Old 06-21-2006, 08:08 AM   #11 (permalink)
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (9)
Originally Posted by Spock1
Wish I knew. I've been back to the dealer to get it adjusted but it still doesn't hold. The dealer says they can't adjust it any further.
You might be able to get it to grab slightly more by scuffing in the parking brake shoes and/or removing rust from inside the drum. The technique is to drive about 10mph, then apply the parking brake partially. Drive no more than 100 feet like this, then release the parking brake. That should be enough to scuff things up inside the drum and/or remove any deposits from the parking brake shoes. See if it helps at all.
Keep in mind that this is not an "emergency" brake. Rather it's a parking assist device to help take some of the load off the PARK pawl pin. It would be more important if your car had a manual transmission.
Dave Zeckhausen
Owner, Zeckhausen Racing
Chrysler 300 Products
Dodge Magnum Products
Dodge Charger Products
DZeckhausen is offline
Old 06-21-2006, 09:57 AM   #12 (permalink)
CVC22348(b)(1)'s Avatar
Car: 2006 Silver Steel CSRT8
Member Number: 4790
Actually, the 1986 Saab 900 parking brake operates the front wheels. I'm sure several of their other models did too. But that's an oddball car!
Most parking brakes operate on the rear wheels, either via the use of a pair of drum brake shoes that clamp against a drum built into the rear rotor, or they use a ratcheting mechanism inside the rear brake calipers to clamp the rear disc. The 300C uses a drum mechanism.
My '86 Subaru locked up the front right and rear left tires. I had it towed and the tow truck driver dragged it leaving a 25 foot mark on the pavement before he figured it out.
He's a demon on wheels
He's a demon and he's gonna be chasin' after someone.
He's gainin' on you so you better look alive.
He's busy revvin' up a powerful Mach 5.
CVC22348(b)(1) is offline
