USB Input Issues - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 04-10-2012, 09:24 PM   #1 (permalink)
Points: 7,593, Level: 1 Points: 7,593, Level: 1 Points: 7,593, Level: 1
Car: 2011 Chrysler 300C HEMI
Member Number: 36494
USB Input Issues
Today I noticed that my head unit was no longer recognizing my iPod Nano so I swapped it out with a usb drive and neither work. Anybody else have any issues with their USB port?
Patdow1 is offline
Old 04-11-2012, 08:11 AM   #2 (permalink)
Points: 934, Level: 1 Points: 934, Level: 1 Points: 934, Level: 1
Member Number: 36446
At times I do have this issue both with 300 and Edge. Also on 300 it doesn't show the album art work. Edge it does.
Ksport is offline
Old 04-11-2012, 08:21 AM   #3 (permalink)
Points: 2,601, Level: 1 Points: 2,601, Level: 1 Points: 2,601, Level: 1
Car: 2012 Chrysler 300c AWD
Member Number: 227
I can play my Android only through bluetooth and it displays no info. Usb will charge but remains greyed out as player choice. Disappointing.
New Chrysler Guy is offline
Old 04-11-2012, 10:10 AM   #4 (permalink)
Mine won't even play. When you go to audio options it only displays bluetoogh and disk, doesn't even recognize usb, SD Date, Aux? Occasionally it ask to touch play on screen to unpause, and when I do absolutely nothing happens.
Patdow1 is offline
Old 04-11-2012, 01:35 PM   #5 (permalink)
Chrysler Customer Service Agent
Points: 1,509, Level: 1 Points: 1,509, Level: 1 Points: 1,509, Level: 1
ChryslerCares's Avatar
Car: 2013 Chrysler 300C
Member Number: 33558
FYI: New TSB Released:
TSB #08-018-12
SUBJECT:
Flash: Hands Free Module Customer Satisfaction Enhancements
OVERVIEW:
This Bulletin involves performing a USB service flash of the Hands Free Module (HFM).
SYMPTOM/CONDITION:
The customer satisfaction enhancements are included with this software release:
NOTE: After the HFM has been updated it will receive these enhancements.
· Reduced “Device Reading” wait time after connecting a device to the remote USB port.
· Call / Dial separation improves upon names being recognized as phone numbers.
· Improved sound quality during Bluetooth streaming.
· Increased iPod and iPhone compatibility.
· SMS messaging support via MAP protocol (not all phones support the MAP protocol).
· Added “None of These” and “Correction” to the phone book prompt menu for better handling of similar names.
· Previous button will return the song currently being played to the beginning of the track.
· AirPlay feature “Dock Connector” no longer needs to be manually selected on Apple devices. This will resolve the “No Audio” condition when the device is connected to the remote USB port and dock connector is not selected.
NOTE: USB mode resume will no longer 'resume' after ignition OFF
ChryslerCares is offline
Old 04-11-2012, 02:53 PM   #6 (permalink)
sox
Points: 38,932, Level: 1 Points: 38,932, Level: 1 Points: 38,932, Level: 1
sox's Avatar
Car: 2006 Chrysler 300c
Member Number: 12361
Send a message via MSN to sox Send a message via Skype™ to sox
TSB #08-018-12
SUBJECT:
OVERVIEW:
SYMPTOM/CONDITION:
This TSB are not for the 8.4 or 8.4n from the 2011 300!
http://www.wk2jeeps.com/tsb/tsb_wk2_0801812.pdf
@Patdow1
first remove the radiofuse for 15-20 min... then test again.
the only update are.
if you have the 8.4n/8.4:
https://qna.extra.chrysler.com/rhb/u...RadioUpdate.do
Uconnect | Support | Chrysler
Uconnect™ | Find the right Uconnect system for your Chrysler Vehicle
......Marco
Massively Over Powered And Respected
Sox`s World
Jeep WK HEMI / Chrysler 300C CRD
sox is offline
Old 04-11-2012, 08:48 PM   #7 (permalink)
USB worked this morning which was a relief. The problem is that I don't know when the next time this problem will rear it's ugly head. It seemed to have corrected itself after the car sat overnight. If it happens again I will try Sox suggestion if that fails I will take it in to the dealership. I'm still in for any insight to this issue.
Patdow1 is offline
Old 04-12-2012, 08:24 AM   #8 (permalink)
Once in a while youhave to unplug the USB from car and replug and it works, same case with me on any device I use and in any car.
Ksport is offline
Old 04-13-2012, 02:56 PM   #9 (permalink)
FYI:
The bulletin I posted above is not the one referenced in the link posted by Sox:
MODELS:
2011 (JC) Journey
2011 (LD) Charger
2011 (LX) 300
This bulletin applies to JC, LD, and LX vehicles built from December 20, 2010 (MDH 1220XX) to June 10, 2011 (MDH 0610XX) equipped with UCONNECT VOICE COMMAND W/BLUETOOTH (sales code RSP, RSQ for international).
Old 07-02-2012, 08:58 PM   #10 (permalink)
Points: 120, Level: 1 Points: 120, Level: 1 Points: 120, Level: 1
Car: 2012 Chrysler 300-SRT8
Member Number: 39096
USB Port Out - Among Other Things !!!
Folks, you are not alone. Recently took delivery of a 2012, 300, SRT-8, on 2/14/12. About a week ago, I lost my USB port that I was using with an old iPod (ver 1.3). Took it into the dealership that I bought the car from to address the failure of the iPod integration. While the vehicle was there, additional systems (adaptive cruise control(ACC) and the forward collision warning (FCW)) were knocked out by the clowns trying to address the USB port issue...
So it appears that not only can these dealers not deal with the USB problem effectively, they take out other systems in the process... Folks consider yourselves lucky...
Law2b is offline
Looking for some input. metal mulisha Performance General Discussion 2 04-10-2010 01:19 PM
Where is the aux input? doseddies Car Audio/Alarms/UConnect/Navigation 5 01-30-2009 06:12 AM
One Touch Power Window Issues And Rear Heated Seats Issues? steelblue08srt8 General Discussion 9 07-08-2007 06:52 AM
Sc Flashpaq issues (If you are having any issues) RON @ SUPERCHIPS Superchips 2 03-15-2006 01:52 PM
Input what input? AGGOST Car Audio/Alarms/UConnect/Navigation 0 04-12-2005 05:20 PM
