Old 12-21-2007, 05:25 PM   #11 (permalink)
Car: 2007 Chrysler 300C SRT8
Member Number: 15777
DZeckhausen...
Thanks again! You've been a lot of help and I'll be sure to pay you back with business in the near future...
buzzedsrt8 is offline
Old 12-28-2007, 10:03 AM   #12 (permalink)
jonnyg21's Avatar
Car: 2006 chrysler 300c SRT8
Member Number: 12024
Dave Zeckhausen
I have a 2006 300C SRT8. I absolutely hate my dealer so your product is the one I am going with. I jsut need some help and have a few questions. Can I put bigger rotors on? Will that help my braking distances? Can I use your pads with the brembo calipers? And what parts do i get? if you can you can email me at jonnyg21@aol.com. I apperciate it thank you.
Jonny
jonnyg21 is offline
Old 12-28-2007, 10:17 AM   #13 (permalink)
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (9)
Jonny,
The Posi-Quiet pads for the SRT8 are designed to fit the factory Brembo calipers. You can click here to purchase front and rear pads (only one box needed of each): Zeckhausen Racing
The SRT8 has relatively large brakes right from the factory. Thermal capacity (resistance to fade) is not an issue for even the most aggressive street driving. (I'm talking about stuff that won't get you arrested!) Normally a big brake kit will not improve single-stop stopping distances. The benefit is primarily adding thermal capacity and this benefit is mostly seen on the track. In the case of the Chrysler BBK, however, StopTech discovered during testing and final design of their 4-wheel kit that they could improve 60mph to zero stopping distance by about 10 feet, using the same car, same track on the same day, same test equipment, and same tires. (Most magazine tests touting improved braking from a BBK use a car with sticky tires and then compare that result with the factory published specs that use stock tires. Not fair.)
The bottom line is that you can fix the squealing, dusting, and rotor scoring problems of the SRT8 for about $170 in pads. Or you can buy a $5,800 StopTech big brake kit and get the above benefits plus some improvement in stopping distance and a better, firmer pedal feel. I have the StopTech 4-wheel BBK on my own SRT8 and I love it. But for most SRT8 owners, it's way overkill, especially if the problem you are trying to solve is dust and noise.
Dave Zeckhausen
Owner, Zeckhausen Racing
DZeckhausen is offline
Old 08-14-2008, 02:00 PM   #14 (permalink)
SRT8-KONVICT's Avatar
Car: 2006 Chrylser 300C SRT8
Member Number: 18446
Originally Posted by DZeckhausen View Post
Jonny,
Got the pads ordered Dave, Thank you.
SRT Option Groups I/II & Rear Seat VES
CURRENT MODS:
Corsa Catback Exhaust
Mopar CAI
DiabloSport Predator
Billet Tech Oil Catch Can
E&G Phantom Grille
Silver Dash Kit
Complete LED Conversion
Complete STEALTH Conversion
+Many More
SRT8-KONVICT is offline
Old 08-14-2008, 05:34 PM   #15 (permalink)
Member Number: 14575
Trader Rating: (4)
R1 concepts has great brakes and rotors
Big Daddy J 300 is online now
Old 08-14-2008, 11:53 PM   #16 (permalink)
Car: 2006 SRT-8 300
Member Number: 4550
brake pads
If you want OEM pads, Bendix makes pads with a Mopar part # for our SRT-8 cars. Find a Bendix dealer, tell them you have an SRT-8 and they can get pads for your car at a significant savings over the dealer.
I don't mind the dust and demand the best performance characteristics in my brake pads, but if you have 37,000 miles on stock pads, perhaps high performance is not one of your requirements.
Originally Posted by srtq8i View Post
Where could i find brake pads for the 300c srt8?
model 2006
mileage so far 37,500
so they must be changed
Dr. Bob
DrBReed is offline
Old 08-15-2008, 07:08 AM   #17 (permalink)
Performance Moderator
Car: 06 Deluxe! CSRT8
Member Number: 3650
I'm with Doc
I, too, cannot afford to change the performance of my brakes. The stock pads have what I want, and I could care less about dust.
37000 miles may be some kind of record! Also, everyone should note that OEM Mopar slotted rotors are available for under 100 dollars each.
Steve
06 300C SRT8
Only mod is new Toyo Proxes 4
245/45 front 275/40 rear
stevesrt8 is online now
Old 09-02-2008, 10:06 AM   #18 (permalink)
I took my car in today for installation of the posi brake pads & they are trying to convince me I need all new rotors, is this necessary right away?
if so, what is the best place to buy them? they wanted $500 for OEM. I think I will look for some slotted ones if they cost that much anyways.
CURRENT MODS:
Mopar CAI
E&G Phantom Grille
Silver Dash Kit
+Many More
Old 09-02-2008, 10:22 AM   #19 (permalink)
Member Number: 1056
Trader Rating: (9)
Ask them to tell you the remaining thickness on those rotors. The fronts were 32mm thick when new and should be discarded and replaced when they get down to 30mm thick. The rears were 28mm thick when new and should be replaced at 26mm thick.
That doesn't sound like a bad price for OEM rotors. However, see my comments above. I doubt your rotors are in need of replacement.
Dave Zeckhausen
Old 09-02-2008, 10:30 AM   #20 (permalink)
Good info Dave, I will try to find out the thickness.
Appreciate the prompt reply!
CURRENT MODS:
Mopar CAI
E&G Phantom Grille
Silver Dash Kit
+Many More
