Old 09-05-2007, 10:10 AM   #1 (permalink)
omg_fast's Avatar
Car: 2006 chrysler 300c
Member Number: 13043
Send a message via MSN to omg_fast
Parking Brake Issues
Has Anyone But Me Had Any Issues With The Parking Brake. Specificly When I Turn The Car On The Parking Brake Light Will Light And Emit Short Beeps To Indicate That The Parking Brake Is Engaged. This Is Strange For Me Because I Have Never Had The Parking Brake In Use Before. I Have '06 5.7 300c. As Of Now I Still Run Stock Wheel Set Up. 18" Chrome Clads. Any Feedback Will Help
omg_fast is offline
Old 09-05-2007, 10:27 AM   #2 (permalink)
Defiant 300's Avatar
Car: 2006 Chysler 300
Member Number: 9654
Same here as well I checked the wiring and the fuses but still can figure it out. It happens for me about once a week.
Defiant 300 is offline
Old 09-05-2007, 11:18 AM   #3 (permalink)
GoofyTimL's Avatar
Member Number: 3755
You probably brush the pedal inadvertantly as you enter the car. This can shift it enough to set the light, which trips the chime. You don't even "feel" it, but I found myself doing this quite regularly at first (guess I have big feet!). Just pull on the release and it will/should pop back up enough to eliminate the light and chime. In the worse case, use your toe and force it up enough to distinguish the light.
It may be something your dealership can adjust if you can't change your entrance practice... like learning to walk without dragging your feet slightly.
GoofyTimL is offline
Old 09-05-2007, 12:45 PM   #4 (permalink)
Ali"i 300C's Avatar
Car: 2006 Satin Jade 300C / 2006 Silver 300C SRT8........ His and Hers
Member Number: 4541
I had similar issue, but I use mine. At first trip of the day the light would stay on, as if the brake was not released. Second trip of day all was OK. Turns out the return spring tension was weak. They replaced the PB assembly (and the cable I think, but the cable might be part of the assbly). All has been fine since.
Ali"i 300C is offline
