I took some pictures of the stock bulbs and the bulbs that came with the kit. I am only showing the ones that won't fit or work.
First set is the puddle lights, you can see clearly that the stock are a rigid loop festoon type bulb and the kit is a wedge.
Next is the trunk light, you can see that the stock bulb and the kit bulb is a festoon type, just won't work.
Last off are the reverse lights. The just won't fit, they are too small, nothing to attach or wedge to. showed the socket trying to show the difference in bulb and socket size.
YOu guys should check to see what bulbs you have too.
Any feedback?????
Smoove do you have the same bulbs as me????
