Humidity sensor question
48K views 13 replies 10 participants last post by  IcarusLSC
#1 ·
Does anyone know where the humidity sensor is located on our vehicles? If so, how easy or not easy is it to change it? My air-recirculation button no longer works because of a faulty humidity sensor. Hoping to change it by myself if at all possible.
#3 · (Edited)
I claim it's that barrel-shaped thing under the starter button behind the little circular grill on the kick (or is it called a knee?) panel. Yes, it's fairly easy to get off, but IIRC there are 3 screws on the left hand side of the panel that have to come off first. The rest of the perimeter is held on with plastic clips. The barrel-shaped thing even has a dinky fan on it to ingest air from the cabin.
#4 ·
Found the sensor. What I had always thought was the sensor for the rain-sensing wipers; turns out that's actually the humidity sensor.
Took 5 minutes to change. The cover is held in via some plastic tabs, and then the sensor is held in with two tabs. Super easy. Beats the 150+ the dealer wanted to charge me to replace it. Tested the air re-circulation button and it works perfectly now.
#8 ·
Patent by Chrysler
Apparently the humidity sensor was supposed to be such a great idea by Chrysler that they got a patent for it. For Chrysler 300 it appears that it has only become a nightmare. The sensor was designed to measure the humidity in the car and give your comfort with causing wear and tear for your compressor. Who cares I do not want to pay the money it takes to get it changed. Apparently it is such a problem in South Florida, where I live, they are on back order. I tried to inquire whether or not there is a recall. The answer is no!
#8 ·
Humidity sensor
HUMIDITY SENSOR- Automatic Temperature Controls - SENSOR HUMIDITY
55111389AF
Located at top of windshield next to rear view mirror. Causes a.c. recirculation light to stay off and screen control for it to be disabled or grayed out
