Old 10-26-2009, 01:46 AM   #1 (permalink)
Points: 1,697, Level: 1 Points: 1,697, Level: 1 Points: 1,697, Level: 1
bennzsrt8's Avatar
Car: 06 chrysler 300c srt8
Member Number: 21122
sub is quiet!!!!!!!
hey all i was driving home tonight and noticed thatmy factory sub got really quiet! so i pulled over and check the trunk, the sub was playing just not very loud so i pulled the audio amp fuse (#44 in the trunk) and it looks fine.! has anyone else had this problem????
bennzsrt8 is offline
Old 10-29-2009, 01:23 AM   #2 (permalink)
bennzsrt8's Avatar
does any one have any imput?????????
Old 10-29-2009, 02:19 AM   #3 (permalink)
Points: 4,449, Level: 1 Points: 4,449, Level: 1 Points: 4,449, Level: 1
LuckyAce's Avatar
Member Number: 22917
Send a message via MSN to LuckyAce
Could be a weak/loose ground. If it's not fully completing the cycle, you're going to lose power. Happens more than you'd expect.
Sabrina - The Srebrna Djvenke
05 300 LTD AWD
To do list....
{_} Mirage doors
{_} Projector headlights/fogs, both with Halos
{_} 22" Avarus AV4 w/ ???
{_) Sway bar/shocks/struts/springs
The To-Do list has slowly been checked off.
LuckyAce is offline
Old 10-30-2009, 12:45 PM   #4 (permalink)
bennzsrt8's Avatar
its is thestock kicker set up! i changed the sub today and it still seems very very quiet!!
Old 10-30-2009, 02:19 PM   #5 (permalink)
LuckyAce's Avatar
That further supports the weak ground theory.
LuckyAce is offline
Old 11-02-2009, 02:37 PM   #6 (permalink)
bennzsrt8's Avatar
loose ground where????? with the amp??? or the sub?
Old 11-02-2009, 07:11 PM   #7 (permalink)
LuckyAce's Avatar
If you're running the stock setup, the amp powers everything, so unless everything is quiet, it would be to the sub.
LuckyAce is offline
