Originally Posted by james jefferson
saw same show. the brake upgrade was lighter than the oem.
But the
distribution of weight on the Dodge Neon brake kit was different, since the rotors were larger in diameter and thicker than the stock rotors. The centers (hats) of the rotors were lightweight aluminum, which did drop the total weight over stock. But the polar moment of inertia for the new system was greater than stock.
Imagine you are a figure skater spinning in a circle. As you spread your arms out, you spin slower. As you pull your arms close to your body, you spin faster. In either case, your weight remained constant but the distribution of that weight changed - thus your polar moment of inertia changed.
As Todd correctly pointed out, the stock front rotors on the 300C are nearly as large as the aftermarket 355mm (14") brake kits from Brembo, StopTech, and TCE. So the end result is your polar moment of inertia won't change much, if at all and you won't notice a difference in handling due to any weird gyroscopic effects. Now if you were to install a brake kit with 380mm (15") rotors, you might have a different story. And a set of 22" wheels will have a much greater impact than even the 15" brake kit.
On a related note, I did notice a subtle improvement in ride and handling when I swapped the stock 300C wheels on my car to a set of Dodge Magnum RT wheels. The tires and dimensions of the Dodge wheels are identical. But the Magnum RT wheels are a few pounds lighter. Now I'm back to the 300C wheels because I have my winter tires installed on them. But I did like the difference. This may inspire me to buy a set of HRE wheels in 18" for next summer in order to shave some more weight.
