member Number: 38768
Thank you for posting these pictures! I've been wanting to know what the light output and pattern were like when putting an HID kit in the halogen projectors. It actually looks pretty decent.
A lot of halogen projectors don't play very nicely with HIDs... mostly because of the way the light is output. For the best results, it would actually be best to to put in some projectors designed for HID bulbs, like a D2S bulb. You would have a much more even light output and you'd especially notice a difference in the width of the beam.
BUT... as far as ease and cost goes, it looks like these halogen projectors play very nicely with HIDs. I'm glad you got it figured out!
It looks like you could use a little aiming... Easiest way is to find a flat wall and some flat ground. Drive up to the wall and mark the center of each projector on the wall. Then back the car up about 20 feet. The light cutoff should end up about 2 inches underneath where you marked on the wall.
pdyebrasil is offline
Old 12-17-2012, 08:58 PM   #20 (permalink)
Points: 1,446, Level: 1 Points: 1,446, Level: 1 Points: 1,446, Level: 1
Car: 2013 Chrysler 300S
Member Number: 41816
These do look good in the halogen projector's - I have a question, how do you know that the D2S bulbs will work?
Also, I have a 2013, and looking on DDM's website, I don't see what bulb I need. Nor do I see it listed on the Sylvania website.
SLUG11 is online now
Installed 2 new mods! Headlights/grille Jmurda Chrysler 300 Picture/Media Post 17 02-03-2011 07:24 AM
Installed new Halo Headlights And 6000K hid (pics) aliens_300touring Chrysler 300 Picture/Media Post 6 11-10-2007 07:22 AM
Installed Headlights and Shaved BLACKOUT Appearance General Discussion 12 01-22-2007 06:14 PM
Zoomers installed, here are my results fionn Intake & Exhaust 4 09-21-2005 10:07 PM
