Old 10-08-2008, 09:20 AM   #91 (permalink)
Points: 2,766, Level: 1 Points: 2,766, Level: 1 Points: 2,766, Level: 1
BCasey's Avatar
Car: 2007 Chrysler 300 Limited
Member Number: 17593
Originally Posted by Joe Cool View Post
Only problems is with the Siruis station names not appearing on the EVIC (and the clock of course).
does anyone know if theyre planning on making the clock work at some point? I'm sure all it would take a is an internal clock in the harness with a battery and feed the info to the mygig as if it was coming from the car.
Kinda hope this gets fixed, its really the only thing holding me back from getting it at this point
BCasey is offline
Old 10-09-2008, 07:38 AM   #92 (permalink)
Points: 440, Level: 1 Points: 440, Level: 1 Points: 440, Level: 1
Car: 2007 Chrysler 300C
Member Number: 19100
Pull of the minus battery cable when changing the radio?
Hi.
Is it important to do or maybe not, to pull of the minus - battery cable when plugging in the Mygig Adapter for example?
//Marcus
marcus133 is offline
Old 10-09-2008, 07:46 AM   #93 (permalink)
Points: 386, Level: 1 Points: 386, Level: 1 Points: 386, Level: 1
Bigair's Avatar
Member Number: 19015
Coastal not working on the clock.
I have talked to two different people at Coastal and they both said they are not working on the problem since it is a car design issue. I think it would be relatively easy to fix, but someone else will have to do it!
Bigair is offline
Old 10-09-2008, 10:42 PM   #94 (permalink)
Points: 1,830, Level: 1 Points: 1,830, Level: 1 Points: 1,830, Level: 1
Member Number: 17599
Originally Posted by pukkaSRT8 View Post
note: some people who have been having issues with not getting the sat info to display on their evic have used a 2 way splitter (readily available on ebay) added on the end. plug the single side of the splitter into the receiver. connect the oem antenna cable to one side of the split and the extension cable to the other. this uses both the receiver in the car (for the evic display) and the receiver in the mygig for the sound. its a get around for one of the lockpick issues.
now, if they would just sort out the clock!
I think my splitter is bad. I got one from ebay and it worked for a couple of days, but now, whenever I am in sat mode, the evic flashes between no signal and the station.
Manny -
"Training can only take you so far, beyond the training you have to have the ability to THINK.." Mr. I.
Manny 08 is offline
Old 10-21-2008, 11:25 PM   #95 (permalink)
Points: 1,723, Level: 1 Points: 1,723, Level: 1 Points: 1,723, Level: 1
Car: 2007 Dodge Magnum SRT8
Member Number: 12520
I have my mygig installed and have 1 little question.. When everything is off and i exit the vehicle i notice that the buttons from the mygig say lit. Why? is there something wrong with the mygig?? I do not want to come out to a dead battery... Any info will help
05norcalsxt is offline
Old 10-22-2008, 11:25 AM   #96 (permalink)
Points: 1,060, Level: 1 Points: 1,060, Level: 1 Points: 1,060, Level: 1
Joe Cool's Avatar
Member Number: 18981
Send a message via MSN to Joe Cool
it does eventually shut off. Just not sure how long.
2006 Chrysler 300C SRT8 w/ Predator, AirHammer, TZ Grille, AAC 8000K Halos & HID Fogs, Billet oil catch can, MB shifter paddles, Mygig w/ front and rear cameras, Illuminated rear wing and brake light badge, Mopar/Corsa Cat back polished exhaust, SLP Line Lock.
Joe Cool is offline
Old 10-22-2008, 07:38 PM   #97 (permalink)
When I went out this morning it was off.. Chrysler tech say it stays on a bit to cool down, kinda like a projection TV
Old 11-06-2008, 01:27 PM   #98 (permalink)
sox
Points: 3,756, Level: 1 Points: 3,756, Level: 1 Points: 3,756, Level: 1
sox's Avatar
Car: 2006 Chrysler 300c CRD sexy Sedan
Member Number: 12361
Send a message via MSN to sox Send a message via Skype™ to sox
Help Please!
Originally Posted by 300MAG View Post
So I finally recieved the long awaited MYGIG adapter from Coastal E-Tech today. With this I shot home from work and ripped out the REC and installed the MYGIG.
For the Installaion the Lockpick adapter was plug and play and setting a couple of DIP switches(very easy).
AM/FM antenna wire adapted to MYGIG with supplied adapter.
Builtin Uconnect requires Microphone or some type of adapting of uconnect controls on mirror. I purchased plug and play microphone from Coastal for $20.
So the install is complete and the MYGIG is working. I haven't tested everything but here are results so far.
*Back up camera working
*Sat is working
*Nav is working(nav voice guidance has a bug that when the nav voice come on the radio volume from the right speaker gets a little loader and it could be diffucult to here the nav vioce. I was able to find a somewhat happy median but playing the all the volums adjustments, this could be drawback.
*Uconnect is working
*Steering wheel switches controls Vol, Change Modes, Change stations.
Salve from the otherside
one Problem with en 300C 2005, the Uconnect end voice command the goings crazy end not work!
what did you make with the original uconnect module?
you deactivate it with starscan ?
feedback please!
thx Marco
saluti Marco
H+R Springs - Hotchkis Swaybars - Eta Beta Tettsut 10x22 - 265/35/22 + 295/30/22 - HID Xenon Fog - HID / DRL/ High Beam - Blastin Bob - CAI Volant -Dashhawk - ECU Kraftwerk Tune - Big Kraftwerk Intercooler - Illuminated LED Break-Rear Wing......
298 HP / 693 Nm
MyGIG™ - Uconnect®
80GB Harddisk
Lockpick
Front / Rearcam
Applikation: 2.067 (2.043 clockfix)
Gracenote: ECE 1289
sox is offline
Old 11-06-2008, 01:48 PM   #99 (permalink)
Points: 6,921, Level: 1 Points: 6,921, Level: 1 Points: 6,921, Level: 1
300MAG's Avatar
Member Number: 3746
Trader Rating: (4)
feedback please!
thx Marco
Disconnect the harness from the old uconnect module, it is mounted to passenger side kick panel behind the glove box. That should fix your problem.
300MAG is offline
Old 11-06-2008, 02:47 PM   #100 (permalink)
sox
sox's Avatar
grazie mille
I will try it
regards Marco
sox is offline
