Old 01-11-2008, 06:37 PM   #11 (permalink)
CUEBALL's Avatar
Member Number: 3447
The pad behind the front wheel is made for the OEM scissor jack.... per the owners manual.
Although you can put a floor jack there.. when I did it as a test, it caught the plastic body piece.. I didn't want to crush it so I followed the hoist points above.
CUEBALL is offline
Old 01-11-2008, 07:08 PM   #12 (permalink)
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Originally Posted by hype View Post
Thanks for the info and links. Now I'm ready to start in the morning!
Good news. You'll find the hardest part is cleaning the wheels once it's off.
One thing though, you may find the front wheels are rusted on. Just put a couple of lug nuts on loosely and lower your floor jack. Mine came right off after the rust seal was broken.
You'll definately need to drive onto some boards to access the jacking point from the front otherwise the fascia is too low for the handle. I use a 2x12 that's beveled.
Bernnie
Rambit is online now
Old 01-11-2008, 09:33 PM   #13 (permalink)
Car: 2008 Chrysler SRT8
Member Number: 15587
Send a message via AIM to NM08SRT8 Send a message via MSN to NM08SRT8 Send a message via Yahoo to NM08SRT8
Originally Posted by Rambit View Post
No, there's no need to open the bleeder at all. You'll find these are the simplest brake pads to install. Takes about 4 minutes per wheel.
Bernie
Wow, very good to know! Less mess not having to deal with brake fluid I'm starting to love my domestic more and more as I read more about it
NM08SRT8 is offline
Old 01-13-2008, 12:51 AM   #14 (permalink)
AlexDestructive's Avatar
Member Number: 10390
what i did was use the lift riser pads
when using the location behind the wheel.
AlexDestructive is offline
