Old 06-06-2006, 10:15 PM   #1 (permalink)
Plutolawyer's Avatar
Member Number: 5281
Aftermarket Handsfree
Anyone ever install or see the installed U-Connect that DCX sells? Looks the same as in the factory install, but does it just sit somewhere in the car or do you have to have it professionally installed? Maybe a stupid question, but I have thought about it in the past
Plutolawyer is offline
Old 06-07-2006, 03:44 AM   #2 (permalink)
300MAG's Avatar
Member Number: 3746
I have installed it and not bad at all, as long as you feel confident in removing the radio to connect the plug and play wire harness and splicing power wire to cig lighter(this will be accessible once you remover radio trim bezel) who should have no problem. The speaker, mic and small control panel are all plug and play as well. Hope this helps. Do a search and you may find a PDF copy of install manual on site.
300MAG is offline
