Old 03-14-2008, 09:14 AM   #1 (permalink)
Car: 2007 Jeep Grand Cherokee
Member Number: 17025
Mygig retrofit problems
After installing the Mygig in my 07 Jeep Grand Cherokee and getting the nav and all radio function to work, I installed an aftermarket amp to replace the factory amp thinking this fix my sound problems. I was wrong. The sound now stays at a constant level. From what I can gather the mygig knows what vehicle it is in and it sends volume output accordingly. This is why the mygig will work in factory non-amplified systems and not factory amplified systems. The only solution I see is some type of interface. Any ideas or suggestions?
RRaiderSS is offline
Old 03-14-2008, 09:28 AM   #2 (permalink)
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
I don't know if this will answer your specific questions, but it's worth the read - MyGIG in MyRIG - 2006 Jeep SRT8 installation!! Update and photo.
ResumeSpeed did this to his 06 GC SRT8 so it is doable. He doesn't have it anymore, but I would expect he'll be chiming in on this later. Good luck!
Bernie
Rambit is offline
Old 03-14-2008, 12:29 PM   #3 (permalink)
Car: 2007 Chrysler 300c AWD
Member Number: 16199
I think the volume control is controlled over the canbus. Is this correct? If so you would need to convert the high speed canbus signal to a line signal that the amp can see as different volumes. I think no one will create this device. You may want to scratch the amp idea and run the mygig directly to the speakers? I may be wrong about volume control over the canbus. Let us know what you find out!
cheifsfan is offline
Old 03-14-2008, 12:35 PM   #4 (permalink)
Found an interesting ebay item
Old 03-14-2008, 12:36 PM   #5 (permalink)
will post the url after i have 4 posts
Old 03-14-2008, 12:37 PM   #6 (permalink)
anyone know anything about this?
Old 03-14-2008, 12:37 PM   #7 (permalink)
eBay Motors: 08 MYGIG RER NAVIGATION RADIO NEW for any car (item 190206432677 end time Mar-20-08 1302 PDT)
Old 03-14-2008, 01:57 PM   #8 (permalink)
TSB/Recall Forum Moderator
ResumeSpeed's Avatar
Car: 2008 Fast, really really fast. Jeep!!
Member Number: 1725
"(works) even with cars that are 50 years old any!..."
So it will work in 1958 and later vehicles? Uh, yeah, right. I'll believe it when I see it.
ResumeSpeed is offline
Old 03-15-2008, 01:20 PM   #9 (permalink)
So anyone with the Mygig will not have the option to add an aftermarket amp?
Old 03-17-2008, 12:19 AM   #10 (permalink)
turk182's Avatar
Car: 06 Black 300c 5.7
Member Number: 4352
Can you get the Mygig Lockpick ? i believe this will add a audio and video out, therefore allowing you to add an aftermarket amp
turk182 is offline
