MYGIG istalled in pre-08 LX using MYGIG adapter - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
post #21 of 280 (permalink) Old 08-19-2008, 05:33 AM Thread Starter
Points: 25,668, Level: 1 Points: 25,668, Level: 1 Points: 25,668, Level: 1
300MAG's Avatar
Just wanted to post a picture of the bezel after completed. Overall I'm preety happy with the outcome considering this was my first time modding a bezel.
300MAG is offline
post #22 of 280 (permalink) Old 08-19-2008, 09:17 AM
Points: 12,395, Level: 1 Points: 12,395, Level: 1 Points: 12,395, Level: 1
BCasey's Avatar
Car: 2009 Dodge Challenger R/T
nice work on the bezel, is that a nav bezel. how did u go about modifying it?
BCasey is offline
post #23 of 280 (permalink) Old 08-19-2008, 12:08 PM
sox
Points: 93,024, Level: 1 Points: 93,024, Level: 1 Points: 93,024, Level: 1
sox's Avatar
Car: 2005/2009/2015 Jeep/Jeep/Dodge GC Hemi / Patriot / Charger SRT
great job !
why you do not have simply installed 2008 bezel ?
the size from the bezel and the attachments are nevertheless identical.
Marco
All Uconnect Software
www.mydrive.ch
username: mygig@soxag
Password: gasolio
..............Mopar or no Car!
sox is offline
post #24 of 280 (permalink) Old 08-19-2008, 07:40 PM Thread Starter
300MAG's Avatar
Thanks, but the bezel I tried was different and would have reqired modding as well.
300MAG is offline
post #25 of 280 (permalink) Old 08-19-2008, 08:17 PM Thread Starter
300MAG's Avatar
Thanks, Here is something to help you get started that I posted on LXF.
This is what you will need to mod the bezel:
Bezel
Plastic weld epoxy
Variety of sand paper
1 sheet of black ABS plastic
Bondo and glazing putty(as required)
Primer, Paint and clear
Time and patience
This was the first time that I modded a bezel, I think if you take you time you shouldn't have a problem. Just take your time, it takes time because there is a lot of waiting time between steps.(1) I glued the ABS into place with plastic weld epoxy. (2)Then went over it with a thin layer of bondo to fill in any uneven spots(it should only be tiny bit if any ,most gets sanded off), use the glazing putty for any small spots. (3)Then you’re ready for prime, paint and clear, after a bit of sanding of course. There may be a better way but this is what worked for me, others with more experience can chime in.
Here are some pics as I progressed, I thought I took one after prime but I can't locate right now.
300MAG is offline
post #26 of 280 (permalink) Old 08-28-2008, 02:51 PM
Points: 703, Level: 1 Points: 703, Level: 1 Points: 703, Level: 1
awakefie's Avatar
Car: 2007 Chrysler 300C AWD
Send a message via AIM to awakefie Send a message via MSN to awakefie
Good Stuff
Im really glad you got this up and working. I am still undecided about this mod. I would like to have the mygig unit, but hate to be an early adopter. The clock issue is interesting to me. I wonder what exactly causes the issue. Oh well glad to see some one had the courage to go after this one.
Where did you mount your mic?
I assume the uconnect button on the old mirror is dead?
awakefie is offline
post #27 of 280 (permalink) Old 08-28-2008, 04:42 PM Thread Starter
300MAG's Avatar
MyGIG is working great, the guys at coastal-Etech have been great. They fixed the issue with the Nav voice guidance, so the only issue is with the clock, which they said was a issue up front. There working on it but they say it will be tough task if at all possible. The cause is because Chrysler is supply the clock input to the mygig from one of the modules via the canbus.
The uconnect button is dead on the mirror but I know Chrysler sell a jumper Harness to use the mic on the mirror, It may also make the the uconnect buttons active but I haven't looked into it enough because the mic from Coastal was much cheaper.
Here is where I mounted the Mic
300MAG is offline
post #28 of 280 (permalink) Old 08-29-2008, 07:40 AM
Points: 1,069, Level: 1 Points: 1,069, Level: 1 Points: 1,069, Level: 1
Send a message via Yahoo to spookyfishlizard
That bezel looks great but has anyone come up with an easier fix than that?
spookyfishlizard is offline
post #29 of 280 (permalink) Old 08-29-2008, 08:25 AM
Points: 460, Level: 1 Points: 460, Level: 1 Points: 460, Level: 1
Car: 2006 Dodge Durango
Durango Bezel
I used yours as inspiration and modified the bezel on my 2006 Durango to accept the MYGIG I just put in. This is such a great unit compared to the old factory nav that was there before. I've pulled the audio from my rear VES into the MYGIG so I can get the sound through the speakers if we have more kids then headphones but I'm still trying to get the video from the back screen up to the front so I can have the same movie on both screens.
brunswickohio is offline
post #30 of 280 (permalink) Old 08-29-2008, 08:33 AM
Points: 5,815, Level: 1 Points: 5,815, Level: 1 Points: 5,815, Level: 1
Car: 2013 Jazz Blue Chrysler 300C
Great Job! I want to do this. Now I have to find a MYGIG at the right price. I am confused about the NAV antenna. Why doesn't the installed antenna not work and what did you replace it with? Where did you get it?
Bigair is offline
Mygig Sirius Ant into an 05 car, Adapter? Topgear2007 Car Audio/Alarms/UConnect/Navigation 5 01-28-2010 11:56 AM
TVandNav2Go MyGig Lockpick,MyGig Adapter and REC Interface Specials June & July domoftvandnav2go Car Audio/Alarms/UConnect/Navigation 25 11-28-2009 07:20 AM
RER MyGig, IPhone and MyGig Adapter (05-07 LX) immo Car Audio/Alarms/UConnect/Navigation 4 11-20-2009 02:27 PM
Mygig Adapter in European models REW?? marcus133 Car Audio/Alarms/UConnect/Navigation 5 09-10-2008 08:48 AM
Using REW together with Mygig Adapter marcus133 UK & Europe Regional Forum 0 09-08-2008 09:48 AM
