Originally Posted by ronharo
When installed properly which direction should the slots be facing on the left front wheel, like this / or like this \. I belive mine were installed wrong they are like this /.
I assume you're talking about aftermarket rotors because you have a 300C, not an SRT8.
All I can tell you is that the OEM SRT8 slotted rotors do not have a left and right rotor, meaning one would go one way and the opposite side the other way.
I guess it depends on whether the aftermarket rotors did come in left and right specific rotors. If it's any consolation to you, DaveZ says his wife's Corvette didn't come with left and right rotors.
Check both sides and see if one goes one way and the other side is backwards.
Bernie
