Old 06-14-2009, 09:13 PM   #1 (permalink)
Points: 3,501, Level: 1 Points: 3,501, Level: 1 Points: 3,501, Level: 1
Dub's +2's Avatar
Member Number: 8262
Noise come from the Front while hitting bumps
This has happen since i purchased the car, Never really bothered me since its not that loud. Its summer and I always have my windows down now. Rolling on the 300c wheels i bought this week and changed out of the 22's. I can still hear these noises, noises like you holding two brake pads and clapping it together. Every bump I hit I can hear a rattle somewhere in the front wheel base. Over years its starting to piss me off. Please help!!!!
Chyrsler 300 Touring Black-
Hero Rogue 22's
SRT8 rear spoiler
Mesh grill
LED Tail lights smoked
Halo Headlights w/10k Slim HID
Kenwood Flip screen
2 JL15W6/ Rockford T-5002 w/Cap
5% tint
Compustar
Chrome trim
Dub's +2 is offline
Old 06-14-2009, 09:14 PM   #2 (permalink)
Dub's +2's Avatar
Member Number: 8262
I can't seem to find out whats the problem, I took my wheels out and looked at my brake pads. It has nothing to do with my brake pads either. Could it be my suspension?
Dub's +2 is offline
Old 06-14-2009, 10:29 PM   #3 (permalink)
Points: 27,801, Level: 1 Points: 27,801, Level: 1 Points: 27,801, Level: 1
Activity: 57% Activity: 57% Activity: 57%
bruno's Avatar
Member Number: 3129
Please go to this thread to read more than you'll ever want to know about that noise and then some!
Weird loose rattle sound over bumps in the front end???? (Moved)
bruno is online now
Old 06-15-2009, 10:05 AM   #4 (permalink)
Dub's +2's Avatar
Member Number: 8262
Thanks alot bro, i been searching for this all last night.
Dub's +2 is offline
Old 06-16-2009, 09:15 AM   #5 (permalink)
Points: 9,141, Level: 1 Points: 9,141, Level: 1 Points: 9,141, Level: 1
DZeckhausen's Avatar
Member Number: 1056
Trader Rating: (9)
What happens to the rattle if you gently apply the brakes? Does it go away? If so, then it's possible you've got a broken piston clip on the backing plate of one of your front brake pads. In that case, replacing the front pads will make the rattle go away.
If the rattle continues even when you're on the brakes, then it's some other suspension component or loose chassis bit that's making the noise. But at least you'll have ruled out the brakes.
Dave Zeckhausen
Owner, Zeckhausen Racing
Mopar Exhaust (older "classic" design)
DZeckhausen is offline
Old 06-26-2009, 03:17 PM   #6 (permalink)
Points: 2, Level: 1 Points: 2, Level: 1 Points: 2, Level: 1
Car: 2006 CHRYSLER 300 CHRYSLER 300
Member Number: 22833
Noise
I to have a rattle that is driving me nuts, I have checked the front end and everthing is tight, but interesting enough ius the fact that when I touched the rear caliper it seemed very loose it just slide in and out without resistance what do you think causes this
Bakerone is offline
Old 07-14-2009, 06:55 PM   #7 (permalink)
Points: 132, Level: 1 Points: 132, Level: 1 Points: 132, Level: 1
300spartans's Avatar
Member Number: 22822
its the swaybar bushings...there I just saved you fifteen pages of reading.lol
300spartans is offline
Old 07-14-2009, 07:08 PM   #8 (permalink)
Points: 16,167, Level: 1 Points: 16,167, Level: 1 Points: 16,167, Level: 1
Activity: 44% Activity: 44% Activity: 44%
BIG SMOOTH's Avatar
Member Number: 7757
Trader Rating: (8)
That seems to be the case first ^^^^ but many times the rattle/bumps persist and other parts need to be replaced.
I've had my steering rack (inner/outer tie rods) replaced as well as the sway bar bushings and my rattle persists.
I'm having some BWoody sway bar end links installed to replace the smaller OEM ones as well as replacing the front tension struts....
So we'll see if the rattle/clunking ends after this.
"You Stay classy San Diego!"
BIG SMOOTH is online now
Old 07-16-2009, 12:12 PM   #9 (permalink)
Dub's +2's Avatar
Member Number: 8262
Ok, I went to the dealership they refused to replace my swaybar bushing because they said it was my rotor and handbrake pads that was making the noise. He said that my hand brake pads are WORN out and my rotors are screwed. So he saying its coming from the rear. Someone please help. I don't think anyone else had this problem before.?
EDIT: So basically there saying that my handbrake pads and rotor is making that clunking noise.
Dub's +2 is offline
Old 07-16-2009, 12:44 PM   #10 (permalink)
Dub's +2's Avatar
Member Number: 8262
Now there charging me 45.00 dollar for a diagnose.
Dub's +2 is offline
