Old 05-21-2006, 03:59 PM   #41 (permalink)
4herb2tas0tik's Avatar
Member Number: 846
Originally Posted by kalo's 300C
just checking is there no one that can help me with this. The stereo shops here are telling me that I need to buy a new deck if I want to add more screens to what I have now. Please help me with this before I spend money on something I dont have to do. Thank you Seth and Carol....
well i dont for sure..but.. i know if you try to hook into speaker wires before the amp it cuts out the nav voice...it has something to do with canbus...every thing seems to run threw the radio...go figure?...but i wouldnt doubt that if you add more tv's it messes something up....dont take my word for it tho....i just thought i would put my 2cents in...
2005 loaded black "C">>which was bought back by dc<<
2006 loaded black srt8
mopar-cai..magnaflow catback..diablo sport tuner
180*t-stat..tinted led tails..5% limo tint all around..
color matched side markers@sirius ant..
2-jl 10w7's boston pro 6.5's
audio control lc8....orion hcca 250-g5
orion xterime 800.4 1600 watts total
>>custom install by wesexcellence<<
4herb2tas0tik is offline
Old 05-21-2006, 09:10 PM   #42 (permalink)
kalo's 300C's Avatar
Member Number: 5488
Thanks for the reply, I hope some one else here can give me more info on this. Again thanks very much for your time, Aloha Seth and Carol...
kalo's 300C is offline
Old 06-22-2006, 11:17 AM   #43 (permalink)
Car: 06 Chrysler 300C
Member Number: 6359
Simple Question
This should be a simple question. In the non-nav head units is that a 4inch din? I want to add a touch screen DVD/Nav unit but I dont want the pop out screens.
Firefighterhuff is offline
Old 07-26-2006, 10:12 AM   #44 (permalink)
Car: 2006 Chrysler 300c
Member Number: 7013
Upgrade Sound Group I to SGII
Can I buy the amp and 2 additional speakers and upgrade using facotry parts? If so, where can I buy OEM parts to do this upgrade?
Gobster is offline
Old 07-26-2006, 01:22 PM   #45 (permalink)
DarkFury's Avatar
Member Number: 5701
When I installed my stereo in my Heritage 300C, I used the information in the initial post of this thread to help determine which wires were needed in the install...
What colors are the wires that run to the speakers?
Note: The the first color is the color of the wire and the second color is the color of the stripe on the wire.
Dash Left +: Gray/Orange
Dash Left -: Gray/Yellow
Dash Center +: Gray/Brown
Dash Center -: Gray/Orange
Dash Right +: Gray/Dark Green
Dash Right -: Gray/Light Green
Front Left +: Gray/Violet
Front Left -: Gray/Yellow
Front Right +: Dark Green/Violet
Front Right -: Dark Green/Yellow
Rear Left +: Dark Green/Tan
Rear Left -: Dark Green/Gray
Rear Right +: Dark Green/Brown
Rear Right -: Yellow/Gray
Subwoofer +: Grey/Brown
Subwoofer -: Dark Green/Brown
By my installer's findings, the polarities of each of the pairs listed above is REVERSED!!! (for example, the Left Dash positive was Gray wire/Yellow stripe and the Left Dash negative was Gray wire/Orange stripe. Opposite of what was quoted above.
He tested each of the speaker pairs with a 9V battery with wires attached to the positive and negative poles. Connecting positive battery to positive speaker pole and negative battery to negative speaker pole... the speaker would "pop out". If you did the reverse (positive battery to negative speaker terminal and vice versa) then the speaker would "pull in".
Using the wire diagram above, all of the speakers "pulled in"... therefore he determined the the speaker pairs above were actually backwards. He tested every pair of speakers and found this to be true.
However, he did say if every pair was reversed, it would still work... however it just wouldn't be "optimal" as far as the sound goes. I would recommend that anyone who used the above guidance to wire your system, to check your polarity to see if you now have it reversed.
Just a heads up... for folks who doing the install themselves.
DarkFury is offline
Old 07-27-2006, 07:16 AM   #46 (permalink)
Member Number: 7013
Sound Group II Parts
Does anybody know where I can buy the OEM parts to do this to my C? I need the amp, center dash speaker and subwoofer. I gues the wires are probably already there. I can just change out the 265 watt amp for the 365 watt amp. Any help would be great!
Gobster is offline
Old 07-27-2006, 07:27 AM   #47 (permalink)
DarkFury's Avatar
Member Number: 5701
Honestly, why would you want to use the OEM components? You can buy better speakers cheaper in the aftermarket.
DarkFury is offline
Old 07-27-2006, 07:34 AM   #48 (permalink)
Member Number: 7013
I know, but I want to keep it a "plug and play" system.
Gobster is offline
Old 07-27-2006, 09:57 AM   #49 (permalink)
DarkFury's Avatar
Member Number: 5701
Sounds like a job for those new PAC/Peripheral add in harnesses.
DarkFury is offline
Old 08-03-2006, 05:07 PM   #50 (permalink)
Deep Lava's Avatar
Car: 2005 Deep Lava Red 300C
Member Number: 1583
Forget the center speaker. A lot of us have disconnected/removed it. Sounds better without it, better stereo separation.
2005 300c Deep Lava Red w/Dynatech Longtube Headers, High Flow Cats, 140112 Borla, SuperChips FlashPaq, K&N Drop-in, 180ºF thermostat, Toyo Proxes S/T 255/50-18, and silencer removed = 13.682 @ 102.23mph
Deep Lava is offline
