Old 12-20-2008, 05:48 AM   #1 (permalink)
Points: 5,847, Level: 1 Points: 5,847, Level: 1 Points: 5,847, Level: 1
Quiknen's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 20345
Send a message via AIM to Quiknen
Question Esp/bas Light On
First Time- noticing that the ESP/BAS are both displaying on my 300c AWD.
Last night got a little happy with the New England Snow Storm and was kind of doing donuts/axel slides. "not using brake at all" and got snow in the tires... i tried cleaning them the best i could after but i still felt snow pact in there..
(the traction light came on a couple times but never stayed)
This morning was about 14degrees and car started up hard
(probably because i didnt plug it in which idk if i should)
and the ESP BAS lights were on for the whole ride to work...
I would like to know anything i should try/ or is there anything recommended.
I have not pulled fuse 11 or reset the calibration yet or restarted it but i just want to know all of my possibilities... ANYONE PLEASE HELP
~quik
Quiknen is offline
Old 12-20-2008, 06:14 AM   #2 (permalink)
Points: 12,043, Level: 1 Points: 12,043, Level: 1 Points: 12,043, Level: 1
wog boy's Avatar
Car: 2006 . 300c, rolling on 24's
Member Number: 5242
Mine did the same after we abused it doing a few dyno runs, same thing the traction control light came on a few times and then the ESP etc...stayed on, took a little bit of driving for the system to recover, well mine did anyways mate
**My Youtube Video**
wog boy is offline
Old 12-20-2008, 06:38 AM   #3 (permalink)
Quiknen's Avatar
I just dont want to ruin the brakes anymore,
Does anyone know if with these lights on there will be constant rubbing?
I'm already at like 50% brake life and i have to drive 100miles for a xmas party later today
all i need is to run out of brakes in a fancy car haha
Real Name: Ian Butler
Modification List
Quiknen is offline
Old 12-21-2008, 06:14 PM   #4 (permalink)
Points: 5,759, Level: 1 Points: 5,759, Level: 1 Points: 5,759, Level: 1
Clean300C's Avatar
Member Number: 11326
It won't do anything like that I don't believe. The ESP/BAS lights being on means your electronic stability program and brake assist system are both deactivated. Alot of us add a switch to do the same thing. Be careful though, it means you have zero traction control.
Clean300C is offline
Old 12-23-2008, 11:45 AM   #5 (permalink)
Quiknen's Avatar
no worry's it was because the brakes froze with the snow... next day it was fine and happened again the following day because i did the same thing... Plus costing at 20mph putting it in neutral and starting the car did shut the esp off Wooo thanks for anwering my own question
Quiknen is offline
