Old 11-30-2005, 02:00 PM   #11 (permalink)
MrHappy
MrHappy's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 1065
Same noise here... temps just recently dropped into the 30s so I too shall try bedding them... people are going to see all of us out on side roads gunning it then breaking and think 300 drivers have all went nuts!
MrHappy is offline
Old 11-30-2005, 02:14 PM   #12 (permalink)
CUEBALL
CUEBALL's Avatar
Member Number: 3447
You might want to read this technical white paper on the myth of the warped rotor: http://www.stoptech.com/tech_info/w...brakedisk.shtml
Thanks!! good reading
CUEBALL is offline
Old 01-05-2006, 06:03 AM   #13 (permalink)
DZeckhausen
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (8)
Did this fix your problem?
Dave Zeckhausen
Owner, Zeckhausen Racing
Chrysler 300 Products
Dodge Magnum Products
Dodge Charger Products
DZeckhausen is online now
Old 01-05-2006, 09:38 AM   #14 (permalink)
CUEBALL
CUEBALL's Avatar
Member Number: 3447
Well, for me it was a challenge to find a spot I could do it 8 times, but I finally got it done. I haven't noticed any squealing.. but I do have a grinding noise, only when cold and only for the first stop. I attribute this to cold pads, and pay it no mind. I have a slight brake judder the last couple of days, so I may need to try your method again if it continues. Thanks for the help!
CUEBALL is offline
Old 01-05-2006, 10:03 AM   #15 (permalink)
DZeckhausen
Member Number: 1056
Trader Rating: (8)
That's often caused by moisture on the iron rotors causing some very minor surface rust. This rust gets taken off the first time you hit the brakes and that's why the grinding sound goes away.
Old 01-05-2006, 02:42 PM   #16 (permalink)
charlie D
charlie D's Avatar
Car: 2006 Chrysler 300C-AWD
Member Number: 2420
The "bedding" procedure that is being described will eliminate the "squealing" that you're describing.I was experiencing the same noises but after using the procedure,I was impressed at the results.The "squealing" did come back after a while but a repete rectified it. I now automatically do it every so often as a matter of principle even though I have no noise.Now I consider this to be preventive maintainence every couple of weeks ( only doing it twice )/ no noises !!
2006 300C AWD
C V loaded
Molded mud flaps Mopar window shields E&G Classic double weave grill & inserts Windowstinted 35% Custom Exhaust
Padded leather console cover
Winged Chrysler visor graphics
Winged Chrysler floor mats
S/S Trunklid molding
Custom paint matched:Taillight Bezels,Engine shroud,Air box lid,SRT8 lip & roof spoilers
Zinik Z17's/BFG KDW 2's/255/55VR18/RF
Body Kit - still in box
charlie D is offline
Old 01-05-2006, 05:24 PM   #17 (permalink)
chasb
chasb's Avatar
Member Number: 3019
Me too in New York
Nope, not alone. Now that its getting in the low 30's here in Germany, my 3000 mile 300C does just what you wrote. I had good brake response before, so I never bedded them even though I've read about that since I came here @ april, I'll do that next few days and post results. I usually don't worry about pad noise unless it is pulsating due to warped rotors, or making a grinding sound. The thing I like about this car is it is easier for me to do a brake inspection than any other car I've had.
Just started wiht the real cold weather. Did into happen before. Brakes squeak once and then they are fine once I get going.
Super Chips Tuner flashed
chasb is offline
