Old 02-07-2008, 05:54 AM   #11 (permalink)
DZeckhausen
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (8)
Originally Posted by Cibalo View Post
I have the exact same problem on my SRT8, coming from the front right wheel. I went out today and did the series of hard stops from 60 to about 15 mph. After I started feeling the breaks fade I did it one more time and then bumped it up to 70 and cruised down the highway for about 3 miles did a quick turn around without stopping and cruised back into town.
On my way home I stopped to get some gas and head that same sound again from the same wheel. Do I need to go it again or at higher speeds?
I have an appointment with the service department at the dealership I bought the car from (not a Chrysler dealership) for Friday but if they aren't going to do anything I'd rather not waste my time. Only reason I was going was because I have a 30 day warranty.
Any idea how many miles are on those pads? Did you pull a wheel and inspect the remaining thickness? The reason I ask is that pad vibration is not the only source of brake squeal. If the pad is fully worn down to the metal backing plate, then the squeal could be the result of some metal on metal action and bedding would be the wrong thing to do. Always check to make sure you have sufficient pad life remaining before you go out and bed the brakes.
I wasn't there to watch, but from your description it sounds like you followed the bedding process properly. The OEM pads do tend to be more squeaky than the aftermarket Posi-Quiet pads. So an alternative to bedding would be to try the different pads. At $167 for all four corners, it's a better alternative than buying a new set of OEM pads at well over $500. I think they want more than $300 just for the rear pads!
Dave Zeckhausen
Owner, Zeckhausen Racing
Chrysler 300 Products
Dodge Magnum Products
Dodge Charger Products
DZeckhausen is offline
Old 02-07-2008, 09:13 AM   #12 (permalink)
Cibalo
Cibalo's Avatar
Member Number: 16346
I pulled the wheel last night and checked the break pads. I have 14k miles and about 3/8" of pad left. So that seems to be fine. And the squeal doesn't happen all the time, only after I've been driving for a while and then gently apply breaks. Similar to slowing down for a redlight that you see up ahead.
My only thought is do the bed in again and include a few 80 mph runs.
Cibalo is offline
Old 02-07-2008, 02:58 PM   #13 (permalink)
UK CHRYSLER 300C
UK CHRYSLER 300C's Avatar
Member Number: 12398
like I said earlier,,,"chamfer the leading and trailing edge of the pads"
[IMG]
UK CHRYSLER 300C is offline
Old 03-03-2008, 07:53 AM   #14 (permalink)
teamsevas300c
Car: 2005 300c 300c
Member Number: 12274
Send a message via AIM to teamsevas300c
I Paid So Much Money For The Pads And Rotors From The Dealer And Have Nothing But Noise Problems, Ive Taken The Car Back 3 Times Already And They Keep Shaving My Rotors, I Dont Know How Many More Times There Going Too Shave But Ibet I Have No More Rotor Left And Its Only Been 4 Months Into My New PadsAND ROTORS AND CANT BELIEVE THE PROBLEMS IAM HAVING... They Refuse To Replace Them
300C
SILVER / HEMI
SLAMMED / CUT / EB SPRT LINE SPRINGS
FACTORY HIDS / YELLOW FOGS
SEVASFORGED OF COURSE!
22X9 FRONT
22X10.5 REAR
ap51 DIAMOND BRUSH
255/30/22F- 452 FALKENS
295/25/22R- 452 FALKENS
teamsevas300c is offline
Old 03-03-2008, 08:09 AM   #15 (permalink)
DZeckhausen
Member Number: 1056
Trader Rating: (8)
Did you try bedding the brakes? See: Instructions for bedding in your brakes
Old 03-03-2008, 08:41 AM   #16 (permalink)
SRT8/BMW
SRT8/BMW's Avatar
Member Number: 1642
just pm'd you...would like some brake advice.
2006 300C 5.7,--HHP/BES Stage 2 PP heads, custom 268 cam, kooks LT/headers w/ HF cats, Corsa cat backs,KWs coilovers, Hotchkis sways, Dub CAI,B&G stage II, 2800 TC, 20% tint, 402 Motoring smoked tails, Billet knobs, 20 x 8.5 Verde Madonna wheels, Toyo Proxes 4s, Kicker amp/spkr upgrade, Power slot rotors w EBC Red Stuff Pads, Dashhawk370RWHP/372RWTQ
SRT8/BMW is offline
Old 03-22-2008, 11:18 PM   #17 (permalink)
BIG SMOOTH
BIG SMOOTH's Avatar
Member Number: 7757
Trader Rating: (4)
Noticed mine again today exactly as described above and it's pissing me off to have a decent looking car and knowing everyone can hear you squealing. I've bed them in twice over the last year and think I might just get some Posi Quiet Ceramic pads and start anew. What do you all think???
"Stay classy San Diego!"
BIG SMOOTH is online now
Old 03-23-2008, 06:25 AM   #18 (permalink)
DZeckhausen
Member Number: 1056
Trader Rating: (8)
The composite shims on the Posi-Quiet pads are very effective at damping out the high frequency vibrations that cause squeal under light braking. That being said, when I had a 5.7 liter 300C, I was able to quiet down the stock pads by bedding them. So, unless the stock pads are worn down below the 50% mark, I would encourage you to save some money and try the bedding one more time. If they're near the end of their life, then go for the Posi-Quiets. You'll like them.
Old 03-23-2008, 06:44 AM   #19 (permalink)
The Trophy
Car: 2005 Chrysler 300c AWD
Member Number: 11716
I could suggest when you bed your brakes, DO NOT completely stop, accelerate up to 60 mph than brake until you get to 10mph, and repeat the process a couples of time. What you want to do after bedding your brakes is to drive around without stoping for a couple of minutes too let the brakes cooldown.
If you stop the car completely after bedding the brakes without letting them cooldown first, you will more than likely wave your disks.
The Trophy is offline
Old 03-23-2008, 07:29 AM   #20 (permalink)
DZeckhausen
Member Number: 1056
Trader Rating: (8)
That's close to the right method. You want to repeat these braking events (60 - 10mph) about 8 times with no cooling off in between. And allow a few minutes of cruising afterward, to allow the brakes to cool down to the point that you can safely come to a complete stop without causing problems.
If you come to a complete stop during the bedding process, you won't "wave" or "warp" the rotors. What you will do is leave a pad imprint on the rotors. This imprint results in a thickness variation that causes brake judder on subsequent stops.
The process is explained in gory detail here: Instructions for bedding in your brakes
