How can I program TPMS on my car? - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 02-22-2013, 05:50 AM   #1 (permalink)
Points: 636, Level: 1 Points: 636, Level: 1 Points: 636, Level: 1
Car: 2012 chrysler 300c
Member Number: 38772
My car has tire pressure monitoring system and I changed my tires recently. I do believe the shop didn’t returned each wheel to its original place.
Do I need to reprogram the car to identify each wheel? If so, how can it be done.
bo3adsa is offline
Old 02-22-2013, 06:56 AM   #2 (permalink)
Points: 42,369, Level: 1 Points: 42,369, Level: 1 Points: 42,369, Level: 1
Activity: 96% Activity: 96% Activity: 96%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
just drive it...the system will sort itself out over several miles
Watching You Avoiding Me!
Kaiser Bill is offline
Old 02-22-2013, 07:18 AM   #3 (permalink)
Points: 28,895, Level: 1 Points: 28,895, Level: 1 Points: 28,895, Level: 1
MADDOG's Avatar
Member Number: 11602
You don't need to re-program it. The system was built to accommodate tire rotation. Just drive it.
Michael
MADDOG is online now
Old 02-22-2013, 10:54 AM   #4 (permalink)
thanks alot for the help
bo3adsa is offline
Old 02-22-2013, 04:11 PM   #5 (permalink)
Sorry to raise the issue again but I don’t think the car programmed itself.
I drove the car since yesterday and just now I was checking the tire pressure so I decided to test the car system by increasing the tire pressure and I noticed the car is identifying the wrong tire.
bo3adsa is offline
Old 02-22-2013, 04:23 PM   #6 (permalink)
the only other thing to do is go to a large tire outlet - they can force a reset of the car's sensors via the OBD socket, it'll only be a few $
Old 02-22-2013, 04:46 PM   #7 (permalink)
MADDOG's Avatar
hmmm...that's odd. That should NOT happen. The sensors in the wheel are not position specific as far as I know.
Old 02-22-2013, 05:15 PM   #8 (permalink)
ditto
Old 02-24-2013, 02:41 AM   #9 (permalink)
I would like to confirm that you were right.
The car just sorted itself and now it detect each tire.
bo3adsa is offline
Old 02-25-2013, 07:48 AM   #10 (permalink)
Points: 598, Level: 1 Points: 598, Level: 1 Points: 598, Level: 1
Car: 2012 Chrysler 300C
Member Number: 42503
I don't know and would like to know also............
IF
Each tire sensor has it's own address AND there is a discrete sensor receiver at each wheel then it might be possible for the system to learn itself when a sensor change/move is made.
However my guess is rotating tires will still give the signal but not at the correct tire position. There must be some method of each sensor knowing it's location.
I don't know how this system does this.
A tech engineer with info has my thanks for answering the questions. ,, I dont know.
vettdvr is offline
Program new key fob Brian Hammond General Discussion 4 01-02-2012 10:33 PM
Need program instructions to program 3rd key orandaberg European & Diesel Powered 300 Models 9 11-02-2010 04:59 AM
Need program instructions to program 3rd key orandaberg General Discussion 1 11-01-2010 11:21 AM
program 3rd key? orandaberg General Discussion 3 11-04-2009 07:02 PM
TPMS USA and TPMS Europe orandaberg European & Diesel Powered 300 Models 11 08-01-2009 09:09 AM
