Headlight Condensation - Page 16 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
LinkBack (14) Thread Tools Display Modes
Old 01-16-2013, 09:36 PM   #151 (permalink)
Points: 161, Level: 1 Points: 161, Level: 1 Points: 161, Level: 1
Car: 2012 Chrysler 300
Member Number: 41462
I just had both of my headlights replaced under warranty today..... Haven't seen any condensation as of yet... Will know more tomorrow.......
thrifty is offline
Old 01-24-2013, 09:42 AM   #152 (permalink)
Points: 8,282, Level: 1 Points: 8,282, Level: 1 Points: 8,282, Level: 1
Car: 2013 Chrysler 300S awd
Member Number: 2124
I just received a call from Chrysler group, and he wanted the name of the dealer I took my car to. He stated, he wanted to give them the new TSB. I guess we'll see.... Has anyone else heard this?
los24k is offline
Old 01-24-2013, 09:56 AM   #153 (permalink)
Points: 3,049, Level: 1 Points: 3,049, Level: 1 Points: 3,049, Level: 1
Car: 2013 Chrysler 300S AWD w/Safety Tech
Member Number: 42297
No call from Chrysler at this time, please keep us updated. I hope there really is a TSB for this.
________________________
2013 Chrysler 300S AWD in Bright White: (options) SafetyTec, Light Group, Panoramic Sunroof, Uconnect Navigation. MSRP, $41,520
hainesm is offline
Old 01-24-2013, 05:34 PM   #154 (permalink)
Mine are still fog free.......
thrifty is offline
Old 01-28-2013, 03:02 AM   #155 (permalink)
Points: 2,318, Level: 1 Points: 2,318, Level: 1 Points: 2,318, Level: 1
Car: 2013 Chrylser 300S
Member Number: 40374
Someone mentioned at TSB in another thread and, after a quick search, I couldn't find anything…
Anyone have something OFFICIAL they can point to..?
http://http://www.automd.com/recall-...&mm=300&y=2012
Sent from AutoGuide.com App
cinca is offline
Old 01-28-2013, 07:10 AM   #156 (permalink)
Points: 2,613, Level: 1 Points: 2,613, Level: 1 Points: 2,613, Level: 1
Torian's Avatar
Car: 2012 Chrysler 300S V6 8 SPD
Member Number: 36311
Go to your dealer and have them look through headlamp housing TSBs. There are two fixes available. One has to do with changing out dust covers, the other has to do with changing out the module that connects the bulb to the housing. Get the dust cover fix.
If your mechanic can't figure out that there is an existing TSB, they should be relieved. Unf-cking acceptable that even with such a widespread problem....every dealer and even Chrysler are playing the "I'm clueless" game when you bring this problem to them. I should get paid by Chrysler for training their mechanics how to do their jobs.
I'm not a dealer, so I have no friggin clue what the TSB # is. Under this thread, you will see that many of us have gotten the dust cover fix already. While this hasn't entirely fixed the fogging problem, it has diminished it. Get someone with half a brain behind one of their computers, and with a little time and effort, they will find it.
New headlamps will NOT fix the problem unless they include the updated dustcovers. I would not advise this course of action. I told my dealer to replace them, but find the reason they were fogging up, and fix that.
Torian is offline
Old 02-24-2013, 09:21 AM   #157 (permalink)
MMM
Points: 115, Level: 1 Points: 115, Level: 1 Points: 115, Level: 1
Car: 2012 Chrysler 300C
Member Number: 43418
had my 300C for just under a month now, will be a month as of coming wednesday. I only noticed the condensation when one of my lead lamps went dead (passanger side one) and there was a hell of a lot of condensation (covered the whole passanger side lamp except for a few spots) while the driver side was clear and no condensation. Will take it into dealership tomorrow. Noticed a small lip showing on the on the passanger side lamp assembly, its not flush with the body of the panel...the only things i can think of is a) dodgy manufacturing or b) the light blew and the gasses from the build up created enough pressure to pop it out of place????
