Originally Posted by 300C Doc
i went in to my mod shop yesterday and ordered me up some sloted and drilled rotars and tried to get some new pads while i was at it and found that hawk has 2 different pads for the 300's but it doesnt say what pad is for what car ... only that they fit the 300
i even went to the hawks website and they have 4 different ones .. now im really confused as to what ones i should be getting
can anyone help me out ??
from my mod shop i have these two part numbers
#HB509F678
#HB507F711
the hawks website gives these part numbers
#HB507F.711
#HB507Z.711
#HB509F.678
#HB509Z.678
The way to decipher a Hawk part number is to break it up into three pieces. For example, let's look at the HB509F.678 pads. The "HB509" part is the pad shape. The letter to the left of the decimal, in this case "F", is the pad compound, specifically Hawk HPS (High Performance Street). And the three digits to the right of the decimal is the pad thickness, in inches. So this pad is 0.678" or 17mm thick.
Hawk street compounds are:
F = HPS
Z = Performance Ceramic
Y = LTS (Light duty truck & SUV)
P = HP Superduty (Heavier truck)
N = HP Plus (very aggressive autocross pad)
For the Chrysler 300C, I would pick the Hawk HPS pads (among the pads offered by Hawk) as the best mix of overall pedal feel, dust level, noise, and performance. The Hawk Performance Ceramic, in my opinion, gives up too much performance in exchange for a slight dust reduction over HPS. I would not even consider the HP Plus, since it's probably the noisiest and dustiest aftermarket pad sold. Terrific performance, but unlivable on a daily driver.
Which part numbers fit your car? The 300C 5.7 uses D1058 front and D1057 rear pad shapes. The corresponding Hawk part numbers are
HB509F.678 (front) and
HB508F.675 (rear). By the way, the AWD 300 V6 model also uses these same pads.
The rest of the V6 models use the same pads in the back, but they use a smaller front pad. The pad shape is D1056 and the Hawk part number for HPS front pads is HB507F.711.
We have all these pads available, as well as other brands, for the various 300 models. If you can't get what you need from your local shop, give us a shout and we'll be happy to help.
