Seat Belt Alarm - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
post #11 of 29 (permalink) Old 01-14-2013, 10:31 AM
Points: 21,348, Level: 1 Points: 21,348, Level: 1 Points: 21,348, Level: 1
Car: 2011 Chrysler 300C HEMI W/EVERY OPTION
Originally Posted by hainesm View Post
I spend a crap load of money on dry cleaning and I cannot stand showing up for work with a wrinkled dress shirt and tie, due to this I choose not to use my safety belt.
These work wonders for keeping your coat wrinkle free.
http://www.amazon.com/MAXSA-Innovations-20022-Butler-Hanger/dp/B000H0PB3O/ref=sr_1_2?ie=UTF8&qid=1358180338&sr=8-2&keywords=car+seat+coat+hanger
Unfortunately there is no way around wrinkles around the belt line and across the chest when using a seat belt.
As a suggestion because this is what I do, I wear my slacks and shoes and a Polo Shirt which still looks professional (In the event you get approached by business partners or colleagues just as you get out of your vehicle or while you are in route to your office) I bring my coat and pressed shirt in a garmet bag and I do a wardrobe change in my office so I maintain a pressed appearance.
To address your original question the chime goes away after a few minutes but your screen between the tach and speedopeter will not display what you have it set to, you will have to press the back button to get it to display, it will eventually go back to the unbuckled seatbelt message. Don't ask me how i know but occasionally i don't wear my seatbelt
Good Luck!
Patdow1 is offline
post #12 of 29 (permalink) Old 01-14-2013, 10:39 AM
Points: 14,061, Level: 1 Points: 14,061, Level: 1 Points: 14,061, Level: 1
toasteroven's Avatar
Car: 2012 Chrysler 300 SRT8
BTW its not a trolling statement when its my post. You could choose not to read it and I disagree with your statement. Your probably one of those liberals who thinks gun rights should be taken away.
Next time just a simple reply when that's all I was asking for would be appreciated.
You also could have said your specific-use statement instead of sounding really arrogant and self-righteous. By default, most of the enthusiast car forums don't persecute; we tend to be a warm and welcoming environment.
There's also been some discussion on 2nd gen belt chimes here. You might either have to short the seatbelt, or maybe find just a buckle, and plug it in for your 1.5 mile commute on the 30MPH road.
And no, I'm a Canadian who goes hunting. Isn't making assumptions fun?
"This car is 100% sh*ts and giggles."
2012 Chrysler 300 SRT8 // 6.4L Hemi // AFE Stage II CAI // Flowmaster Force II Cat-back // Diablo Tuned
2004 Dodge SRT-4// 2.4L Turbo // Sunrooof+Vipers // Mopar BOV
2005 PT Cruiser GT Convertible // 2.4L Turbo // Muffler Delete // Pillar-mount SRT Boost Gauge // Mopar BOV // Diablo Tuned
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
toasteroven is offline
post #13 of 29 (permalink) Old 01-14-2013, 10:55 AM Thread Starter
Points: 4,809, Level: 1 Points: 4,809, Level: 1 Points: 4,809, Level: 1
Car: 2013 Chrysler 300S AWD w/Safety Tech
MAXSA Innovations 20022 Car Butler Wood Hanger for Car : Amazon.com : Automotive
Good Luck!
Thanks that's helpful.
hainesm is offline
post #14 of 29 (permalink) Old 01-14-2013, 12:31 PM
Points: 5,943, Level: 1 Points: 5,943, Level: 1 Points: 5,943, Level: 1
Car: 2012 CHRYSLER 300S V8 RWD
thanks! I will look into that procedure to see if it works on gen2's.
It worked on mine.
rvaldez1 is offline
post #15 of 29 (permalink) Old 01-14-2013, 08:44 PM Thread Starter
I would like to confirm the gen1 process does work on a 2013. The seat belt icon does stay on and the lcd screen on the console shows a msg that says the seat belt is undone, you can back out of it but it keeps coming back. For the short time I will be using this I'm happy.
Thanks everyone
To confirm here is what I used:
(Do not step on the brake when pushing the start button in any steps below).
In step 1 below, try tapping the start button once to put the car in ACC mode.
At step 2, tap the button again to put the car in RUN (ON) mode.
Do step 3 as outlined.
In step 4, press the button again to turn the car OFF.
Enhanced Seatbelt Reminder Programming
The seatbelt indicator also includes a programmable enhanced seatbelt reminder or “beltminder” feature that is enabled when the vehicle is shipped from the factory. This beltminder feature provides extended and modified visual seatbelt indicator and audible chime warning responses to an unbuckled driver side front seat belt. The beltminder
feature may be disabled or enabled by the customer using the programming sequence that follows, or by the dealer using a diagnostic scan tool. The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully.
1. With the ignition switch in any position except On or Start, buckle the driver side front seat belt.
2. Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds).
3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
4. Turn the ignition switch to any position except On or Start to toggle the beltminder feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed.
________________________
2013 Chrysler 300S AWD in Bright White: (options) SafetyTec, Light Group, Panoramic Sunroof, Uconnect Navigation. MSRP, $41,520
hainesm is offline
post #16 of 29 (permalink) Old 01-15-2013, 09:17 AM
Thanks everyone
The reminder on the dash will illuminate everytime the car speed drops to zero, then goes up again.
rvaldez1 is offline
post #17 of 29 (permalink) Old 01-15-2013, 09:23 AM
Nice Find hainesm!
For Clarification purposes when you say "then goes up again" do you mean that the warning message disappears till you come to a complete stop, then disappears when the vehicle is in motion?
Patdow1 is offline
post #18 of 29 (permalink) Old 01-15-2013, 09:48 AM Thread Starter
Nice Find hainesm!
The warming msg is up all the time until you come to a complete stop, then it goes away. Once you start moving again the msg is back. :-(
Even if you "back" out of the msg its displays again in a minute or less (never timed it).
hainesm is offline
post #19 of 29 (permalink) Old 01-15-2013, 09:50 AM Thread Starter
you could also get one of these:
2pcs Carbon Fiber Car Safty Seat Belt Buckle Alarm Stopper Fit Mazda Dodge BMW | eBay
I'm going to purchase one, this will fix me up. I would really like to see the gas mileage display instead of the warning, it makes me drive slower.
hainesm is offline
post #20 of 29 (permalink) Old 01-16-2013, 06:06 PM
Points: 272, Level: 1 Points: 272, Level: 1 Points: 272, Level: 1
The seat belt reminder was the first "mod" that I did a few months back, but I get sick of the message between the tach and the speedo. I'll have to look into that clip that goes into the buckle.
Thr33Hundo is offline
Seat belt alarm! SilverCloud General Discussion on Issues / Trouble Shooting 13 08-10-2014 04:40 PM
Seat Belt Stuck!!! jtrejo Problems / Dealer Service 4 06-15-2012 07:06 AM
Seat Belt alarm is driving me crazy... OHSIXSRT8 Car Audio/Alarms/UConnect/Navigation 3 11-02-2008 01:41 PM
Why are the seat belt clasps different? 300justgotaC General Discussion 2 01-21-2006 01:16 AM
