Transmission fluid check - Chrysler 300C Forum: 300C & SRT8 Forums
 2Likes
  • 1 Post By Kaiser Bill
  • 1 Post By Trenton Johnson
post #1 of 8 (permalink) Old 03-15-2017, 08:54 AM Thread Starter
Points: 11,305, Level: 1 Points: 11,305, Level: 1 Points: 11,305, Level: 1
Activity: 36% Activity: 36% Activity: 36%
Alan1's Avatar
Car: 2013 Chysler 300S
Hey everyone,
I want to get something clear about checking the transmission fluid on the NAG1. I know we get the temp of the fluid by putting the car into drive. I want to know if we check the level of the fluid in park or drive.. The level of fluid in park is different than the level of fluid in drive. I've been having a whine whirrling noise when car is cold before the 2nd shift happens. Sounds like the tranny pump sucking air almost. Level is at 65mm at 165 degrees when checked in park. Level is at about 45mm when checked in drive at 165 degrees.
Any thoughts would be helpful
Alan1 is offline
post #2 of 8 (permalink) Old 03-15-2017, 01:50 PM
Administrator
Points: 102,853, Level: 1 Points: 102,853, Level: 1 Points: 102,853, Level: 1
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
measure in park. If youre getting a correct temperature reading, the level is correct. I'd be inclined to check the temperature via another method, as I've seen no info on how accurate the built-in evic temp reading is
Watching You Avoiding Me!
Kaiser Bill is offline
post #3 of 8 (permalink) Old 03-15-2017, 02:35 PM Thread Starter
Alan1's Avatar
Thats what i was wondering if the EVIC temp is actually correct. Do you have a tool you use to measure the temp?
Alan1 is offline
post #4 of 8 (permalink) Old 03-15-2017, 05:14 PM
Administrator
yes...I have a cheap electronic thermometer with a 4ft thermocouple off ebay that I shrink-tubed onto the dipstick
Crunkz1 likes this.
post #5 of 8 (permalink) Old 03-15-2017, 10:34 PM
Points: 679, Level: 1 Points: 679, Level: 1 Points: 679, Level: 1
Trenton Johnson's Avatar
Do not use EVIC temp that is coolant temp you need a scanner that reads transmission temp you can also get a B&M dipstick that has temp sensor built in.
Trenton Johnson is offline
post #6 of 8 (permalink) Old 03-20-2017, 05:25 AM
Points: 86,178, Level: 1 Points: 86,178, Level: 1 Points: 86,178, Level: 1
silver06hemic's Avatar
Car: 2006 Chrysler 300c
As mentioned above... Be sure that you are checking the transmission fluid temp not coolant temp... 2 very different temps!
Sent from my VS995 using Tapatalk
FRI'd Sidewinder, Novi 1200 S/C @ 7.5psi, Custom TR1235 A2A Intercooler, Tial BOV, Ported SRT Headers & Gutted Mid's, EGR, MDS & 02 Delete, Custom Catback w/Blastin Bobs SRT Pipes 4" tips, 170 Tstat, Big Bully Catchcan, 3.06 diff, 2800 stall, MTCM, Tranzformer, SRT Rad, SRT P/S Cooler, 5/15% Tint, SRT 20's, SRT Spoiler & Bumpers, Custom Stainless Grill, SE Coilovers.
AMP'd, FRI'd and Blown... 476rwhp/507rwtq @ 7.5psi
11.51@117.02mph 7.5psi/DR's
silver06hemic is offline
post #7 of 8 (permalink) Old 03-20-2017, 04:11 PM
Administrator
really? I can find B&M dipsticks, but none with a sensor. If you know different, can you put up a link please, as that sounds a good idea
I thought I solved the issues by fitting a B&M deep pan, which has a sensor hole in it. Now I get accurate temperatures, but the extra fluid means it never gets up to 80 degrees when stationary, and my dipstick is a 'hot/cold' one.....so now when I do it I have to take a tape measure to the dipstick tip, and measure for 75 degrees!
post #8 of 8 (permalink) Old 03-20-2017, 05:30 PM
Sorry the BM dipstick has the temp measurements on it BM 22302 and BM 80212
Crunkz1 likes this.
Transmission Shutter After Fluid Change Siciliano15 1st Gen SRT8-Specific Problems/Dealer Service 7 09-15-2016 10:54 PM
Transmission fluid warmup times Torian General Discussion on Issues / Trouble Shooting 0 01-29-2016 09:08 AM
transmission Fluid turns milky/strawberry likemefranky General Discussion on Issues / Trouble Shooting 6 01-10-2016 08:56 PM
NAG1 transmission fluid change info please Alan1 2nd Generation Chrysler 300 Discussion 1 09-29-2015 08:54 AM
Replace with
