What motor oil to use?? - Chrysler 300C Forum: 300C & SRT8 Forums
Australia / NZ Forum General Discussion
post #1 of 9 (permalink) Old 08-08-2010, 10:06 PM Thread Starter
Points: 46,448, Level: 1 Points: 46,448, Level: 1 Points: 46,448, Level: 1
bozo4's Avatar
Car: 06 chrysler 300c
I am about to do the first service since my car came out of warrenty.. Want to change the oil type.. I have been looking at Mobil 1 and Royal Purple.. Are these the best? If so What weight of these work best? Thankfull for any advice i can get.............
bozo4 is offline
post #2 of 9 (permalink) Old 08-09-2010, 02:13 AM
sox
Points: 93,024, Level: 1 Points: 93,024, Level: 1 Points: 93,024, Level: 1
sox's Avatar
Car: 2005/2009/2015 Jeep/Jeep/Dodge GC Hemi / Patriot / Charger SRT
hi
Jeep Grand Cherokee WK - Maintenance information and schedules
CRD
Use only SAE 5W-30 Synthetic Engine Oil that meets Chrysler Material Standard MS-11106 or Mercedes Benz MB 229.51 and ACEA C3 qualified engine oils
5.7 Hemi
5W-20
(Note: It is important to use only 5W-20 oil for proper operation of the Multiple Displacement System. Use of other weight oils will affect the on/off timing window of the MDS system and may also result in unbalanced engine wear).
SRT
0W-40 or 5W-40
(For best performance and maximum protection under all types of operating conditions, the manufacturer only recommends full synthetic engine oils that meet the American Petroleum Institute (API) categories of SM or SM/CF, and meet the requirements of Chrysler Material Standard MS-10725. The manufacturer recommends the use of a full synthetic engine oil, such as Pennzoil Platinum® European Formula SAE 5W-40 or equivalent.)
*Note for the 6.1L engine: The oil change specification calls for 7 quarts of oil when changing the oil and filter. Some owners have reported a slight to moderate overfill reading on the dipstick when installing a full 7 quarts. The 6.1L engine drains the oil slower than other engines. Drain the old warmed oil for at least 20 minutes to get as much out as possible. We suggest adding around 6-1/2 quarts, run the engine for a few minutes, shut it down and let sit for awhile, then fill as neccessary to bring the reading to the safe area on the dipstick. The top of the safe area represent the proper "full" level. Note that adding a full 7 quarts (with filter change) will never overfill the engine to such an extent that any oil foaming or harm will result, even if the level is beyond the "safe" reading on the dipstick.
All Uconnect Software
www.mydrive.ch
username: mygig@soxag
Password: gasolio
..............Mopar or no Car!
sox is online now
post #3 of 9 (permalink) Old 08-09-2010, 11:38 PM Thread Starter
bozo4's Avatar
If I dont use mds on my 5.7 at all can I use 5w30??
bozo4 is offline
post #4 of 9 (permalink) Old 08-10-2010, 03:22 AM
Points: 7,240, Level: 1 Points: 7,240, Level: 1 Points: 7,240, Level: 1
Jaffa's Avatar
Car: 2006 300C V8 HEMI Silver Home at last
YES WE CAN!
with mds or without mds 5W-30 is fine.
The 2006 Owners manual page 129 says so. You will need 6.6 litres.
I suspect back in 2006 there was practically no alternatives for 5W-20 oil in AUS.
I have used Castrol Edge Sport 5W-30 on our 5.7 hemi 300C since new and change the oil & oil filter every 6 months as recommended.
No issues with mds operation at all. She still purrrs like new
Cheers
Jaffa is offline
post #5 of 9 (permalink) Old 08-10-2010, 12:34 PM
sox
sox's Avatar
Originally Posted by Jaffa View Post
YES WE CAN!
Cheers
rigth no problem!!
have you deactivated the mds for mod...?
sox is online now
post #6 of 9 (permalink) Old 08-10-2010, 03:03 PM Thread Starter
bozo4's Avatar
Yeah, With my supercharger I had to do torque modification to the transmission so the mds didnt work smoothly and was annoying.. So I just turned it off.. So much better without it in my application. Ordered 5w20 anyway.. Found a supplier that can supply me 5w20 cheaper than my local supplier can supply 5w30.. 5w20 is a better oil...
bozo4 is offline
post #7 of 9 (permalink) Old 08-10-2010, 06:19 PM
Jaffa's Avatar
Yeah, With my supercharger ....the mds didnt work smoothly and was annoying.. So I just turned it off.. .. 5w20 is a better oil.???
As SOX suggested 0W-40 or 5W-40 would be better for your no mds - high power - high load - high temp application
Jaffa is offline
post #8 of 9 (permalink) Old 08-22-2010, 11:05 AM
Points: 1,625, Level: 1 Points: 1,625, Level: 1 Points: 1,625, Level: 1
VFPACER's Avatar
Car: 2007 Chrysler 300C SRT8
I have used Castrol Edge Sport 5W-30 on my 6.1 300C SRT8 since new and change the oil & oil filter every 6 months as recommended.
The car has done only 20,000 Kms and runs like a swiss watch on steroids.
VFPACER is offline
post #9 of 9 (permalink) Old 08-22-2010, 11:16 PM
Points: 97,419, Level: 1 Points: 97,419, Level: 1 Points: 97,419, Level: 1
Fisch's Avatar
I didn't know 5w-20 was an option for the 5.7? Thought 5w-30 was a must.
I've always used Mobil 1 full synthetic 5w-30 and always been happy. I change at about 7000-8000 miles, and usually use 7 quarts or so. I use MDS however.
Fisch is offline
post #10 of 9 (permalink) Old 05-03-2015, 06:08 AM
Points: 144, Level: 1 Points: 144, Level: 1 Points: 144, Level: 1
What motor oil?
In australia they use 10w30 but in US is 5w20. I have 2006 300c 5.7 HEMI and the manual that came with the car has the spec of 5w20. I use Mobil 1 Extended Performance with Mobil 1 Filter it works really great.
joee300 is offline
Excessive oil use in 3.5 6cyl motor? Norp Problems / Dealer Service 2 06-06-2010 11:16 AM
Motor Oil Bobquinn 1st Gen SRT8-Specific General Discussion 6 03-15-2008 12:39 AM
Motor Oil Bible MoparCanuck General Discussion 3 12-01-2007 09:15 AM
Motor Oil Comparison VERY helpful. jmoney 1st Gen SRT8-Specific General Discussion 27 07-01-2007 10:05 PM
What grade motor oil? diablosrt8 General Discussion 6 08-31-2006 10:56 AM
