Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Regional Forums > Australia Forum
Old 10-04-2009, 08:13 PM   #1 (permalink)
Points: 2,675, Level: 1 Points: 2,675, Level: 1 Points: 2,675, Level: 1
Cruzmat's Avatar
Car: 2007 Chrysler 300C SRT-8
Member Number: 8234
Dust Storm Aftermath
Hey guys, just thought i'ld mention the huge jump in horse power after cleaning the K&N air filter in the Chrysler post dust storm.
Amazing the difference once the thing can breathe!!!
That's all I got.
Cheers,
Andy.
2007 Black SRT 8
Mods
Dual 3" Cat backs
Tint
Posi-quite low dusting pads
Stainless brake lines
O.T.R.C.A.I.
Future Mods
22" Black Magic Rims
Custom Grill
Cruzmat is offline
Old 10-05-2009, 02:34 AM   #2 (permalink)
Points: 12,033, Level: 1 Points: 12,033, Level: 1 Points: 12,033, Level: 1
wog boy's Avatar
Car: 2006 . 300c, rolling on 24's
Member Number: 5242
I send you mine to clean too, thanks Andy
**My Youtube Video**
wog boy is online now
Old 10-05-2009, 05:59 AM   #3 (permalink)
Points: 2,868, Level: 1 Points: 2,868, Level: 1 Points: 2,868, Level: 1
Car: 2007 Chrysler 300c v6
Member Number: 18653
ive got the AFE stage 2, the non oil one. how do you clean it? just take it off and run it under a hose?
M@ndrake is offline
Old 10-06-2009, 12:09 AM   #4 (permalink)
Australia Forum Moderator
Points: 18,080, Level: 1 Points: 18,080, Level: 1 Points: 18,080, Level: 1
Hemi57's Avatar
Car: 2006 (Australian Spec) Chrysler 300C 2006 SRT8 (Aussie spec)
Member Number: 299
"the non oil one" ?
I doubt that that is the right literal intent of the statement if provided by the manufacturer or supplier. The foam or cone type filters need cleaning and oiling with appropriate products. I use the K&N kit which has aerosol cleaner and aerosol oil pressure cans.
Without some sort of oiling agent there is little protection from dust and contaminants getting into the motor.
John
SRT8 Mods:
E&G Heavy Mesh Grille
Tint
Ultimate Racing Pedals
C-TEKs
Shaved side moldings
Mopar CAI
"Fatt" Exhaust Tips
Hemi57 is offline
Old 10-06-2009, 05:15 AM   #5 (permalink)
Points: 8,263, Level: 1 Points: 8,263, Level: 1 Points: 8,263, Level: 1
Pusbum's Avatar
Member Number: 6391
Send a message via MSN to Pusbum Send a message via Skype™ to Pusbum
Originally Posted by Hemi57 View Post
"the non oil one" ?
That could be correct if he has a synthetic filter.....like I do. Not that I know anything about the AFE but........
I ordered the K&N kit thinking that is what I needed but when i finally went to do it I found I was wrong. On the end of the filter it actually says "Do Not Oil". I have done some research and I have an AEM DryFlow. All the doco says not to oil it as it will degrade the filter. Appartently I am supposed to use the AEM cleaning solution and warm water. Apparently quicker to clean than the other style filter but harder to find the solution :-)
He who dies with the most toys wins!
Pusbum is offline
Old 10-06-2009, 06:54 AM   #6 (permalink)
Points: 1,726, Level: 1 Points: 1,726, Level: 1 Points: 1,726, Level: 1
stubbers's Avatar
Car: 2007 Chrysler SRT8 Touring
Member Number: 18081
I've got a Mopar CAI and it also has a "Do not oil" warning on the filter cone.. needs a clean though after the dust storms.. any thoughts on the best method? Tried blowing with air and worked to some degree.. but that red dust is a biatch as it has created a sticky residue.
--------Stubbers-----------
Tis better to seek forgiveness...
Than ask permission
stubbers is offline
Old 10-07-2009, 01:16 AM   #7 (permalink)
Points: 4,133, Level: 1 Points: 4,133, Level: 1 Points: 4,133, Level: 1
SRT4ME's Avatar
Car: 2006 Chrysler 300C-SRT8 Tourer
Member Number: 7074
Hmmm, filters, I know a bit about that, been selling 'em for > 20 yrs now.
Anyway (yawn) filters use a number of mechanisms to remove the crap from the air supply.
Oil wetted filters use a mechanism called inertial impaction to remove the fine material & the oil is used to retain the collected debris. They are actually quite a coarse filter (to maximise air flow & reduce pressure losses). To operate effectively then they need cleaning & re-oiling regularly. Once the oil is all 'used up' & covered in dirt then the filter will revert to its non oiled state and the finer material will then penetrate the filter (as it won't be retained by the sticky oil).
The dry type filter work by a mechanism called direct interception (as do the oiled filters once the oil has lost it's stickyness!, but the oiled filter being a much coarser matrix, will allow more & larger crap through), to operate in this mode the filter is so fine that the crap is retained both on the surface and in the internal structure of the filter. They can be cleaned, but only of loosely retained material, anything that is well stuck in the filter won't be got out. Ideally they should also be cleaned regularly, if not the crap builds up internally & can't then be removed at all. Eventually the dry type WILL need totally replacing (like every service to be on the safe side).
Oiled Type filters
Advantage, good performance, low pressure drop (more oomph).
Disadvantage, needs cleaning & oiling regularly otherwise too much crap gets into the engine & wears out the upstream bits (valves, cylinder bores, rings etc.)
Dry type
Advantage, effective removal of fine material even when 'blocked', in fact this type of filter can improve, as regards filtration efficiency, as they block, but air flow is degraded so you shouldn't let it get this far.
Disadvantage, cannot be reliably & effectively cleaned unless this is done when they are only very partially blocked. Will block & starve the engine of air = reduced performance.
You pays yer money & you takes your choice.
The Liver is Evil & must be Punished
Stealth Blue SRT8 Tourer
Mods to date-
Heavy tint
Predatorized
Smoked rear & side marker lense
Underhood Stainless Steel mirror
Body colour painted grill, B pillars, rear door sails & door trims
De-chromed (98%)
De-moulded
H.I.D. mainbeams
CAI.
Planned mods-
Stealth bulbs
Alloy pedals
Wheels
SRT4ME is offline
Old 10-08-2009, 05:17 AM   #8 (permalink)
Points: 3,861, Level: 1 Points: 3,861, Level: 1 Points: 3,861, Level: 1
slang's Avatar
Car: 2007 Chrysler SRT8 (black)
Member Number: 14609
Send a message via MSN to slang
Great explanation....much appreciated.
2007 Chrysler 300C SRT8, Brilliant Black
Mods to date:
Bentley-style grille, 25% tint, 22" Zenetti Masquerades, Corsa catback exhaust, smoked LED tails, SRT22S plates, more to come
slang is offline
Old 10-08-2009, 05:46 AM   #9 (permalink)
yeah, thanks mate!
M@ndrake is offline
Old 10-08-2009, 05:09 PM   #10 (permalink)
Pusbum's Avatar
Member Number: 6391
Thanks for the info......so in summary I am heading out to buy a new filter :-)
Pusbum is offline
