Put this under LX threads but no answer so trying here
Have a 2007 CRD touring with 6CD and satnav with 3 dash speakers, 2 front door speakers and L & R rear speakers ( can't see any sign of a subwoofer it the rear so don't know what version of Boston is fitted . When configuring the output the base, mid, treble work ok, the fade between front & rear works ok, but when balance is selected, the screen is ok but when control is moved to right hand side the sound disappears apart from a feint muffled sound from RH door speaker. Is the fault likely to be the head unit or the separate amplifier, are the outputs to L,R, Fr and rear individually fused.
I notice there are quite a few amps on E-bay but not sure which model I would need to get - Help please anyone !!
