Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Advanced Automotive Concepts
Old 04-21-2009, 12:22 PM   #1 (permalink)
Headlight Guru
Points: 14,303, Level: 1 Points: 14,303, Level: 1 Points: 14,303, Level: 1
AACstyle.com's Avatar
Car: www. AACstyle .com
Member Number: 3553
Trader Rating: (7)
Night Raider LED Scanner Bars- Only $49!
Currently have Green, Amber, and White In Stock.
The Night Raider LED Scanner can be used as an addition to your security system, a scanning third brake light, or a standalone scanner. It is 15 inches long and features 30 micro-processor controlled LEDs for fluid scanning motion you have to see to believe!
Use it as a scanning security system status indicator on your dashboard or in your grill, or use it in your rear window as a high-visibility third brake light. You can mount it in your grill, under seats, or anywhere else for a head-turning scanning affect! No security system is required, but it includes a signal wire that can be hooked up to scan with your alarm.
Rated for Interior or Exterior Use. Simple 2-wire Hook-up. Installation & mounting hardware and instructions included.
Available in 6 Colors - Lifetime Warranty.
Compare at $80!
Night Raider LED Scanner PlasmaGlow
Only $49 from AAC!
-Justin
"Now serving all LX platforms!"
1(800)407-5776
www.AACstyle.com
No PM, email: justin@aacstyle.com
AACstyle.com is offline
