Old 02-01-2006, 08:49 AM   #1 (permalink)
Desert Dawg
Desert Dawg's Avatar
Car: 2005 Chrysler 300c
Member Number: 4825
Question My brake spring is annoying
This may have been hashed over before and I appologize because I'm a newbe but has anyone come up with a solution for the return spring creaking when you are holding the brakes on, I've tried greasing but that is short term. The dealer had no solution and says it's common. I'm going to try a rubber tube over the spring wire but I want to asked if a good fix has been found. I have had my C for over a year and no problems at all but I like my interior quiet Thanks in advance for any answers.
DD
Desert Dawg is offline
Old 02-01-2006, 11:58 AM   #2 (permalink)
HEMEEE
Administrator
HEMEEE's Avatar
Car: '07 Chrysler 300C SRT8
Member Number: 664
DD
I haven't heard this problem come up before, but I moved your thread out of the interior visual mods forum and into the brakes forum, where you're more likely to get a good response. Our resident brake expert, bar none, is Dave Zeckhausen. If you don't receive a reply in your thread, you might want to send him a PM.
Welcome to the forums, and good luck with your problem!
P.S. the New Member forum is a great place to introduce yourself and get acquainted with some of our really friendly members, here's a link if you'd like to check in over there!
Linda... * More Pics *
HEMEEE is offline
Old 02-01-2006, 12:47 PM   #3 (permalink)
GoofyTimL
GoofyTimL's Avatar
Car: '07 MSRT8 Bright Silver; '06 H.E. 300C Inferno Red MSRT: AirHammer, OptGrp 1, UCon, ACW flaps, Stealth Bulbs, 22elite armrests/console, pin stripes H.E.: ProtectGrpII, RearVES, Sunroof, UCon, Sirius, ACW flaps/Eng. cowl, 22elite armrests/VES cover
Member Number: 3755
Desert Dawg... I have a 300C and have no idea what you're talking about. Are you saying that you hear a "creak" when you let your foot off of the brake, or is it the emergency brake and release to which you're referring? Has this been happening for the entire year of ownership, or just recently started?
GoofyTimL is offline
Old 02-01-2006, 01:00 PM   #4 (permalink)
Desert Dawg
Member Number: 4825
Creaking Brake spring
This started about 5 months ago. The return spring for the brake pedal rest against the back of the arm. When you depress the brake it shifts the spring slightly. Once it wears the coating off the spring it gives a vibration on the spring coil. I thought it was just my car but the dealer service Mgr. knew about it. The grease helped but short time. My family didn't notice it till I pointed it out.
Old 02-01-2006, 01:12 PM   #5 (permalink)
BobCav
BobCav's Avatar
Member Number: 2085
I have it and I know exactly what you're talking about! Apply a little more or less pressure or move the pedal a little and you hear "creek-creek" and yes, it's annoying!
Visit my homepage...
BobCav is offline
Old 02-01-2006, 01:32 PM   #6 (permalink)
GoofyTimL
GoofyTimL's Avatar
Member Number: 3755
We've only had our pre-owned 300C for 4 months and it now totals 19.1k miles, but I can't say that I have ever heard (or noticed) this sound from my brake pedal. Guess I'll have to do some investigating over the next couple of days.
Old 02-02-2006, 08:03 AM   #7 (permalink)
DZeckhausen
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (8)
This is the first time I've heard of this problem. Since it isn't affecting the vast majority of these cars, I'll have to assume there's something slightly different about your car. Perhaps the spring was installed improperly while your car was being built. Perhaps your spring didn't have the correct coating. In any case, have you asked if the dealer can order you a new return spring?
Dave Zeckhausen
Owner, Zeckhausen Racing
Chrysler 300 Products
Dodge Magnum Products
Dodge Charger Products
DZeckhausen is offline
Old 02-02-2006, 09:31 AM   #8 (permalink)
MrHappy
MrHappy's Avatar
Car: 2007 Chrysler 300 SRT8
Member Number: 1065
I too have it. It's like what I've had with other cars when the break pressure is let off just slightly not so much that it moves the car but enough you hear a noise, except with this car, you hear it no matter what.
MrHappy is offline
Old 02-02-2006, 10:10 AM   #9 (permalink)
BobCav
BobCav's Avatar
Member Number: 2085
I'm thinking about a teflon sleeve inside the spring. My luck it'll be the coils rubbing against each other!
BobCav is offline
Old 02-02-2006, 10:54 AM   #10 (permalink)
JmyDs300C
Member Number: 3451
I have it too and have experienced this for about four months. I haven't mentioned it to the dealer, nor have I taken the time to examine it, but I wonder if the spring is rubbing against the panel that covers over the underside of the dash. I have big feet and may have nudged that panel upward. I'll look into it this weekend, or ask the dealer who has been very helpful.
JmyDs300C is offline