MMM is offline
Old 02-24-2013, 01:10 PM   #158 (permalink)
Ac6
Points: 132, Level: 1 Points: 132, Level: 1 Points: 132, Level: 1
Car: 2013 Chrysler 300c
Member Number: 40959
Originally Posted by Ac6 View Post
Well its been over a month now. I have been through several rainy days and variations in temperature. Except for a slight fog once in a while that drys quickly, PROBLEM SOLVED!
I am not sure why you guys are struggling with the dealership on this issue. Has anyone tried what I and others have tried without success? its now been months including Storm Nemo and several rain storms and my problem is solved after 15 minutes of putting lube on the rubber o rings. someone else mentioned this and it really worked.
Ac6 is offline
Old 02-24-2013, 01:19 PM   #159 (permalink)
Points: 1,363, Level: 1 Points: 1,363, Level: 1 Points: 1,363, Level: 1
DjHEMI's Avatar
Car: 2009/2012 Chrysler 300C Hemi
Member Number: 35582
Ok are you talking the o-rings on the light bulb capsule plugs where they lock in place on the reflector assembly?
DjHEMI is offline
Old 02-24-2013, 02:10 PM   #160 (permalink)
Ac6
yes, I did both the large and small on each side. mine started off really wet inside with water droplets. I dried it with a blow dryer from the outside and then lubed the rubber o rings.
Its been good since. search my prior post for the lube I used. pool filter o ring lube.
Ac6 is offline
LinkBacks (?)
LinkBack to this Thread: http://www.300cforums.com/forums/2nd-generation-chrysler-300-discussion/95529-headlight-condensation.html
Posted By For Type Date
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 14 | BoardReader This thread Refback 04-24-2013 12:27 PM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 15 | BoardReader This thread Refback 03-25-2013 02:06 PM
Moisture in lights normal - Page 6 - Cherokee SRT8 Forum This thread Refback 03-15-2013 06:29 AM
Moisture in lights normal - Page 6 - Cherokee SRT8 Forum This thread Refback 03-11-2013 04:43 PM
Moisture in lights normal - Page 6 - Cherokee SRT8 Forum This thread Refback 03-11-2013 07:02 AM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 5 | BoardReader This thread Refback 02-27-2013 09:03 AM
Der Lancia Thema 3.0 CRD Executive ist da - Bericht + leider diverse Probleme :( - Seite 2 - Thema - Lancia-Forum.de This thread Refback 02-01-2013 12:48 AM
Der Lancia Thema 3.0 CRD Executive ist da - Bericht + leider diverse Probleme :( - Seite 2 This thread Refback 01-14-2013 02:27 AM
Der Lancia Thema 3.0 CRD Executive ist da - Bericht + leider diverse Probleme :( - Seite 2 This thread Refback 01-13-2013 05:35 AM
Der Lancia Thema 3.0 CRD Executive ist da - Bericht + leider diverse Probleme :( - Seite 2 This thread Refback 01-13-2013 05:31 AM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 4 | BoardReader This thread Refback 12-07-2012 01:03 AM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 7 | BoardReader This thread Refback 09-24-2012 08:13 PM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | Page 6 | BoardReader This thread Refback 09-24-2012 08:11 PM
Thread Headlight Condensation | Chrysler 300C Forum: 300C and SRT8 Forums | BoardReader This thread Refback 01-20-2012 01:55 PM
Fog lights are getting condensation in them JTSRT8 Lighting Discussion 2 11-22-2011 07:03 AM
Condensation in headlight housing stoneman European & Diesel Powered 300 Models 7 02-20-2011 09:09 AM
Headlight Condensation Repair Idea!? Tomi33 General Discussion on Issues / Trouble Shooting 3 01-29-2011 09:10 PM
HELP!!! Condensation in Headlights CSand78 Lighting Discussion 5 10-01-2009 12:38 AM
Headlight Condensation? 300C ON 24'S Problems / Dealer Service 7 03-05-2008 10:35 AM
