Old 11-30-2007, 03:41 PM   #1 (permalink)
THE KID
Car: 2006 chrysler 300c
Member Number: 11254
nav not working
ok i got the stock nav in my car and it worked ok then i got a bent wheel so i removed all for of my after market wheels with the tps and put my stock ones on so i took it for a spin and my tps system, esp light, abs light went off so i thought maybe it did because theres no sensor, but anywasy i tried to use ny nav and it shoes my car location but when i drive off my car is still in the same location, could this be a problem caused by not having my tps there?
THE KID is offline
Old 11-30-2007, 05:31 PM   #2 (permalink)
CUEBALL
CUEBALL's Avatar
Member Number: 3447
I wouldn't think the TPMS sensors would be causing the problem.... when Mine were out of the car, my NAV worked fine.
Any other ideas out there?
CUEBALL is offline
Old 12-04-2007, 02:20 AM   #3 (permalink)
THE KID
ok so my wheels are fixed now and there back on but the nav is still not working can someone help
THE KID is offline
Old 12-04-2007, 03:56 AM   #4 (permalink)
300MAG
300MAG's Avatar
Member Number: 3746
It's a long shot but pull the nav unit and make sure the GPS antenna plug didn't come loose. Maybe came loose from the jolt of bending the rim.
300MAG is offline
Old 12-04-2007, 06:52 AM   #5 (permalink)
jdiddy101
jdiddy101's Avatar
Car: 2005 CHRYSLER 300 limited
Member Number: 8318
Usually when the antenna is unplugged u get a message and the nav screen won't boot but it can't hurt.
Modification List
[X] Factory Nav
[X] In-motion Hack
[X] Tint 20% back 35%front
[X] Factory U-connect
[X] Leather armrest
[X] Startech grille
[ ] HID's
[ ] JL-2 10w7's
[ ] Backup Camera
[ ] Navtogo
[X]Universal Air Suspension
jdiddy101 is offline
Old 12-04-2007, 08:12 AM   #6 (permalink)
switcher
switcher's Avatar
Car: 2005 Chrysler 300C 5.7L Hemi V8 Black
Member Number: 13553
Location: Brampton Ontario, land of the brave, home of the C
If it shows your car in the correct location every time you start it, at least you know it is communicating with the satellite.
Is that the case?
Does it show your new location each time you start it?
If it does, I think it could be something with the controller knob.
It is behaving as though you are scrolling the map.
When you scroll through the map while driving, the tracking feature turns off.
Have you tried exiting and then re-entering the NAV mode while in motion?
That is how you get it to track you again.
switcher is offline
Old 12-05-2007, 02:47 AM   #7 (permalink)
THE KID
Is that the case?
yes that what it does i'm gunna go try that now maybe my knob is stuck
THE KID is offline
Old 12-05-2007, 08:20 PM   #8 (permalink)
switcher
switcher's Avatar
Any update on this case?
switcher is offline
Old 12-06-2007, 01:54 AM   #9 (permalink)
THE KID
i've tried everyting nothing is fixed i'm guessing it's the disk i have one with the nav hack and the disk has a few scratches so it's that or the laser on the drive
THE KID is offline
