Old 09-03-2008, 06:26 PM   #51 (permalink)
Points: 6,921, Level: 1 Points: 6,921, Level: 1 Points: 6,921, Level: 1
300MAG's Avatar
Member Number: 3746
Trader Rating: (4)
Originally Posted by spookyfishlizard View Post
I received my new mygig, lockpick and nav antenna today. Just went out and installed it. My nav picks up no satellite and my fm antenna is not working. Pulled it back out and both are plugged in securely. Any ideas??
Maybe you have them plugged into the wrong spot, unlucky since they should be keyed to prevent this but you may want to check. GPS is the top connecter and the am/fm is right below it, the sat is the botton connecter slighly to the right of the GPS and am/fm.
300MAG is offline
Old 09-03-2008, 06:27 PM   #52 (permalink)
Points: 471, Level: 1 Points: 471, Level: 1 Points: 471, Level: 1
Member Number: 18104
Send a message via Yahoo to spookyfishlizard
Yeah, that's exactly how I have them connected.
spookyfishlizard is offline
Old 09-03-2008, 06:29 PM   #53 (permalink)
300MAG's Avatar
Member Number: 3746
Trader Rating: (4)
Originally Posted by makemyday View Post
have posted now the photo
i have made an different to you
we take the measure when we fixed upside the MyGIG in the original screwholes of old MyGIG so our position is little bit higher than yours
but its fits perfect
i hope you can see it now[IMG][/IMG]
Looks great, very easy fix. I should check to see if he can do one for me with the cutout lower.
300MAG is offline
Old 09-03-2008, 06:45 PM   #54 (permalink)
I just got an email from him last night, he is sending me a paper template to make one for me. If I can't get my nav and FM working on this thing I guess it's pointless though.
Old 09-03-2008, 07:11 PM   #55 (permalink)
I was wondering if it makes a difference where the nav antenna is located in the car and which direction it is facing. And on my FM antenna, there is a round black plastic piece that turns on the end of my cars antenna. Is this supposed to be on there when I connect the adapter or is it keeping the two from making a connection?
Old 09-03-2008, 07:30 PM   #56 (permalink)
300MAG's Avatar
Member Number: 3746
Trader Rating: (4)
I have my GPS antenna just facing up sitting on top of the air ducts behind the dash. As far as the am/fm anteena, all I did is pull the antenna out of the REC radio attach the adapter and plug in to the MYGIG. Perhaps you can test the adapter with a ohm check on a multimeter.
Is everything else working such as DVD, harddrive and sat.... do you have sound? perhaps check to see if the connectors on the mygig look damaged?
300MAG is offline
Old 09-03-2008, 07:37 PM   #57 (permalink)
I have my nav antenna on top of the stereo, I think I'll try moving that tomorrow. I'll also check out the adapter for the FM, good idea.
I've been out messing around with it and everything else seems to work fine. DVD works, harddrive copied a cd with no problems. Just the nav and the radio. I did notice though that my clock doesn't show 12:00, it shows --:--.
Last edited by spookyfishlizard : 09-03-2008 at 07:40 PM. Reason: forgot to add something
Old 09-03-2008, 07:41 PM   #58 (permalink)
300MAG's Avatar
Member Number: 3746
Trader Rating: (4)
I would look really close at the connectors on the back, they may be damaged.
300MAG is offline
Old 09-04-2008, 06:32 AM   #59 (permalink)
Points: 642, Level: 1 Points: 642, Level: 1 Points: 642, Level: 1
Car: 2005 Chrysler 300C Hemi
Member Number: 16513
Send a message via MSN to makemyday Send a message via Skype™ to makemyday
300MAG great that you like it
yes its easy when you send Boris an paper with exactly position
i think he can do it
good luck
and i hope i can install next week my mygig when i receive the lockpick
i will post an photo..now i know how its works to show you the final look
regards from Germany Eugen
makemyday is offline
Old 09-04-2008, 07:59 AM   #60 (permalink)
Checked out the connections this morning and moved the nav antenna to on top of the ducts. I haven't tried the nav yet but did notice that on the FM adapter that was sent with my mygig adapter, the wire on the end that connects to the cars antenna only comes out of the cable probably less that 1/32 of an inch, I don't think its long enough to make the connection. Is this a part available through dealerships or do I have to wait for a new one to get shipped?
