Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Regional Forums > Australia Forum
Old 05-11-2007, 02:14 AM   #41 (permalink)
The Gunslinger's Avatar
Car: 2005 Citroen C4 VTS
Member Number: 11981
Cheers. I'm now looking at getting an AIRHAMMER, simply because anyone who owns one has nothing but good things to say about it. Plus the boost of fifteen extra hp at the wheels is a SWEET bolt-on power upgrade.
Hmmmm, those performance 'module' add-ons sound a bit dodgy, I just looked into the Jet Performance modules, and I've suddenly lost my urge to purchase one.
I would like to get the 300C dyno-tuned when I put these parts in, however if that requires me to purchase an aftermarket 'tunable' ECU (and I've heard of this being the case for other cars), forget it.
Essentially, I'd like an ECU map that makes better use of the CAI, exhaust, Premium fuel and such, instead of just the outright benefits these parts give. Having said that, I don't intend to squeeze the upteempth ounce of power I can get out of the HEMI, and I'll probably ask the dyno folks to crank it back a notch from max to make life easier on the engine.
So my question is, can the stock ECU be tuned, and am I better off taking it to a dyno joint and have them tune it for me? I know there are flash modules and 'tune-it-yourself' kits out there, but I don't want to be mucking around too much with the engine tuning. If I can have someone else do it simply and better than I can, I'll go for it.
The Gunslinger is offline
Old 05-11-2007, 04:16 AM   #42 (permalink)
MrVelvet's Avatar
Car: 2006 Chryler 300C SRT8
Member Number: 5271
Send a message via MSN to MrVelvet
We've just finished our development work (thus far) so it's time for an update.
Things we have learnt:
1. The XFI cams may well be a good thing on a 300C but they aren't much good for an SRT8 although (in fairness) it was only the middle of the three available grinds.
2. The stock intake system on the SRT8 is exceptionally good for not only air flow but also (and more importantly) for the speed of the air flow in the plenum. It would probably make a good addition to a 300C 5.7 as a stock looking alternative to some of the aftermarket kit.
3. Underbonnet temperatures are terrible on even a mildy warm day. We'll be investigating this one a little further to see what can be done.
4. We desperately need a working ECU tuner - not that most people here don't already know this!
5. Hi flow cats are worth about 5rwkw which is a handy gain.
6. The more rubber at the rear end - the better. We identified early on that traction was going to be a big issue at the strip and the 275/40's have helped that markedly. As a side note the wet weather performance of the Kumho's is roughly akin to pouring oil on the tyres but they are great in the dry.
Dyno is now showing a slightly improved 255rwkw and the 26th will see this tested at HPR to see what we have actually gained.
I'll post the results then.
Cheers
Russ
2006 300C SRT-8 / 2001 Mustang Cobra
Mods:
E&G Grille
3M Tint
Ultimate Pedals
22elite console cover
Comp Cams 268 XFI Cam
275/40 all round
Mopar CAI
Predator/RDP tune
Billet shift knob
... on the way 426 stroker kit
I want to die in my sleep like my grandfather ...not screaming and yelling like the passengers in his car"
MrVelvet is offline
Old 05-27-2007, 04:57 AM   #43 (permalink)
MrVelvet's Avatar
Member Number: 5271
The bitumen dyno returned a solid half second improvement with a best of 13.4183 @ 108.62 mph. The traces look much better from a traction viewpoint thanks to the extra rubber on the rear.
60' times still need some work with a 2.118 and a 2.202 respectively.
Cheers
Russ
300c-modifications-advice-potential-260507a.jpg  300c-modifications-advice-potential-260507b.jpg  300c-modifications-advice-potential-260507c.jpg  300c-modifications-advice-potential-260507d.jpg
Mods:
E&G Grille
3M Tint
Ultimate Pedals
275/40 all round
Mopar CAI
Predator/RDP tune
Billet shift knob
MrVelvet is offline
Old 05-27-2007, 05:46 AM   #44 (permalink)
MY300's Avatar
Member Number: 5780
Hi all in regards to Ecu Tuner -Star scan I think whats the go in getting one
I have read that some guys have them in the US
I know Superchips are availlable and they do their there thing well.Is there an advantage in having what DC have??? just curious and deciding whether the Superchips is worth while...
Russ you were interested in the Airhammer before have you knocked it on the head from your resuts you have been getting
I would like to say i am on the same page as you Gunslinger just to get the optimised fine tuning and gear shifting out of the Hemi 300C
Frank
Black 2006 300C, 22" DUB Shorline,Corsa Cat Back,
Airhammer Polished, Kingsprings 30mm, Mopar Grill
LED Smoked Tails, SRT8 Boot Lid Spoiler,Aluminium 300C Pedals, Window Tint:Back Limo,Front 30%,Pic Mods by HAZMAN
MY300 is offline
Old 05-27-2007, 04:46 PM   #45 (permalink)
Australia Forum Moderator
Hemi57's Avatar
Member Number: 299
Frank, the Starscan is the DC diagnostic tool which is not freely available to the consumer.
I think you are referring to the SuperChips Flashpak. You could hook up with snoopdolks and get him to upload the Flashpak tune to see how it goes on your ride. Of course you cannot keep the tune as the systems requires an off load of your factory setting and then upload of your selected Flashpak tune, but it would still give you the opportunity to try before you buy.
John
SRT8 Mods:
E&G Heavy Mesh Grille
Tint
Ultimate Racing Pedals
C-TEKs
Shaved side moldings
Mopar CAI
"Fatt" Exhaust Tips
Hemi57 is offline
Old 05-28-2007, 03:22 AM   #46 (permalink)
MY300's Avatar
Member Number: 5780
Thanks John I do understand what the Flashpak can do I have been in Bezitas car and its awesome.
I was more of thinking my Mechanic being able to access the Diagnostics and giveing it a tweak...Just a thought. I like to experiment ..
Flashpac would do all I would need and more I am sure...Cheers frank
MY300 is offline
Old 05-28-2007, 06:21 AM   #47 (permalink)
MrVelvet's Avatar
Member Number: 5271
Frank
Hi Frank
No, I am still interested in going there along with a locally produced exhaust and a couple of other ideas we've floated around.
Cheers
Russ
Mods:
E&G Grille
3M Tint
Ultimate Pedals
275/40 all round
Mopar CAI
Predator/RDP tune
Billet shift knob
MrVelvet is offline
