Old 10-03-2009, 04:36 PM   #1 (permalink)
Points: 849, Level: 1 Points: 849, Level: 1 Points: 849, Level: 1
Car: 06 Chrysler 300 Limited AWD
Member Number: 22581
Fitting 08 mygig bezel in a 06
I am doing the mygig in my 06 this week as soon as I get the 08 mygig bezel I just ordered and needed help from the ppl that used the 08 mygig bezel. How did yous modify the bezel to fit in the 06 300? Thanks!
MikeyDubs is offline
Old 10-03-2009, 05:16 PM   #2 (permalink)
sox
Points: 4,835, Level: 1 Points: 4,835, Level: 1 Points: 4,835, Level: 1
sox's Avatar
Car: 2006 Chrysler 300c CRD sexy Sedan
Member Number: 12361
Send a message via MSN to sox Send a message via Skype™ to sox
ciao
you must only "grinding " the sids from the down bezel about 3/8 inch ( 10mm)
thats all
fitting-08-mygig-bezel-06-2008er-blende.jpg   fitting-08-mygig-bezel-06-2008.jpg   fitting-08-mygig-bezel-06-2008-2006.jpg   fitting-08-mygig-bezel-06-2008-2006-rear.jpg
saluti Marco
3.0 CRD 299 HP / 691 Nm
AMG Shift Paddles
MyGIG™ - Uconnect® REW
80GB Harddisk
Lockpick
Front / Rearcam
Applikation: 2.067 (2.043 clockfix)
Gracenote: ECE 1289
NAV DB: WS10 E0921 3.0.4 ( EU N208 )
sox is offline
Old 10-03-2009, 05:38 PM   #3 (permalink)
Originally Posted by sox View Post
ciao
thats all
What did you use to grind down the sided sand paper? And did you use the stock bezel as a templet and lay it over the 08 bezel to mark where you had to cut? Also did you have to touch up the sides with paint or you cant even see where you grinded the sides once you put the bezel in?
Old 10-03-2009, 05:47 PM   #4 (permalink)
sox
sox's Avatar
yes sandpaper 60 / 120 i have "cut" and testet in the car, steb by steb until it was perfectly aligned
than sanded nice and slow, no painting, only grinded
sox is offline
Old 10-03-2009, 10:32 PM   #5 (permalink)
Did you use any kind of templet or just sand lil by lil and keep testing it in the car??
Old 10-04-2009, 03:33 AM   #6 (permalink)
sox
sox's Avatar
no templet just sand lil by lil and keep testing it in the car.
I have a good eye for this work
sox is offline
Old 10-04-2009, 12:28 PM   #7 (permalink)
k thanks for all the info!!
Old 10-04-2009, 12:30 PM   #8 (permalink)
sox
sox's Avatar
n.p.
sox is offline
