Does this problem happen to you guys? - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Power Train > 5.7 V8 Engines
Old 10-09-2012, 09:16 PM   #1 (permalink)
Points: 2,820, Level: 1 Points: 2,820, Level: 1 Points: 2,820, Level: 1
Bluebandit's Avatar
Member Number: 33622
So a bit ago I went to fill her up with some 91 like I always have fow awhile now. I filled it up and as I was driving away the car wanted to die. My rpms and oil pressure dropped. I pulled over because it eventually died. It wouldnt turn on only a couple times did it turn on but died right after that. Eventually I got it to work normal after a few hard revs. This is the second time its happened. Anybody know what the H*** is wrong?
Bluebandit is online now
Old 10-09-2012, 09:39 PM   #2 (permalink)
Points: 29,983, Level: 1 Points: 29,983, Level: 1 Points: 29,983, Level: 1
yamabob's Avatar
Car: 2007 chrysler 300c
Member Number: 14746
Sounds like car was overfilled and some got into the evap can. Only fill till pump click off. Don't try to "top off"
AFE, Corsa Catback, Predator,HHP High Flow Cats,JBA Shorties,HHP Stage1 cam,HHP CMR tune,6000k HID low & fogs,AAC 6k halos,Original American Illuminated Rear wing 486 rwhp,475 rwtq,20" chrome SRT rep's,rear SRT trunk spoiler,SRT front lip. R1 slotted/crossed drilled rotors, Luxer interior LED's, Grip grill,22Elite console cover,MGP caliper covers. Spyder Tails,ATI Procharger,PLX Multi-gauge AFR Wideband and Vacuum/Boost,Fore Industries Fuel Rails,Paramount Stage 2 VB,MTCM,Chally hood,Getrag LSD
yamabob is offline
Old 10-09-2012, 09:49 PM   #3 (permalink)
Bluebandit's Avatar
What is the evap can? I didnt top it off, the pump stopped by itself because I knew if I top off this problem would happen. I didnt think it would happen it I filled till the pump clicked.
Old 10-09-2012, 09:57 PM   #4 (permalink)
yamabob's Avatar
A cannister that collects vapors during filling. These are normally put back into play by way of the purge solenoid. It can happen just during the filling process. Another thing could have been a loos gas cap. DO you have any codes?
yamabob is offline
Old 10-10-2012, 07:41 AM   #5 (permalink)
Bluebandit's Avatar
Thanks allot for the info. I dont think It had any codes.
Old 10-11-2012, 01:20 PM   #6 (permalink)
Points: 28,856, Level: 1 Points: 28,856, Level: 1 Points: 28,856, Level: 1
MADDOG's Avatar
Member Number: 11602
Also, make sure that your gas cap fully seals (twist until it clicks) and you might be needing to replace it if it doesn't fully seal.
A lot of times this issue comes up after a fuel stop because the cap isn't tight.
Michael
MADDOG is offline
Old 10-11-2012, 09:37 PM   #7 (permalink)
Bluebandit's Avatar
Thanks guys. My gas cap is fine it clicks shut all the time.
Old 10-12-2012, 12:22 PM   #8 (permalink)
MADDOG's Avatar
Clicking is one thing and it will click even though the seal has failed.
MADDOG is offline
Old 01-23-2013, 05:14 PM   #9 (permalink)
Points: 598, Level: 1 Points: 598, Level: 1 Points: 598, Level: 1
Car: 2012 Chrysler 300C
Member Number: 42503
Make sure you didn' t get bad gas trash and water will have the same effect.
The car is designed to run 89,, no real advantage of 91 but you should have no issues if you want to use 91. Sounds like you should buy your gas somewhere else.
vettdvr is offline
anybody had this happen? doby European & Diesel Powered 300 Models 43 07-29-2011 06:13 PM
What will happen if there is to much oil??? kd300c General Discussion 24 08-11-2009 04:41 AM
what would happen if.... wanna300 General Discussion 5 11-17-2007 01:02 PM
It just had to happen didn't it! BIG SMOOTH General Discussion 15 04-16-2007 08:03 PM
