Old 03-27-2005, 07:43 PM   #1 (permalink)
moka987
Member Number: 1422
Question problems with JL sub installation
well i recently bought a JL 12 inch W7 sub with a JL 500/1 amp and got all the stuff installed by the local store. When they hooked the remote wire up apparently there were surges of power goin back into the fuse box where they hooked it too. The surges blew some fuse in there that the dealer said had some information on and that they wouldnt replace it if this happened again. So i went back and they turned the signal sensing switch on the amp on and took the remote wire out and now everything works fine, but i have the feelin that i am losing alot of power because of what happened. I was wondering if any of u guys could give me some advice on what to do and how your installation went?
moka987 is offline
Old 03-27-2005, 09:14 PM   #2 (permalink)
majestic
majestic's Avatar
Member Number: 1825
re:
What exactly did they hook the remote wire up to?
Are you using the stock headunit or an aftermarket headunit?
If stock... use Accessory or Ignition (fused) for the remote turn on
If aftermarket... use remote amp turn on wire (blue/white)
Hope this helps
majestic is offline
Old 03-27-2005, 11:13 PM   #3 (permalink)
apbrian112
Car: 2oo5 khrysla 3hunned
Member Number: 1572
well i hooked up my remote wire from my jl 500/1 to the ignition wire (pink/white). i tapped into the wire from the bundle of wires coming out of the fuse box. here's the thread i had going a while back where i was trying to figure out how to hook up the remote wire.
wire for remote wire (amp)
hope this helps. good luck!
brilliant black base- the poorman's version of the poorman's bentley.
apbrian112 is offline
Old 03-28-2005, 09:09 AM   #4 (permalink)
HaTaX
HaTaX's Avatar
Car: 2005 C - Loaded Cool Vanilla
Member Number: 1047
Losing alot of power to the subs? No, the remote wire just tells the amp when the car is on, using the signal sense method just tells the amp to look for a signal over the RCAs and turn on when it gets one.
2005 300C Cool Vanilla with every option box checked.
Built 11-06-04 / Brought Home 12-10-04
HaTaX is offline
