Old 06-29-2009, 11:59 PM   #91 (permalink)
Points: 4,351, Level: 1 Points: 4,351, Level: 1 Points: 4,351, Level: 1
Car: 07 Chrysler 300C SRT8
Member Number: 6743
Originally Posted by 808C View Post
is it possible to install a Stock nav in to a non nav equip 2008 300c
Yes.
A 2008 model probably has The mygig system. You need to find a mygig with the nav integrated- I believe it's the RER. Keep in mind that if it's an earlier stock nav such as the REC it will not interface. In other words make sure you look for the mygig nav unit.
VYPER883
300C SRT 8... Pure Evil Dressed to the Nine's...
"Ever notice how you come across somebody once in a while you shouldn't have ****ed with? That's me." Clint Eastwood as Walt Kowalski in Gran Torino.
vyper883 is offline
Old 06-30-2009, 09:35 AM   #92 (permalink)
Cool_V_300C's Avatar
Member Number: 9722
Originally Posted by GTOconvertedto300C View Post
Comment on your last paragraph: "However, he did say if every pair was reversed, it would still work... however it just wouldn't be "optimal" as far as the sound goes" Every time I have wired up speaker polarity backwards, the speakers actually worked backwards. When wired correctly the speaker cone will move outward when it hits. If it is wired backwards, the cone moves inward when it hits. This greatly cuts down on sound volume and quality, "a hell of a lost less than optimal". When the installer says it will still work, I guess, technically he's right.
The installer was correct, and there is nothing wrong with the direction
the speaker moves. The idea around creating sound is to move the air.
Unless you have a poorly made speaker, it should be able to create sound
properly regardless of polarity.
The one thing you MUST be certain of is that all speakers are wired with
the SAME relative polarity.
there are some exceptions, however. In a high end competition system,
sometimes the installer will wire certain speakers (say a pillar mounted mid)
in opposite polarity during the tuning phase in an effort to try and get
the sound stage set up properly.
Mods: Stereo only, PAC SNI, Peripheral CHYX, XM Commander, AudioControl four.1, MTX TA5604, MTX TA5601, Polk MMC6500, Polk MMC690, MTX JH4512X2D
Cool_V_300C is offline
Old 08-07-2009, 12:10 AM   #93 (permalink)
Points: 8,972, Level: 1 Points: 8,972, Level: 1 Points: 8,972, Level: 1
kalo's 300C's Avatar
Member Number: 5488
Aloha from Hawaii
please forgive me if I sound ignant but, wife wants to upgrade her streo are there any sugestions on head units with screen maybe single din or double din and all else that I might need to make everything work so that she will be happy ... Thanks for all of your help... Aloha Seth & Carol....
kalo's 300C is offline
Old 09-27-2009, 12:33 AM   #94 (permalink)
Points: 831, Level: 1 Points: 831, Level: 1 Points: 831, Level: 1
AlG300C's Avatar
Car: 2006 chrysler 300 SRT8
Member Number: 19859
2 questions i have on a 300 srt8
1 where do you find the Reverse back up wireing ? im doing a camera in rear
2 where do you find the parking sencer wire ?
also color codes would help alot too.
any one know or have done this install on a after market set up
O btw if you want to check the polarity of your speakers (See If there hooke up corectley + to + and -to -) from head unit to speakers.......theres a simple test IF you can get to the speaker wires AFTER amp or NON amped system .
useing a 9 volt battery and touch the pos of battery to pos of speaker wire and neg of battery to neg of speaker wire for a brief sec you will see the speaker suck in or pop out the correct way to have it set up on a system is pop out.
AlG300C is offline
Old 10-26-2009, 12:23 PM   #95 (permalink)
Points: 6,870, Level: 1 Points: 6,870, Level: 1 Points: 6,870, Level: 1
artichoke's Avatar
Car: 2006 Chrysler 300C SRT-8 black, no options
Member Number: 4091
Alternator Hum
I replaced my head unit, as well as the speakers of course, and now I have an alternator hum at about 3 KHz. I think the head unit contained some circuitry that suppressed alternator hum. Any suggestions on getting rid of the hum?
artichoke is offline
