Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Regional Forums > Australia Forum
Old 07-30-2006, 05:52 AM   #11 (permalink)
Points: 22,171, Level: 1 Points: 22,171, Level: 1 Points: 22,171, Level: 1
MY300's Avatar
Member Number: 5780
Originally Posted by snoopdolks
Ahhhhh...you'll find the setting for that in the Personal Settings section on the EVIC. Just scroll thru there and you'll find something about "??? the seat on exit"......I just can't remember exactly what is says. Sean
hi Sean yes that is Automatically move seat back on exit ...which is On...frank
Black 2006 300C, 22" DUB Shorline,Corsa Cat Back,
Airhammer Polished, Kingsprings 30mm, Mopar Grill
LED Smoked Tails, SRT8 Boot Lid Spoiler,Aluminium 300C Pedals, Window Tint:Back Limo,Front 30%,Pic Mods by HAZMAN
MY300 is offline
Old 07-30-2006, 09:48 AM   #12 (permalink)
Points: 2,832, Level: 1 Points: 2,832, Level: 1 Points: 2,832, Level: 1
HEM-300's Avatar
Car: 2006 chrysler 300c
Member Number: 6884
G'day. Just a guess, but I reckon "be4st" is in need of a bit of key programming too. I had some issues before properly re-programming and matching both keys with seat adjustment... Ummm....just trying to find out how that was done...found it.
Memory seats.. got two issues!
From the above thread, try this sequence after you've got everything set up and saved in the memory profiles (buttons on drivers door).
Remote keyless entry can be programmed to return driver's seat, side mirror, etc.
1) Remove key from ignition with all four doors closed.
2) Select desired memory profile 1 or 2
3) Press and release set button and press and release button 1 or 2
4) Press and release the Lock button on the transmitter within 10 seconds.
Hope that helps you!
Sean.
Thanks Snoop
That was the issue, the mirrors where set at that angle, for the main key now has been changed all okay, thanks again !
HEM-300 is offline
