Has anyone changed interior lights to LED's in 2011-2012? - Chrysler 300C Forum: 300C & SRT8 Forums
 1Likes
post #1 of 77 (permalink) Old 04-04-2012, 01:35 PM Thread Starter
Points: 1,711, Level: 1 Points: 1,711, Level: 1 Points: 1,711, Level: 1
I am changing out my interior lights in my 2011 Limited and ran across the map lights from hell. They are not just bulbs. They are a single LED light on a circuit board attached to a ribbon cable (See picture below). I cannot find a replacement anywhere. Damn those yellow lights!
J-Rock is offline
post #2 of 77 (permalink) Old 04-04-2012, 05:01 PM
Elite Contributing Member
Points: 65,124, Level: 1 Points: 65,124, Level: 1 Points: 65,124, Level: 1
Bronek's Avatar
Send a message via MSN to Bronek
According to Sylvania, standard 578s should fit. Do you have a pic of the socket?
Sabrina - Srebrny Księżna
2005 300 Limited AWD ~ FE210 AWD? Maybe...
Click below for current mods + future plans
I do not believe in fire-breathing dragons, multi-coloured unicorns, good-willed people, omni-present creators, or other mythical creatures.
Bronek is offline
post #3 of 77 (permalink) Old 04-04-2012, 05:19 PM Thread Starter
The picture of the lights are attached. It has the black backround.
J-Rock is offline
post #4 of 77 (permalink) Old 04-04-2012, 06:03 PM
Bronek's Avatar
That's the lights. I want to see the socket.
Bronek is offline
post #5 of 77 (permalink) Old 04-04-2012, 07:38 PM Thread Starter
Sorry about that. One picture is of the whole circuit board that is in the overhead housing and the second shows the connector and where it connects to the circuit board.
ID:	40217   Click image for larger version
J-Rock is offline
post #6 of 77 (permalink) Old 04-05-2012, 06:57 PM
Bronek's Avatar
12 pin flex cable? Bloody hell... Best bet would be to pull off the current LEDs and just solder some new ones on yourself.
Bronek is offline
post #7 of 77 (permalink) Old 04-05-2012, 10:16 PM
Points: 934, Level: 1 Points: 934, Level: 1 Points: 934, Level: 1
X2 like Broneck said
Ksport is offline
post #8 of 77 (permalink) Old 04-12-2012, 03:08 PM
Points: 43,599, Level: 1 Points: 43,599, Level: 1 Points: 43,599, Level: 1
zach2011's Avatar
Car: 2015 Chrysler 200C V6
I'm currently looking into soldering new ones on, as all the other bulbs in my car are now LED and these do not match.
How did you go about removing the flex cable assembly like that??
zach2011 is offline
post #9 of 77 (permalink) Old 04-13-2012, 03:53 PM Thread Starter
Alright Zach, you need to be really sure you are ready for this mission. It was a pain in the ass. But, I will guide you through it because it really makes our cars look better.
1. Do not take off the clear plastic lenses. You dont have to.
2. There are NO screws holding on the lights assembly to the roof of the car. You have to get a flat head or a plastic prybar and work it in there to get the assembly off. There are some strong clips that hold that thing in there so dont be scared to pull hard.
3. Once off, there are 10 screws that hold the whole thing together. Take them off and you can break the whole assembly apart. Now be careful because there are 2 small pieces that you cannot lose. Its a small black wheel and a metal piece that make the sunglasses door open slowly. There is one large circuit board and then the ribbon cable with the LEDs attached. Thats the picture I have up top.
4. Now the hard part. I ordered single LED lights from superbrightleds.com for 2 bucks apiece. Get some extra ones just in case you mess up. I removed the 2 small circuit boards with the single LED light from the ribbon cable. I spliced the new LED to the ribbon cable by using a lighter and burning the ends off. You have to do this because you cant peel the insolation off because its real hard. Then slice and cover up good. I stuck the new LED light on the oppisite side of the old LED light circuit board. You have to use the same small circuit board because it hold the LED in place. I didnt mess with the accent light because you dont want your car lit up when your cruisen.
I know it might be hard to understand this but ask, and I can clarify. Also, the floor lights are the same, a circuit board with an LED. I spliced on the same new LED light and stuck it to the same circuit board and they worked fine. Ive attached some pictures for final product.
ID:	40329   Click image for larger version
J-Rock is offline
The Following 2 Users Say Thank You to J-Rock For This Useful Post:
DJKW (01-16-2015), duanebonney (01-09-2015)
post #10 of 77 (permalink) Old 04-13-2012, 05:35 PM
zach2011's Avatar
That looks great, and thanks for the really helpful post! I'll probably see if I can hire someone to do mine, there's no way I'd be able to do that!
zach2011 is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.300cforums.com/forums/2nd-generation-chrysler-300-discussion/97662-has-anyone-changed-interior-lights-leds-2011-2012-a.html
Posted By For Type Date
Chrysler 300C Forum: 300C & SRT8 Forums This thread Refback 01-20-2015 02:35 PM
2nd Generation Chrysler 300 Discussion on Chrysler 300C Forum: 300C and SRT8 Forums | BoardReader This thread Refback 10-22-2013 08:24 PM
2011/2012 Tail lights... Differences between standard/fogs/300C jaak 2nd Generation Chrysler 300 Discussion 7 12-10-2011 01:46 AM
Interior Led's CHEM300WV Lighting Discussion 4 06-19-2008 06:58 PM
Interior LED's.... Kensmash Appearance General Discussion 7 06-07-2007 04:03 PM
Replace with
