Old 10-13-2007, 05:57 PM   #1 (permalink)
SBK
Car: 2005 Chrysler 300c
Member Number: 12843
Please Help! Doing Brake Install Right Now
Hi guys. I am out there doing a rotor swap and new pads and have run into a big problem. The two pistons in the calipers are fully extended and I don't know how to get them to recess. I have the car up on jacks and only one side removed. I have to start the car and thus hit the brake and the pistons are almost all the way out and will not go back in.
How do I get them to retract? Is there a pressure release valve or something? Seriously guys, I really need your help.
SBK is offline
Old 10-13-2007, 06:11 PM   #2 (permalink)
Jected
Jected's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 9663
Ok here goes.
You will need the following tools - G clamp and a flat peice of wood about 1cm x 3cm x 10cm (strong)
1. Loosen the brake reservoir cap.
2. Place rags underneath to catch any overflow
3. Go to the caliper you are having problems with and place the block of wood across the 2 pistons.
4. Using your G clamp slowly slowly wind it in making sure that both calipers are going in evenly untill the are fully compressed.
If they are not, loosen the clamp and follow steps 3 & 4 on the caliper sticking out the furthest until the are even again.
Make sure to check the fluids once you are finished and DO NOT pump the brake pedal until iit is all re assembled.
Hope that helps.
THE COUNTDOWN HAS BEGUN TO FIRE IT UP.
http://www.300cforums.com/forums/avatars/jected.gif?type=sigpic&dateline=1210167973
Jected is online now
Old 10-13-2007, 06:12 PM   #3 (permalink)
magic32
magic32's Avatar
Car: 2006 chrysler 300c srt8
Member Number: 11786
try opening the brake fluid bottle under the hood if you haven't already. next go get yourself a good set of c-clamps and a couple block of wood and clamp them slowly and they should retract. a little old school i know. it worked for me.
magic32 is offline
Old 10-13-2007, 06:13 PM   #4 (permalink)
magic32
magic32's Avatar
well jected, we must have been typing at the same time. nice to see we think alike. you did a better job
magic32 is offline
Old 10-13-2007, 06:15 PM   #5 (permalink)
Jected
Jected's Avatar
Member Number: 9663
LOL.....just saw that . Hope it helps him out and yes great minds think alike...
Old 10-13-2007, 06:17 PM   #6 (permalink)
SBK
Ok, I am going to go do that now. Pull the cap under the hood. Block of wood. C clamps slowly. Got it. brb
SBK is offline
Old 10-13-2007, 06:26 PM   #7 (permalink)
SBK
Even as I do it slowly, it is not depressing. Could I just bleed the brakes instead? Wouldn't that work?
SBK is offline
Old 10-13-2007, 06:40 PM   #8 (permalink)
Jected
Jected's Avatar
Member Number: 9663
It will go in trust me. It will be extremely tight. Once it starts it will get easier.
Old 10-13-2007, 06:44 PM   #9 (permalink)
SBK
Ok, I trust you. Let me try harder.
The cap under the hood is off. I have wood on the one piston for now because it is out about double the other one. When it meets it will put the wood on both and c clamp it more.
Brb. And thanks for the help so far. Beer is on me.
SBK is offline
Old 10-13-2007, 06:46 PM   #10 (permalink)
Moose
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
You don't need any of that. Do you have the e brake off? Anyway, you should be able to put pressure on the pistons and they will slowly depress. If you have to, put a large screw driver and pry to the side. There is no reason why they will not push back into place. Are you sure you are pushing on the right part?
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back Calendar Winner
Moose is offline
