Old 04-23-2007, 10:54 AM   #1 (permalink)
NIQUE
NIQUE's Avatar
Car: 2005 Chrysler 300 Touring Signature Series
Member Number: 5250
Help... DEAD BATTERY after DVD Player Install
Originally Posted by NIQUE
Where do the wires go per the diagrahm below???
Memory/Battery (B+)(Yellow) goes where?
Ground (B-)(Black) goes where?
Ignition Swithc(ACC+)(Red) goes where?
Install complete:
B+ (Yellow) 12v + at cigarette lighter under center console for both monitors.
B- (Black) Grounded at cigratte lighter under center console for monitors and DVD player
ACC + (Red) 12v constant at cigarette lighter under center console for DVD player. DVD player is now controled by switch. Monitors have to be turned off after each use or when ignition switch is turned off.
The car was not driven for two days resulting in a dead battery. Where did I go wrong.
NIQUE
2005 W.P. Chrysler Signature Series
22" TIS 07s 265/35/22 AVON Tech 550 Tyres
9" Innovatek Headrest Monitors
Boss DVD Player
PAC Audio #AAI-CHY aux-in adapter w/ REC Navigation system
AF Navigation (In-Motion Hack)
http://www.carhack.org/forum/
Spoiler (Color Matched)
05 Chrysler 300 W.P. Signature Series 22" TIS
(CLICK LINK TO VIEW MY PHOTO GALLERY)
NIQUE is offline
Old 04-23-2007, 11:00 AM   #2 (permalink)
CplDaugherty
CplDaugherty's Avatar
Member Number: 5668
You should have the 12v ACC power on to something that is switched with the key, such as the cigarette lighter under the radio. I'm a little bit confused, your say that you have both powers set up to the always on lighter in the center console?
CplDaugherty is offline
Old 04-23-2007, 11:56 AM   #3 (permalink)
NIQUE
NIQUE's Avatar
Member Number: 5250
I was speaking of the 12v cigarette lighter under the center console/arm rest.
NIQUE is offline
Old 04-23-2007, 12:12 PM   #4 (permalink)
Mighty Noid
Mighty Noid's Avatar
Car: 2006 Dodge Charger RT w/R&T
Member Number: 5249
Try the cig. light in the center console below the AC controls. That one should be a switched 12 volts. This should be good for the red wire and the wire for your screens as well.
The one in the arm rest console is 12 constant. This will be fine for the yellow wire.
Quote from SF of LX's: "I LICK'EM! I DON'T KNOW THEM!!"
SoCalLX Club - Where Southern California Car Culture meets Modern Mopar Muscle
Mods:
HP - 330.4
Torque - 366
http://community.webshots.com/user/m...host=community
Mighty Noid is offline
Old 04-23-2007, 01:43 PM   #5 (permalink)
CplDaugherty
Member Number: 5668
^^^ Exactly what Mighty Noid said. You're having the switched power line connected to a constant power is causing your battery to be drained.
Old 04-23-2007, 03:41 PM   #6 (permalink)
jt321
Member Number: 11877
+1
jt321 is offline
Old 06-16-2007, 02:20 PM   #7 (permalink)
NIQUE
NIQUE's Avatar
Member Number: 5250
OK guys,
I went with above connections this morning. Why do the monitors blink for about a half a second when the Ignition is turn to ACC or On???? The monitors and DVD player turn off when the ignition is turned to OFF. I am so close to having this correct.
NIQUE is offline
Old 06-16-2007, 03:12 PM   #8 (permalink)
irish_loveAWD7
Car: 2002 Saturn VUE
Member Number: 12481
Originally Posted by NIQUE View Post
OK guys,
YOU DO HAVE THIS CORRECT. If the DVD player and monitors don't turn off when the ignition is turned to OFF it will drain your battery. The monitors blink becuase they are turning on. Nothing to worry about.
irish_loveAWD7 is offline
Old 06-18-2007, 04:27 PM   #9 (permalink)
D's300C
Car: 2005 Chrysler Brilliant Black 300C
Member Number: 10951
Send a message via AIM to D's300C Send a message via Yahoo to D's300C
your done man, just like he said. Video is good to go now.
D's300C is offline
